Like Tree36Likes
Old 01-18-2014, 07:30 PM   #12376
I think there might be other dcj's out there that fit the tc4, but it will be hard to find... Hopefully Losi will make new lcd drives soon.....
bertrandsv87 is offline   Reply With Quote
Old 01-18-2014, 10:26 PM   #12377
rbudano's Avatar
Originally Posted by bertrandsv87 View Post
Well you can checkout post #11514..... There are lots more upgrades but I can't recall where they were posted......
Thank you! That should set me straight for a bit!
rbudano is offline   Reply With Quote
Old 01-19-2014, 05:57 PM   #12378
Smile
No problem..... I found the other upgrades on post # 12073 to 12076 + chassis flex upgrade....
Old 01-22-2014, 05:30 PM   #12379
moparSRT's Avatar
found a great way to add weight for vta where its most needed ... 124g in the center of the chassis, with this setup I only use 1 extra 7g brick to balance the chassis and make wieght ... 1551g
moparSRT is offline   Reply With Quote
Old 01-22-2014, 06:27 PM   #12380
NutDriver's Avatar
Trader Rating: 15 (100%+)
@Mopar,
Is that a Factory Team car without the upper brace?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is online now   Reply With Quote
Old 01-22-2014, 06:52 PM   #12381
moparSRT's Avatar
in the picture yes, but the top plate is now on the car, would not work without it.
Old 01-24-2014, 06:08 AM   #12382
gooba's Avatar
@mopar rough calculation on my part says your car weighs 1420g approx? Am I close? if so whats your setup as that seems heavy for a fttc4?
gooba is offline   Reply With Quote
Old 01-24-2014, 06:21 AM   #12383
moparSRT's Avatar
OOPS ur right Totaly forgot about the 3x7g sandwiched between the motor and battery.
That would make my TC4 1400g RTR in VTA trim.
Old 01-24-2014, 09:33 AM   #12384
IndyRC_Racer's Avatar
To get 1400 grams, how light are your electronics/batt & does that include a driver figure. Are you taping the battery or using a top battery bar.
I've gotten my tub TC4 down to about 1450 without a body - this is with a GTB, full-sized 2s lipo, and a full-sized servo. With a Pegasus Mustang, I'm just over 1550.
I've been thinking about setting up my FTTC4 as a 2nd VTA car, but the last time I set it up I remember it being a bit on the heavy side.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 01-24-2014, 10:12 AM   #12385
moparSRT's Avatar
DS1015 servo
Justock
Spektrum SR3001
Balistic
Reedy 5000 wolfpack
Associated carbon drive shaft
Cut down Associated lexan driver
Cut down diggity lipo brace with TC5 battery strap
Mcallister Trans Am 105g
My TC3 with the same setup weighs 1425g RTR without any weights
Old 01-24-2014, 10:20 AM   #12386
DarthRacer's Avatar
I was going through my newer Club Racer kit the other day and found what seems to be a 'high spot' in my rear drive train. Something with the rear shaft pinion and the diff ring. If I rotate the assembly with my fingers you can feel a spot where it wants to stick. I couldn't find any issues with the diff case, bearings, or the gears. I have an older TC4 that has a smooth drive-train so I'm wondering if there is a break in period?
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Old 01-24-2014, 10:25 AM   #12387
moparSRT's Avatar
how many shims on the diff and under the pinion ??
I think I only have 1 shim on the diff and zero under the pinion
Old 01-24-2014, 10:40 AM   #12388
DarthRacer's Avatar
I have two on the diff, don't remember on the pinion.
I even moved the two diff shims around to see if that would help, didn't seem to.
Old 01-24-2014, 10:57 AM   #12389
moparSRT's Avatar
take a sharpie and mark the pinion and diff gears where they bind, then rotate it a couple times to see which gear is binding on the mark, that will tell you where the problem is.
Old 01-24-2014, 11:13 AM   #12390
DarthRacer's Avatar
Worth a shot. thanks
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
