Like Tree26Likes
Old 07-01-2014, 05:49 PM   #12706
jkach's Avatar
Originally Posted by gooba View Post
The stock tc4 setup is actually pretty good. It needs a bit of Dremel work in the battery tray to fit square lipo packs and underneath the motor mount to fit anything over a 35t pinion. Also it's really helpful to take all the bearings out pull the seals out,clean the grease out(I use motor spray) and re lube them with good bearing lube.(marvel mystery oil works well too) then put them back in the car. You'll be amazed how much freer the car is.
Thanks I'll give it a try.
SC10.2
jkach is offline   Reply With Quote
Old 07-02-2014, 06:38 AM   #12707
boudin4evr's Avatar
Trader Rating: 18 (100%+)
Originally Posted by winstoncup View Post
Anyone have one they would like to sell?
Pm me. I'm looking for one.
I have a TEAM car and a Factory team car
not selling carbon fiber FT car
but I am selling the Team car roller
If not, I'll make it a basher/drift car
look in For sale section
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 07-02-2014, 08:01 AM   #12708
boudin4evr's Avatar
what is a lower cost alternative for a motor and esc? I run TEKIN equipment in my FT TC4 but was gonna put a cheaper system in another TC4 team car that I have lying around to drift and play around with
thanks
Marc Richard
Old 07-02-2014, 09:37 AM   #12709
NutDriver's Avatar
Trader Rating: 15 (100%+)
Speed Passion combo from the SpeedPassion US warehouse is a good and inexpensive combo.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 07-02-2014, 06:27 PM   #12710
I use a hobbywing Justock with their programming card and a hobbyking track star 34 dollar motor. It's smooth.... Not sure about the hobbywing motors. You could try the hobbywing combo..make sure u get the programming card... Get in touch with fastpete in the hobbywing thread...super fast service..cheap..and a great guy...
SouthFloridaApp is offline   Reply With Quote
Old 07-02-2014, 07:25 PM   #12711
Just getting back into RC after 10 years, and need some help with gearing. I bought a brushless system and plan to run 17.5 sportsman class. I am a bit confused as to what spur and pinion to use. I have the original setup 72T spur/28T pinion 48 pitch that was matched to a 24 degree stock bushed motor. I have been looking on Rctech and Associated on what to use, but I am unsure, do I go up on the spur or go down from 72T? The only available spur gears are 75T, 69T, and 66T. I am running a Team Powers motor that suggest to start at 4.2 to 4.8 gear ratio, but the ESC suggest 3.9 for the 17.5T. Any suggestion of spur and pinion size is greatly appreciated.
Dayten is offline   Reply With Quote
Old 07-03-2014, 02:56 PM   #12712
gooba's Avatar
A 60 tooth spur and a 37 tooth pinion will give you a 4.05 final drive. But you could probably get away with up a bigger pinion depending on your track. You'll have to order a 60tooth spur from Robinson racing though and Dremel the chassis under the pinion so it will fit.
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 07-06-2014, 06:18 PM   #12713
gooba's Avatar
Does anybody mess with anti dive at all?(the spacers under the front arm mounts). Ive messed with anti squat quite a bit and my car accelerates like a drag car but I've never messed with the anti dive in the front I've never felt like my car needed help under breaking but I'm always looking for something to go faster or handle better. Anybody got any insight?
Old 07-06-2014, 07:04 PM   #12714
Thanks for the reply gooba. I did find a 62T at my local hobby shop. I will need to special order the 60T and 55T spur gear. Thanks again.
Old 07-06-2014, 10:32 PM   #12715
I messed with anti dive a lot, but it decreased front caster too much, and made my car wander more on the straights in addition to increasing the likelyhood of traction rolling in the turns... I run my front ARM mounts flat now, with no shims at all, and it works perfectly now.....
bertrandsv87 is offline   Reply With Quote
Old 07-08-2014, 06:07 AM   #12716
Looking at building a VTA car and was thinking of using a TC4 Club Racer to fill the bill...I am worried that with the age of this chassis and already seeing that most hopups have been discontinued, the general parts support for the chassis will cease to exist...Should I look elsewhere for a chassis or do you guys see this chassis being supported for the next couple of years
JLinney is offline   Reply With Quote
Old 07-08-2014, 07:59 AM   #12717
Rick Hohwart's Avatar
The TC4 Club Racer sells very well. Parts support will remain as long as the chassis remains popular.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 07-08-2014, 08:18 AM   #12718
moparSRT's Avatar
for much less $$ you can get a modern touring car like the XI SPORT or S2 which out of the box are competitive without additional upgrades.
The TC4 will need some dremel work to make a lipo and proper gearing fit, also you will need to upgrade the front axles to aluminum or steel as the stock plastic ones will snap the first time you pull the throttle, you will also want(need) to upgrade the shocks. Most of the good Factory Team parts for the TC4 have been discontinued.
You can buy a used modern TC for less then it will cost to get a TC4 race ready.
The TC4 is great for bashing, but if you want to race there are better options
moparSRT is offline   Reply With Quote
Old 07-08-2014, 09:17 AM   #12719
Thanks for the reply and I am sure there are better options out there...I have the shocks covered as I have a brand new set of FTTC3 shocks and VCS2 upgrade kit still in package from another project, Dremel work is no problem for me, and front HD axles are about $20...Will the Robinson 55T 48P spur fit and allow enough motor adjustment for proper mesh to achieve a good FDR or do the bigger spurs(66T+) have to be used? Any and all info I can gain from you guys is much appreciated as I am totally new to on-road and have a F1 car and building a VTA to get my feet wet on carpet this winter when work slows down a little...
Old 07-08-2014, 09:20 AM   #12720
IndyRC_Racer's Avatar
Mopar has fallen off the TC4 bandwagon for his racing, so take his advice accordingly.
There is no need for expensive upgrades to race a TC4 in VTA. I actually "downgraded" from a spool to a plastic diff in the front of my car. The diff is easier on the front cvds and lighter. I was able to run the composite bones without any issues. (Note: I did have to adjust my setup to work better with a diff)
The only reason to upgrade the stock plastic shocks is that threaded shocks are quicker to make small adjustments to ride height. The stock plastic shocks work well if built properly.
The only "upgrade" needed on a TC4 is a wider bumper, which will help protect the steering rack.
I currently race a TC4 in VTA and I have been able to be competitive with it locally and nationally. While there may be "better" cars out there, the TC4 has been a great value for me.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
