Like Tree26Likes
Old 01-24-2014, 06:16 PM   #12391
gooba's Avatar
@Darth I noticed this on my club racer also. I looked at every possible thing i could think of and found nothing. I dropped it by my LHS ad they said my screws were too tight. So i took and started to back them off till 1/4 turn at a time and about 2 turns from tight it went away. Ive run it several time since with no ill effects and no screws falling out. Also I bought every carbon part AE still has for the tc4(chassis,arms,"wings",caster blocks,hubs, carbon fiber front tower,carbon front tower mount and a FT screw kit) and with castle mamba max pro,turnigy shorty lipo, a servo thats soon to be replaced(too slow) and a killshot my TUB chassis is down to 1355g rtr minus transponder
gooba is offline   Reply With Quote
Old 01-24-2014, 06:31 PM   #12392
moparSRT's Avatar
which screws are you packing off 2 full turns from tight ?? Dosent that make your parts move around ??
carbon composite parts are great for weight savings but they are also very stiff compared to the regular composite, I use the shock towers and steering knuckles ... flex is good if your racing
moparSRT is offline   Reply With Quote
Old 01-24-2014, 06:55 PM   #12393
gooba's Avatar
I loosened the 6 screws that hold down the top diff case. They are tightened till i just start to feel resistance so their tight but just so no movement. For 17.5 on carpet i prefer the stiffness of carbon. I personally feel like it makes the suspension work to its full potential and makes a more predictable car
Old 01-24-2014, 07:11 PM   #12394
moparSRT's Avatar
Thats some serious over torquing, yes that will cause binding and striping
I loosened up 2 turns and ended up with this :
not good
Old 01-24-2014, 07:40 PM   #12395
gooba's Avatar
Did the catch go away tho? If it did tighten your screws back till it starts then back of a hair and you should end up just flush
Old 01-24-2014, 07:48 PM   #12396
DarthRacer's Avatar
I actually did try loosening the diff case screws, had the same problem. I may have a wonky gear in there. I'm going to have to pull it apart again to check.
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Old 01-24-2014, 08:19 PM   #12397
gooba's Avatar
Since the Lcds are no more will anything else fix the frontend chatter? I have aluminum cvds on the way but i believe they still chatter. Am I just stuck with it?
Old 01-24-2014, 09:19 PM   #12398
moparSRT's Avatar
I dont have a binding problem, just questioning your advice to back out 2 full turns on a properly tightened screw ... the result is in the pic Your seriously overtorqueing your screws if you can back them out 2 turns and still have the head of the screw flush with the part
Old 01-25-2014, 07:52 AM   #12399
gooba's Avatar
I never told you to back yours off 2 turns i said my car had same issue and it was about 2 turns out to fix it. maybe it was too tight but backing them out fixed my issue
Old 01-25-2014, 08:28 AM   #12400
gooba's Avatar
@mopar. My car may very well have been over tightened and binding I also think I used a longer screw in the rear diff case as i took my car back apart this morning to work on front end chatter and my rear screws are longer than the front. guess thats what happens when you make your own screw kit
Old 01-25-2014, 11:02 AM   #12401
IndyRC_Racer's Avatar
Last night in VTA, I tried running my batts forward. Overall it gave me more steering, but at the expense of making the rear end a bit too loose (off throttle in the center of the corner).
What setup change (other than more rear toe) would people advise to lock down the rear more. I'm looking for general advice and not anything specific to my setup.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 01-25-2014, 01:52 PM   #12402
moparSRT's Avatar
My base carpet set up http://gregrojna.com/trash/2013/tc4%20birds.pdf
Old 01-25-2014, 02:42 PM   #12403
More rear toe gave me less traction than One degree toe.......
bertrandsv87 is offline   Reply With Quote
Old 01-25-2014, 06:06 PM   #12404
moparSRT's Avatar
Things I would try:
Less SXT on front tires
Lower rear camber link on chassis(roll center)
Raise rear arm blocks
Softer rear springs
Wider front hex
Old 01-25-2014, 08:03 PM   #12405
Well, you can try the tamiya dcj's , and ream the tc4 hub carriers from 3/8”(9.525mm) to 10mm.......... Tamiya uses 5x10x3mm Bearings vs 3/16”x3/8”x1/8” ...... The total dcj length needs to be 75 to 76mm, and the pinhole to bearing distance need to be the same as in the tc4 axles...... Good luck........
Also by doing this mod, you will be able to use any dcj with 5mm axles(xray t4 etc...)... It's not really hard to find a straight 10mm reamer at Mcmaster.com part#: 2822A48 , and 5x10x3mm Bearings(AE #91156)....
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
