Old 07-10-2014, 08:43 PM   #12736
DesertRat's Avatar
Originally Posted by gooba View Post
@desertrat. What does that setup weigh rtr? And is it worth the money? I'd really like a carbon fiber tc4 but don't know if I can bring myself to spend what a new kits costs on a conversion kit
My car as pictured with the big metal gear servo, hefty no-motor-limit EST, 7400mah battery, fan and all the rest comes to 1396g with a standard weight body. The car is not quite complete, as it will need swaybars to race, but there isn't really any more weight for the car to lose as it has about two steel screws left in the car! That, and I haven't re-installed the swaybars yet...
That being said, a TC4 factory team with the carbon chassis and all the rest would be MUCH heavier, which is the advantage of the Diggity car over any associated product, it simplifies the car and saves you a massive amount of weight. If I ran a lightweight body, I think my DC4LE would be close to the lower limit. Remember that a body without any paint weighs over 100g, going from .030 to .025 lexan saves a bit.
One thing is for sure, I won't need to worry if I'm underweight!
I race toy cars for fun. If I need to explain, you'll never understand.
If everything is under control... go faster.
WTB: Carpet racing in Arizona.
It is obvious and intuitive to the most casual of observers that RC racing is better than golf.
DesertRat is offline   Reply With Quote
Old 07-10-2014, 10:42 PM   #12737
Smile
That protek pack weighs a ton...lol... 333 grams ...wow... The dc4 le is pretty light though.... With a very light battery, lightweight body, and light electronics, the dc4 le will be in the 1200gram world...
1396 - 125(3300 battery) - 20(light body) - 50(light electronics) equals 1201 grams.... Add 179 grams flat on the chassis, and you' ll make weight... Weight holes down the middle would be great for lowering the center of gravity....
bertrandsv87 is offline   Reply With Quote
Old 07-11-2014, 12:16 AM   #12738
DesertRat's Avatar
No.
Old 07-11-2014, 10:35 AM   #12739
Default Rear sway bars?
Greetings, I have a carbon fiber/aluminum converted TC4 I bought that came with a sway bar installed up front but it doesn't have a rear one. Does anyone know if the sways bars TA sells ( ASC31057 ) are for both front and rear or do I need to buy a rear set separately?
Djtrippusa is offline   Reply With Quote
Old 07-11-2014, 11:07 AM   #12740
NutDriver's Avatar
Trader Rating: 14 (100%+)
Both.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 07-11-2014, 11:10 AM   #12741
Thank you soo much!
Originally Posted by NutDriver View Post
Both.
Old 07-11-2014, 11:11 AM   #12742
Does anyone have recommendations for a metal spur gear for this vehicle? I do a lot of parking lot drifting and rocks keep eating my plastic ones
Old 07-11-2014, 02:27 PM   #12743
gooba's Avatar
One of the funky Chinese places like Asiatees or boom racing may have one that will work but I wouldn't trust it. Perhaps u need to find a new place to drift if your chewing up spur gears I can't imagine the damage that's happening to your chassis and tires.
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 07-12-2014, 07:28 PM   #12744
How does one adjust the rear diff in this car? My rear diff is too stiff.
On another note, I took my car to a large track today and had a blast. I was running 18.5 second laps and with many adjustments and practice I was in the 16.5-17 range. I handed my transmitter to a semi-pro driver and he basically ran 15.4 laps... I think he is running 14 second. laps with his car.... I don't have enough motor..5.5t and need to change my esc too... Also running the stock body, but have a protoform Mazda that needs installation. This may help a tiny bit...I will change out the esc and motor in the future... On another note...I borrowed a friends shorty pack80 c and 4600mah as opposed to my standard 7200 mah heavier packs. My c rating for the 7200 is 70 c if memory serves... The latter was good for a .5 per lap difference...so much fun.....
SouthFloridaApp is offline   Reply With Quote
Old 07-12-2014, 10:13 PM   #12745
gooba's Avatar
To adjust the rear diff you pop the I believe right side cvd out of the out drive and there is an adjustment screw in the out drive. Don't loosen to much though or it'll slip and burn up on u. I'll double check which side shortly to be sure. Also you don't have enough motor with a 5.5? How big is your track? Can you gear up any to gain more speed?
Old 07-12-2014, 10:37 PM   #12746
IndyRC_Racer's Avatar
Adjustment screw head location on AE TC3/TC4 diffs...
Steel Diff - short side
Plastic Diff - long side
Here is a link on Team Associated's website for all current TC4 manuals (http://www.teamassociated.com/manuals/TC4). The TC4 FT manual includes instructions on how to build plastic and steel diffs for the TC3/TC4.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 07-13-2014, 06:59 AM   #12747
moparSRT's Avatar
Please explain how a diggity carbon fiber chassis is MUCH lighter then a AE FT TC4 carbon fiber chassis The diggity conversion is nothing more then a Factory Team TC4, so where is the weight savings coming from that you speak of
Just by looking at the chassis its obvious the AE version is lighter with most of the chassis cut out.
2014 IFMAR Warm-Up Pics >>> www.rcactionpics.com <<<
Check it out >>> www.RaceVTA.com <<<
moparSRT is offline   Reply With Quote
Old 07-13-2014, 07:33 AM   #12748
Smile
The associated chassis itself looks lighter than the diggity designs chassis, but the weight really comes from the aluminum Camber link mounts, and center spline, on top of the heavy electronics that most people use.... It's possible to just use the diggity designs shock towers and 2mm top plate on the factory team tc4 to lose some weight, but you'll still need light electronics to make weight....The center spline weighs 19 grams, and I guess the camber link mounts weigh about 20 grams... After that, you'll be able to use a 310 gram battery pack, but it's much cheaper to use a lighter battery .....
Old 07-13-2014, 02:03 PM   #12749
gooba's Avatar
Bert your trying to save too much weight especially since a majority of tc4s race in USGT and VTA and for those that do run 17.5 or mod 16 grams overweight isn't going to make any difference.
Old 07-13-2014, 02:44 PM   #12750
Emaculant's Avatar
My FT TC4 race ready with heavy electronics, fan, motor heat sink and a shorty turnigy 4200mah weights 1330g. Not sure how light you guys looking for but 17.5 stock spec in my area is 1380g.
Emaculant is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 8 (3 members and 5 guests)
Nerobro, tman4wdr, _dave
SEO by vBSEO 3.5.0
