Like Tree1Likes
Old 06-18-2014, 10:09 PM   #12661
has anybody made a gear diff for the tc4 yet??
DESOTO RACING,,SERPENT S411 3.0 USGT,,S411 3.0 17.5,,MOTIV,,FRP PAINT WORKS
starrx is offline   Reply With Quote
Old 06-18-2014, 11:16 PM   #12662
DesertRat's Avatar
No, but the ball diff isn't that bad if it's correctly assembled. The car does not appear to be that diff-sensitive.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 06-19-2014, 07:02 AM   #12663
DarthRacer's Avatar
Does anyone drift with their TC4 and have a good base setup?
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Old 06-19-2014, 07:09 AM   #12664
moparSRT's Avatar
spool in the rear, front one-way, will set camber for even tire wear.
moparSRT is offline   Reply With Quote
Old 06-19-2014, 07:11 AM   #12665
DarthRacer's Avatar
Cool. That confirms setup tips I heard for other cars.
How about shocks? I've seen some setups that say you should lay down the fronts and stand up the rears. Make the rear harder than the front.
Old 06-19-2014, 07:16 AM   #12666
moparSRT's Avatar
I have not seen any difference regardless of what I do with the shocks/droop/ride height. I dont think it matters becouse of the lack of speed and traction.
Old 06-19-2014, 07:20 AM   #12667
DarthRacer's Avatar
Maybe that is for different types of drift tires then. I just have the basic hard plastic type for now but plan on HPI T-Drifts at some point.
Old 06-19-2014, 07:26 AM   #12668
moparSRT's Avatar
Quite possible, im no pro drifter, just play around with friends on parking lots.
Old 06-19-2014, 06:38 PM   #12669
Advice needed
Have a tc4 with a Novak gtb2 with a sensored motor. The car runs faster backwards then forward....about twice as fast. I have reversed the throttle position in my transmitter, but the car then goes backwards when I pull the trigger forward. The wires from the esc to the motor are wired a to a, b to b, and c to c. I am wondering if the motor setting from the esc is running clockwise instead of counter clockwise... Any thoughts...
SouthFloridaApp is offline   Reply With Quote
Old 06-19-2014, 06:55 PM   #12670
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Originally Posted by SouthFloridaApp View Post
Advice needed
Have you gone back through the set up sequence for the ESC after changing transmitter settings? You will need to do this.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 06-19-2014, 08:15 PM   #12671
I fixed my issue. I went into the esc settings and changed the motor rotation.
Thanks for the reply.
There is a little plug that comes out of the fan from the esc. Where do I plug this into and do I need some sort of adapter? Trying to get this car ready for a race this weekend...
Old 06-19-2014, 08:22 PM   #12672
nf_ekt's Avatar
Glad you fixed it.
I'd download the manual online so you can see how all the wiring works. You should be able to connect the fan to the esc, just look at the description decals to see which is pos/neg (red/black). Hth. Other wise I just run the fan wires straight to the esc (solder them to the pos / neg wires that go to the battery).
Up the Irons \m/
Old 06-19-2014, 09:18 PM   #12673
Good to hear ..
bertrandsv87 is offline   Reply With Quote
Old 06-20-2014, 07:46 PM   #12674
gooba's Avatar
To the drift guys there actually is suspension set ups out there for drifting. Generally soft in front and stiff in the rear. Also 3 to 5 degrees of front camber so at full counter steer your inside tire is at 0 camber, less rear toe is also recommended so the rear end will come around easier. Balance is really key also as an off balance car won't transition left to right well.
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 06-21-2014, 05:23 AM   #12675
DarthRacer's Avatar
Good to know!
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
sam1030
