Like Tree19Likes
Old 06-03-2014, 09:30 PM   #12601
Maybe I'll just get the shock upgrade kit that is $40.00 dollars and not $100.00.
Mac8 is offline   Reply With Quote
Old 06-03-2014, 10:33 PM   #12602
Hey guys, I have a TC4 and I installed a Savox 1251 Servo and there is a problem with it. The wheels aren't centering right and the car won't turn right as much as left. I took out the servo and checked the centering and it looked it was fine and when I turned right and left it was the same amount of steering. I think there is binding on the steering. What should I check or what to replace? I might go to the hobby shop on Thursday.
Thanks In Advance
Old 06-04-2014, 07:21 AM   #12603
boudin4evr's Avatar
Trader Rating: 18 (100%+)
take a look guys
Team Associated TC4 Team Car
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 06-04-2014, 09:11 AM   #12604
Rick Hohwart's Avatar
Thanks In Advance
It sounds like a radio problem. What radio do you have. With EPA and sub trim adjustments it should be simple to achieve equal steering right and left.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 06-04-2014, 12:34 PM   #12605
gooba's Avatar
@mac8 I agree with rick it sounds like you have a radio adjustment out of wack. And as far as upgrades for your car yes to sway bars and one ball diff for the front. Take the shocks off the car and rebuild them right away. I threw out the stock Orings and used Factory1 Orings. (Hes a personal friend of mine but his shock parts are second to none) Rebuild them per the instructions and use plenty of green slime on the rings and seals. Other than that run your car as is and upgrade as needed(a spring set would be my next upgrade)
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 06-04-2014, 06:53 PM   #12606
NutDriver's Avatar
Trader Rating: 14 (100%+)
Where can I get Factory1 O-rings, gooba?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 06-05-2014, 05:07 PM   #12607
Emaculant's Avatar
On the FT TC4 what's the largest spur for the top deck my motor was running 200 without a fan after 6min it's mod 19/72. Thinking 18/75 and a good fan can drop the temp in a reasonable range.
Emaculant is offline   Reply With Quote
Old 06-05-2014, 05:25 PM   #12608
gooba's Avatar
factoryone-rc.com. I maybe biased but I run or use every product he has
Old 06-05-2014, 07:10 PM   #12609
I got the VCS2 Shock Rebuild Kit for my car to make it better and if I have enough budget I will get the sway bars. Turns out the screw that goes in the steering rack is loose making it weird. Thanks For The Help!
Old 06-06-2014, 06:20 AM   #12610
boudin4evr's Avatar
i asked several times, what bumper and foam do you guys run? I heard parma foam part number ?
what mount for bumper? part number? thanks
Marc Richard
Old 06-06-2014, 09:10 AM   #12611
NutDriver's Avatar
Thanks, Gooba. Will give them a shout.
USVTA member #111
Old 06-06-2014, 10:32 AM   #12612
Smile
19/72 is 9.47fdr , which is very low for mod....... Going lower will generate more heat.... You might need to take Off your bearing shields to make sure your drivetrain is also free at high rpm... I doubt you run a 2.5t or 3.5t , which I run between 8.409fdr(3.5t) and 8.8fdr(2.5t)..... It is also possible to get better Performance and less heat by turning down the boost and gearing up... Anything above 9.0fdr is too low......
bertrandsv87 is offline   Reply With Quote
Old 06-06-2014, 11:38 AM   #12613
IndyRC_Racer's Avatar
To further explain...too low gearing means that you may be over-revving the motor, which can generate heat.
Also gearing too low can create wheel spin when coming out of a corner, which in itself can contribute to over-heating a motor.
You didn't mention if you were running brushless or brushed motors, but brushless motors have more torque and normally use lower number FDR's to achieve best results (when compared to brushed motors)
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 06-06-2014, 02:46 PM   #12614
Emaculant's Avatar
HMM so the higher the number the lower the FDR? So I should go for a larger pinion? It's a brushed mod motor.
Old 06-06-2014, 03:09 PM   #12615
gooba's Avatar
@boudin the parma bumper has been discontinued so ebay or the forsale section maybe your only option for it. 3racing also discontinued theirs however Asiatees show them in stock still
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
