Like Tree26Likes
Old 07-13-2014, 06:47 PM   #12751
moparSRT's Avatar
Originally Posted by bertrandsv87 View Post
The associated chassis itself looks lighter than the diggity designs chassis, but the weight really comes from the aluminum Camber link mounts, and center spline, on top of the heavy electronics that most people use.... It's possible to just use the diggity designs shock towers and 2mm top plate on the factory team tc4 to lose some weight, but you'll still need light electronics to make weight....The center spline weighs 19 grams, and I guess the camber link mounts weigh about 20 grams... After that, you'll be able to use a 310 gram battery pack, but it's much cheaper to use a lighter battery .....
All 4 aluminum camber link mounts weigh 14g, with diggity you need to cut the plastic ones if you want better roll adjustment which weigh 8g, a 6g difference.
Center spline is optional as are the top deck standoffs, you dont use them unless ur racing foams on carpet.
Diggity shock towers have built in old school camber link mounts so more material and should weigh more then the FT TC4 towers.
Sorry but I dont see where the FT TC4 would be MUCH heavier then a diggity, they should be around the same weight give or take a few grams.
moparSRT is offline   Reply With Quote
Old 07-13-2014, 10:31 PM   #12752
Smile
You are right, but there is some sort of mystery surrounding the tc4 overweight issue that I feel compelled to trim the fat as much as I can to make weight...... It seems that AE carbon fiber is made out of lead or something, because I use the same heavy electronics in my Awesomatix and have no problem making weight, eventhough the Awesomatix looks a lot more cluttered... I have to leave alot of empty space on my tc4+ use a 208 gram pack to weigh the same as the Awesomatix...... It's unreal, but the scales don't lie. Trimming 20 grams at a time on a tc4 is the only way to get down to 1380g......
Originally Posted by gooba View Post
Bert your trying to save too much weight especially since a majority of tc4s race in USGT and VTA and for those that do run 17.5 or mod 16 grams overweight isn't going to make any difference.
bertrandsv87 is offline   Reply With Quote
Old 07-14-2014, 01:09 AM   #12753
DesertRat's Avatar
Originally Posted by moparSRT View Post
Please explain how a diggity carbon fiber chassis is MUCH lighter then a AE FT TC4 carbon fiber chassis The diggity conversion is nothing more then a Factory Team TC4, so where is the weight savings coming from that you speak of
Just by looking at the chassis its obvious the AE version is lighter with most of the chassis cut out.
The main chassis itself is probably a bit heavier but it cuts other stuff. Maybe the Diggity chassis could be lightened a hair but after I painted up a spare lightweight body the car is really close to legal minimum with a transponder and swaybars. Car feels very solid, too bad I won't be able to race it until my next trip to Cali in August. It will be like a magazine from 2005, my DC4 vs my JRX-S Type R!
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 07-14-2014, 06:13 AM   #12754
moparSRT's Avatar
Originally Posted by DesertRat View Post
The main chassis itself is probably a bit heavier but it cuts other stuff...!
Chassis, top deck and shock towers ... thats it, everything else is the same. I dont see where you would find any weight savings to claim a diggity is MUCH lighter.
The diggity car should weigh the same as a FT TC4 give or a take a few grams
Old 07-14-2014, 08:15 AM   #12755
The Ft tc4 should be about 40 to 60 grams heavier than the dc4 le with the same electronics, and they both can be underweight, it's all about choice....
Old 07-14-2014, 08:49 AM   #12756
moparSRT's Avatar
where does this 40-60g come from bert ?? the AE chassis, shock towers and servo mount are lighter then the diggity version, that leaves the top plate and camber link mounts
AE chassis, top plate & shock towers come in at 106g + the 14g for the camber mounts gives a total of 120g ... so you saying bert that the diggity conversion only weighs 60g
Old 07-14-2014, 09:00 AM   #12757
I only look at the AE parts that are not present in the dc4 le, like the center spline (19g), camber link mounts(14g), top plate weight difference ( maybe 7g), etc... It' s not that much difference to justify $200... I'd rather invest on a range of lighter battery packs (3300/4300/etc...) to bring the weight down....
Old 07-14-2014, 10:25 AM   #12758
DesertRat's Avatar
If I take a guess I would say the conversion saves 30g or so, an ounce. Aluminium and titanium hardware and a light body probably save that much again, so 60g weight savings over a steel screw TC4. Not massive but my servo weighs about 60g. That's just how I race, get the most powerful electronics you can and then force it to make weight.
Old 07-14-2014, 10:53 AM   #12759
moparSRT's Avatar
If I take a guess I would say the conversion saves 30g or so, an ounce...
on what part are you saving the 30g
chassis, shock towers & servo mounts are lighter on the FT TC4 ... your left with the top plate that is lighter from diggity
Since you're only guessing, my guess is the FT TC4 is lighter
Old 07-14-2014, 11:03 AM   #12760
DesertRat's Avatar
Well your guess is wrong then,
You throw away the camber link mounts, aluminium standoffs, most of the top deck, and the battery strap and gain weight? Maybe Diggitys suspension and top deck plus the AE main chassis would be lightest.
Old 07-14-2014, 11:13 AM   #12761
moparSRT's Avatar
camber links are 14g, aluminum standoffs and center spline are not used unless ur racing foam tires on carpet and want a stiff chassis.
Diggitys suspension Diggity doesnt make any suspension parts ... you use all the TC4 parts.
My guess the the extra weight of the diggity chassis, shock towers and servo mount are not made up by the lighter top plate .... so in the end a FT TC4 will be lighter
Old 07-14-2014, 11:22 AM   #12762
DesertRat's Avatar
So you agree that the lightest combo would likely be the diggity top deck and shock towers with a stock AE main chassis?
Also, the Diggity chassis is thinner carbon fiber than the stocker, so that's a little weight saved in spite of no battery cell cutouts. A DC4 will be a lighter rolling chassis than a TC4, but not by much, and the Diggity main chassis may be a hair heavier.
Old 07-14-2014, 01:08 PM   #12763
IndyRC_Racer's Avatar
While the recent posts are interesting from a technical standpoint (which components can offer weight savings), I really want to read about TC4 or TC4 based cars doing well on the track.
I have 2 FT TC4 chassis sitting collecting dust. One reason I stopped racing them was my setup was over 1600 grams in VTA (older speedo, steel diffs, heavy body, center spline installed). If there is a way to put one on a diet and be competitive in USGT or even 17.5, that would be great. I will admit I never considered removing the center spline completely or modifying the top deck. I just thought the car would be too flexible and cause the shaft to bind (from witnessing another driver try it).
At least for now I'm content to run my 2 tub chassis TC4's in VTA (one for carpet & one for parking lot).
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 07-14-2014, 02:13 PM   #12764
gooba's Avatar
@ Indy. I'll trade you an ecx ruckus for one of those factory team cars. I really want to try a dual deck fiber car out but can't get all the parts and don't think I want the diggity car. Weight wise though my carbon tub car(not carbon fiber) weighs in at 1367 ready to run setup for 17.5 and with transponder I make about 1384 which is perfect. I should think either carbon fiber car should be in the 1330-1350 range similarly setup
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 07-14-2014, 06:07 PM   #12765
moparSRT's Avatar
Originally Posted by IndyRC_Racer View Post
...One reason I stopped racing them was my setup was over 1600 grams in VTA ...
wow thats way up there, I need 152g of lead to get my FT TC4 up to 1550g , and thats with standard electronics
DS1015 servo
Justock
Spektrum SR3001
Balistic 25.5
Reedy 5000
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
