Like Tree42Likes
Old 03-14-2014, 06:08 PM   #12481
Racer X79's Avatar
Trader Rating: 30 (100%+)
Originally Posted by THEBIGBULL View Post
A couple of questions??
I have a TC3 with the IRS graphite conversion for VTA. Is there any advantage in using the TC4 shock mounts and chassis braces, I already have them in carbon???? If I do this do I have a TC3.4 LOL!!!
I have no difficulty balancing my TC3 or TC4 side to side, is there an ideal front/rear weight, right now both TC3 and 4 are 48% front and 52% rear.
The TC4 shock towers and braces switch the inner camber link mounts to the newer vertical style. It makes tuning easier and gives several more roll center options versus the horizontal shock tower mounts.
Balance wise if you're at 48 front and 52 rear you're doing pretty good. The right rear is the heavy spot, and to get that offset and evened out is the trick.
--Ermer Racing Inc.--
IDC Precision Machining (www.idcwi.com)--Trackside Raceway (www.trackside.com)--Hounds Hobbies and RC Track In The Back--
Racer X79 is offline   Reply With Quote
Old 03-15-2014, 06:03 PM   #12482
nascarkeith's Avatar
I've done a lot of reading and got very confused. I need TC4 specific help with traction roll on carpet and carrying more speed through the turns.
In racing if it goes out of bounds it probably ain't coming back.
SouthviewRC.com
nascarkeith is offline   Reply With Quote
Old 03-15-2014, 10:01 PM   #12483
Smile
The whole tc4 thread is dedicated to stopping traction roll, specially the tips on page 832....
bertrandsv87 is offline   Reply With Quote
Old 03-16-2014, 04:46 PM   #12484
Trader Rating: 40 (100%+)
Big thanks everyone Had a great day racing and almost won TC but Had a wheel come off but with quicking thinking Pit crew got the wheel back on with only 2 laps lost
The car is way better and Big thanks to ANR211 and Martin for the Suggestions including adding more droop soooo wild to have the car lean but not roll over
Bert Tried 3mm of washers on the upper and was quite a bit better. Ended up removing a bit from the rear back to 2mm but the car was awesome
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 03-16-2014, 04:46 PM   #12485
Jason Deadman
Old 03-16-2014, 08:05 PM   #12486
Smile
Great Jason !!! Please post your final setup, lots of us will be grateful !!! Thanks....
PS: I use blue loctite on all my wheel nuts after also losing wheels in qualifiers....
Old 03-16-2014, 09:02 PM   #12487
The Wheel nut was my fault. I was widening the front to match the rear and I was interrupted and the left side was let just finger tight
lol it was funny but the one guy who saw my nut fall off started running for the car as my buddy was putting the tire back on finger tight it lasted the rest of the race
I will put my final setup once I clean the car and get it ready for the big race this weekend.
Going to the Minnesota Onroad Champs in Duluth MN. Something close to 175 entries
Jason Deadman
Old 03-17-2014, 08:29 AM   #12488
thanks for your input Jason on your setup, looking forward to seeing your final setup posted here.
Has anyone got any insight on how to tighten up the front end ? I find there is a little too much loose with the front wheels and steering. Are there any stock parts that need to be changed out to improve this?
Note: I am using TC3 cvd's up front and all the rest is stock except for plastic drag link replaced with alu turnbuckle and a kimbourough servo saver.
Saint Hyacinthe RC Circuit
circuitctsh.com
rc-demon is offline   Reply With Quote
Old 03-17-2014, 08:51 AM   #12489
Look at the rack first. Check bearings and shim for play. should be about a thou play up and down check ball studs everywhere any play replace and check the c-hub where it mounts to the arm I use 0.1 mm shims (or e-clips) to take out any play
Jason Deadman
Old 03-17-2014, 09:24 AM   #12490
With cvd's up front, you'll need a ball diff , not a spool, or else everything will rattle endlessly... After that, you can shim everything tight once and for all...
Old 03-17-2014, 10:28 AM   #12491
My Setup on the FTTC4 carbon chassis
Ran great Just with the Slipper front diff setup I'm destroying CVD's like mad
Going back to a tight diff for the big race this weekend
http://my.tbaytel.net/jdeadman/1.pdf
Opps the pdf was too big lol Click the link
Jason Deadman
Old 03-17-2014, 11:04 AM   #12492
The car is a new club racer with only a few days of track use so all the parts are new.
I did break a steering rack and just put a new one this weekend, so it should be tight.
thanks for the tip on the c-hub shim!
circuitctsh.com
Old 03-17-2014, 11:07 AM   #12493
Sorry i am a little new to this, i have to change my front diff if i use TC3 cvd's ? Can you explain?
The play i see is back and forth and a little up and down in the outdrives.
circuitctsh.com
Old 03-17-2014, 11:12 AM   #12494
Due to the High steering angle even the tc4 HD CVD's get blown out easily due to the extreme forces and the light duty Aluminum.
The Solid front axle is really hard on these parts and the only way to make the front end last longer is the use of the Losi Double jointed axles. but those are getting really hard to find
Jason Deadman
Old 03-17-2014, 12:14 PM   #12495
So you would not recommend the TC3 cvd's ? Am i just better to run the aluminium dogbones ? Part #: 31034
I heard of the Losi part, a common part would be better for long term.
circuitctsh.com
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
