Like Tree6Likes
Old 07-14-2014, 07:17 PM   #12766
Your tc4 weighs 1367g with a 300+gram pack, or a shorty pack ??? My Ft tc4 weighs 1372g with full size servo, heavy novak gtb, full length wires, and rx glitch buster.... I can lose an extra 60 to 100 grams if I use the 2700mah pack(168g) and new electronics, but it won't be necessary... I have no center spline, and a 208g light pack....
Originally Posted by gooba View Post
@ Indy. I'll trade you an ecxkus for one of those factory team cars. I really want to try a dual deck fiber car out but can't get all the parts and don't think I want the diggity car. Weight wise though my carbon tub car(not carbon fiber) weighs in at 1367 ready to run setup for 17.5 and with transponder I make about 1384 which is perfect. I should think either carbon fiber car should be in the 1330-1350 range similarly setup
bertrandsv87 is offline   Reply With Quote
Old 07-14-2014, 07:37 PM   #12767
moparSRT's Avatar
... Weight wise though my carbon tub car(not carbon fiber) weighs in at 1367 ready to run setup for 17.5 and with transponder I make about 1384 which is perfect. I should think either carbon fiber car should be in the 1330-1350 range similarly setup
The carbon tub comes in at 131g, the stock plastic tub is 156g. Motor mount+cam 37g.
FT TC4 chassis componets (chassis, top plate, motor bulkhead & camber link mounts) are 121g
Around 47g difference between a carbon tub chassis and Carbon fiber chassis equiped cars.
moparSRT is offline   Reply With Quote
Old 07-14-2014, 08:00 PM   #12768
Smile
If I can get my Ft tc4 down to 1272g-1312g , then my tub tc4 should be able to reach 1319g-1359g, after I finish lightening it up... Remember guys, I am using aluminum diff outdrives, Cf shaft, etc..., so my tc4.1 might be able to weigh less than most other tub cars out there... It's been a real challenge making the tc4 lose weight, but like Oprah, anything is possible....lol... So 1320grams for the Ft tc4 , and 1370 grams for the tub tc4 sounds about right with a 210 gram pack. Lipo packs saved the tc4 and many other old chassis out there...All that's left now is to TQ and win every event I participate in...lol....
Old 07-15-2014, 07:17 AM   #12769
gooba's Avatar
1367 is with a 4200 shorty lipo. Depending on which full size pack I run it comes in between 1390 and 1420. My stone stock club car is kind of portly but it weighs pretty close to USGT minimum which is its class so im gonna leave it pretty well alone.
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 07-15-2014, 09:17 AM   #12770
Hi guys comming over from the dirty side of things and am ordering a tc4 club chassie was wondering if some one could give me a short list of things to order with it to run vta or gp1
Solo1 is offline   Reply With Quote
Old 07-15-2014, 10:47 AM   #12771
Smile
Whatever brand you choose, get the lightest of everything..... Esc/receiver/servo/battery needs to be light... For example: NOVAK impact esc/ spektrum receiver/futaba bls 551 servo/ Thunderpower 3300 mah 65C (208g) lipo pack.... It's the only way to get the tc4 to be competitive........
Old 07-15-2014, 12:00 PM   #12772
DesertRat's Avatar
If your VTA class enforces a high weight limit you don't have to worry about getting down to 1380. Don't get some tiny pack and be slow as Bert, get the highest power short pack you can and find balance. For the best example of what a tub TC4 can do I would recommend this as an example by Ray Klebanow on page 797 of this thread. Front DCJ's will be hard to find, but the part number is LOSA3344.
Team Associated TC4
Good luck.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 07-15-2014, 03:46 PM   #12773
Default gearing and tires
Looking for gearing help for 17.5 blinky and what a good rubber tire for carpet. Thanks
troyd is offline   Reply With Quote
Old 07-15-2014, 04:16 PM   #12774
DesertRat's Avatar
If you are racing indoors and your track is in the 60-80 foot long straight range, I would recommend a starting gearing of around 4:1 and play with your timing/gear from there. The internal gear ratio of a TC4 is 2.5:1, so an 80 tooth spur and a 50 tooth pinion would hit 4:1 on the dot, but you may need to dremel clearance for the pinion if you are racing a plastic tub car. This gearing, or one close to it, is a safe, non-aggressive starting point for 17.5 on almost any chassis or tracks.
Also, it is highly recommended that you run a fan in spec motor touring car, whether you need it or not it gives you a safety net and more consistent power over the run.
The BEST tires for carpet are Sorex, usually a Sorex 28 for max traction, but they are expensive. Sweep and Muchmore are good as well. If you are racing at an organized facility they may have a spec tire, and if not I would recommend trying to organize a spec tire agreement in the interest of saving a lot of money on tires.
I hope that helps, good luck,
Old 07-15-2014, 05:07 PM   #12775
CraigH's Avatar
Default gear diffs
AE TC7.1
AE B6d
AE B64d
CraigH is offline   Reply With Quote
Old 07-15-2014, 06:10 PM   #12776
NutDriver's Avatar
Trader Rating: 14 (100%+)
Craig,
Will those fit in a TC4?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 07-15-2014, 07:21 PM   #12777
gooba's Avatar
I really really hope so
Old 07-15-2014, 07:28 PM   #12778
It's always best to set up the tc4 with the lightest stuff possible even if you decide to get a heavier lipo pack for the higher VTA weight limit, but always keep in mind that you won't have to get new stuff if you decide to try 17.5t blinky, all you'll have to do is switch to the lighter lipo pack... You can't run shorty packs in 17.5t blinky or mod, so you'll be stuck with an illegal pack for those classes...Buy a full size battery you can use in all classes once, and call it a day... If not a 3300mah thunderpower, then you can get the 4300(255g) TP that will run in all classes....
Team Associated TC4
Good luck.
Old 07-15-2014, 08:04 PM   #12779
gooba's Avatar
Since when are shorty lipos illegal? Yes light weight is helpful but why should you make a super lightweight car to add it all back in and then some to make weight for your class? Your not gaining anything by drilling and grinding away chassis and suspension pieces but a flexy mess.
Old 07-15-2014, 09:08 PM   #12780
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
Dude stop with the false so called know it all posts. You don't need the lightest stuff and last I saw shorty packs were legal. 90% of the post I read in here are ridiculous. Don't listen to Bert he thinks he knows setup but that is all bs.
Serpent project 4x
jeff jenkins is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
