Like Tree19Likes
Old 02-19-2014, 06:34 PM   #12436
gooba's Avatar
Ok back on topic. 17.5 guys where do you guys run your body ride height at? Just high enough not to drag or higher to allow some suspension travel before it drags?
gooba is offline   Reply With Quote
Old 02-19-2014, 06:40 PM   #12437
I always run the body so the suspension can compress before it hits the ground.
frozenpod is offline   Reply With Quote
Old 02-19-2014, 07:26 PM   #12438
If you run a Mazda speed6 like I do, you'll have to put your top body pin on the 9th hole(rear), and on the second hole(front) to be legal... Then, you can trim the skirt so the body won't drag too much...
bertrandsv87 is online now   Reply With Quote
Old 02-23-2014, 04:48 PM   #12439
Farticus's Avatar
Some of the previous posts in this thread suggested replacing the front cvds with LOSA3344 lcds. Unfortunately, this part number doesn't seem to be available anymore. Are there any other suitable replacements or a source for the 3344s?
Beachline Raceway
Associated B44.3
X-Factory SCX60 CF
Schumacher Cougar SV2
Farticus is offline   Reply With Quote
Old 02-24-2014, 04:01 PM   #12440
gooba's Avatar
As a simple bolt in affair no. modifying your car and other brands of dcj drives may be possible but not alot is known about which ones and what mods are needed to make them work
Old 02-24-2014, 07:36 PM   #12441
MD
MD's Avatar
Trader Rating: 106 (100%+)
I have a TC4 Club Racer with front and rear regular diffs.I am looking for a good vta setup for low grip carpet.
MD is online now   Reply With Quote
Old 02-28-2014, 04:01 PM   #12442
Racer X79's Avatar
Trader Rating: 30 (100%+)
Here's my new TC4 project. I got tired of dremeling so I made up a quick fixture to throw the chassis in an old bridgeport mill. The sides, center, and rear bulkhead are cut down. I removed the webbing on both sides of the front and rear. I also added a 3/16 slot straight through the bottom down the center wall. I'm curious to see how it will react, I can already tell the mods added quite a bit of flex.
--Ermer Racing Inc.--
IDC Precision Machining (www.idcwi.com)--Trackside Raceway (www.trackside.com)--Hounds Hobbies and RC Track In The Back--
Racer X79 is offline   Reply With Quote
Old 03-02-2014, 02:23 PM   #12443
gooba's Avatar
@racer x. What did that take your weight down to? my unmolested carbon car is already underweight for my local tracks. Almost 50 grams for one. And im over 200 grams under vta weight thats a lot of lead to add to a car. And thats carbon tub not carbon fiber
Old 03-02-2014, 07:34 PM   #12444
Racer X79's Avatar
I weighed it before and after and it took out around 16 grams. I wasn't too worried about reducing weight, my goal is to improve the flex. Also, with the webbing removed it adds more room for weight if needed.
Old 03-07-2014, 05:06 PM   #12445
blwaz23's Avatar
What should I run for the gear and pinion on a TC4 with a 6.5 motor on asphalt?
blwaz23 is offline   Reply With Quote
Old 03-07-2014, 08:55 PM   #12446
6.5t with boost , start with 7.5fdr (72t/24t pinion)........
No boost 6.5t, start around 6.66 FDR (72t/27t pinion).....
Old 03-09-2014, 12:21 PM   #12447
jeffyrc's Avatar
So after looking threw the last 20 pages could really find the answer I was looking for. I have a tekin gen2 17.5, whats a good starting point for pinion/spur combo? Going to run my esc in blinky.
RC8 B3e - B5mFL - B5rm - RC10 Worlds rere - FT B4.2 (dirt oval) - FT SC10B.2 - JConcepts BJ4 (stick pack chassis)
jeffyrc is offline   Reply With Quote
Old 03-09-2014, 12:34 PM   #12448
gooba's Avatar
depending on track size you'll want to start with a 4.0 fdr and adjust from there. I believe my car runs 60spur 38pinion which nets a fdr of 3.94. You can also run a 55t spur and drop a few pinion teeth. robinson racing is the gears i use
Old 03-09-2014, 12:43 PM   #12449
jeffyrc's Avatar
Nice, is that 48 or 64 pitch?
Old 03-09-2014, 12:54 PM   #12450
gooba's Avatar
48pitch.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
