Like Tree19Likes
Old 07-08-2014, 09:20 AM   #12721
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
In VTA and USVTA the TC4 is doing fine. You do not "NEED" to do all that was just said. It will work fine. Check on the USVTA or VTA threads . . . mostly, just get a good, neutral setup and drive it. Both VTA and USVTA are more about driver skill than getting every hopup you can find. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 07-08-2014, 09:22 AM   #12722
moparSRT's Avatar
yes the 55 will fit, I have run the 49t spur on mine (big 1/8 scale track), for vta you wont use anything bigger then 60t 48p
moparSRT is offline   Reply With Quote
Old 07-08-2014, 09:29 AM   #12723
moparSRT's Avatar
Originally Posted by IndyRC_Racer View Post
Mopar has fallen off the TC4 bandwagon for his racing, so take his advice accordingly.
LOL
still have mine and not selling it, but after trying the XI Sport my TC4 has become a paperweight
Old 07-08-2014, 09:37 AM   #12724
jkach's Avatar
There is no need for expensive upgrades to race a TC4 in VTA. I actually "downgraded" from a spool to a plastic diff in the front of my car. The diff is easier on the front cvds and lighter. I was able to run the composite bones without any issues. (Note: I did have to adjust my setup to work better with a diff)
The only reason to upgrade the stock plastic shocks is that threaded shocks are quicker to make small adjustments to ride height. The stock plastic shocks work well if built properly.
The only "upgrade" needed on a TC4 is a wider bumper, which will help protect the steering rack.
I currently race a TC4 in VTA and I have been able to be competitive with it locally and nationally. While there may be "better" cars out there, the TC4 has been a great value for me.
So which bumper did you get? and what is the gearing of choice for your typical parking lot track (nothing really to big)? I'm putting one together also and I'm very new to this on road thing. Thanks in advance.
SC10.2
jkach is offline   Reply With Quote
Old 07-08-2014, 09:48 AM   #12725
moparSRT's Avatar
I use the NTC3 bumper
around 3.5fdr
Old 07-08-2014, 10:05 AM   #12726
IndyRC_Racer's Avatar
A good bumper upgrade for any touring car is the Parma universal ultimate bumper, which is retangular. You will have to cut it to fit the body you are running, but for VTA that will help prolong the life of your body.
Here is a link to Parma bumpers on their website (http://parmapse.shptron.com/c/rc-car..._front-bumpers).
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 07-08-2014, 10:24 AM   #12727
jkach's Avatar
Thanks for the help guys.
SC10.2
Old 07-09-2014, 11:27 AM   #12728
DesertRat's Avatar
My Diggity Designs DC4LE, looking really pretty with its new aluminum sliding rack steering and milled shock tower mount to get the CG down just a hair. It just needs swaybars and it's ready to race once more.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 07-09-2014, 11:43 AM   #12729
oreo's Avatar
Greetings DesertRat. Cool pictures of the DC4LE- if ya' don't mind me askin', which chassis plate are you running? and for carpet or asphalt?Please do tell.
I'm jus' tryin' to decide which chassis that I'd get for my conversion.
Rc 10L (x6)
(.......in 2010, I jus' may get to run one.)-Irrgang Racing Service;TeamCRP. R.I.P. Billy 105
oreo is offline   Reply With Quote
Old 07-09-2014, 03:18 PM   #12730
gooba's Avatar
I too switched out to ball diffs in the front of my tc4s and have no problems with the plastic driveshafts. I did but lightweight aluminum diffs but that's personal preference. As far as shocks tear them off rebuild with different seals and plenty of green slime and your good to go. The 55 tooth spur works just fine you'll just need to Dremel under the pinion a bit to fit pinions over 35t. As far a s factory team options you can still get everything but the motor mount and I've been told you can modify a stock one however VTA has a 1550gram minimum weight so the light weight parts means a lot of lead to add back in.
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 07-09-2014, 03:40 PM   #12731
Thanks for all the info gentlemen, ordered a TC4 from my LHS today along with spec wheels and tires for VTA and Parma universal bumper...Gotta get me a 25.5 now as I have never had the need for one in my motor collection until now...I am not seeing the LRP Sphere TC Spec esc listed on ROAR's approved blinky esc list so I guess it is a illegal speedo? That is the speedo I had planned on using as I have one not being used...Can not understand that esc not being approved as it is non-updateable with no timing adjustments as far as I know...
JLinney is offline   Reply With Quote
Old 07-09-2014, 04:43 PM   #12732
gooba's Avatar
Check with your local track as to what rules they enforce some tracks are becoming lenient on speed controls as the VTA approved list is becoming quickly discontinued
Old 07-09-2014, 09:51 PM   #12733
DesertRat's Avatar
I have only run this car on carpet, I just like my cars too much to subject them to the death of a thousand cuts that is asphalt racing on less than optimal surfaces. The chassis plate is the Diggity stock plate, the chassis is plenty flexible with that plate and I never saw the need to make it more flexible (I personally think the trend of wet-noodle touring cars may be reversing...), other than that, the car just runs a spool and the stock TC4 ball diff. I needed to get all of the steel out of the car to make the lower weight limit, but no biggie.
Old 07-10-2014, 03:46 PM   #12734
gooba's Avatar
@desertrat. What does that setup weigh rtr? And is it worth the money? I'd really like a carbon fiber tc4 but don't know if I can bring myself to spend what a new kits costs on a conversion kit
Old 07-10-2014, 04:36 PM   #12735
NutDriver's Avatar
Trader Rating: 14 (100%+)
I have a DC4LE and with full-sized servo and ready to run (short of the battery and body), I think mine was about 1100g. I'll double check on Sunday.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
