Like Tree19Likes
Old 01-05-2014, 06:02 PM   #12346
DarthRacer's Avatar
The TC4 isn't discontinued, it lives on as the Club Racer. I think the only change was a front spool that comes stock.
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Old 01-05-2014, 06:10 PM   #12347
Trader Rating: 37 (100%+)
All is well then.
v_squared is offline   Reply With Quote
Old 01-05-2014, 08:59 PM   #12348
Cool
All is well , Bert is swell...lol... Get your tc4, and see you at the track....
bertrandsv87 is offline   Reply With Quote
Old 01-06-2014, 01:13 AM   #12349
AllenCheung's Avatar
Kenshin, I like your avatar.
AllenCheung is offline   Reply With Quote
Old 01-06-2014, 04:44 PM   #12350
I noticed the graphite chassis is only 60 bucks or so. but I can't find the top plate. Do I need the top plate?
lee111m is offline   Reply With Quote
Old 01-06-2014, 04:57 PM   #12351
moparSRT's Avatar
you will need a top plate, motor bulkhead and camber mounts to finish the conversion, most of these parts are long discontinued.
moparSRT is offline   Reply With Quote
Old 01-06-2014, 07:03 PM   #12352
IndyRC_Racer's Avatar
It is possible to create a hybrid between the tub chassis TC4 and FTTC4, but you will have to come up with your own solutions for a few things...
Motor Mount
The FTTC4 motor mount is no longer available. Here a a couple of options.
- Modify the tub chassis TC4 motor mount to work with the FTTC4 chassis. You will need a way to support the bearing in front of the spur gear though.
- Purchase a Diggity Designs DC4 LE motor mount which looks to be a direct replacement for the FTTC4 motor mount (if available). Here is a link - http://www.diggitydesigns.com/Diggit...otorMount.html
Top Deck
- Check Team Associated website for parts as it looks like you can still buy a top deck here - http://www.teamassociated.com/cars_a...s_accessories/
- Some people have modified other cars top decks to work with their TC4's (TC5's or TC6's???). Search this thread as I know there was at least one example.
- Again you can buy a Diggity Designs DC4 LE top deck. They have 3 different thicknesses that look to be available on their website here - http://www.diggitydesigns.com/produc...signs_DC4.html
Camber Mounts
- Good luck on finding the FTTC4 aluminum inner camber link mounts. I don't think anyone makes an aftermarket option.
- You can always use the stock TC4 chassis braces and cut off/modify what you don't need since they have the inner camber link mounts. If you are using a stock FTTC4 top deck you will also need to modify it.
- Remember that the NTC3/TC3/TC4 all use the same diff cases which were designed to use plastic chassis braces. In fact you can update a TC3 with TC4 chassis braces and shock towers to have updated camber links & 4 shock tower locations.
One thing to keep in mind is that you may end up spending a lot to upgrade/modify a stock TC4. Set a budget and price everything out before you buy. It may be more cost effective to purchase a newer designed shaft car like a Tamiya TB-04, which has gear diffs.
However if you read through this thread you will find plenty of suggestions/photos on how to upgrade a TC4 to be competitive in faster classes. If you are just going to be running USVTA or USGT, then a Club Racer TC4 is capable of winning in the hands of a good driver.
Hope this info helps.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 01-06-2014, 07:24 PM   #12353
DarthRacer's Avatar
I love the TC4 and have done some upgrades but you really do need to be realistic about it. Sometimes it is just not worth the time and money to mod.
My top upgrades to a box stock TC4 club racer, in order of my preference and value are:
Front steel universal shafts - front shafts will not survive the spool
VCS2 shock upgrade - shocks are soo unbelievably smooth
Front and rear aluminum hinge pin blocks - so you can make roll center and other adjustments
RPM ball ends
and..... thats it! That is what I put in my car and the value I got for those upgrades was worth their price. Anything else short of just taking a dremel to it to add some flex just isn't worth it IMHO.
Old 01-06-2014, 09:33 PM   #12354
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
if anyone is interested I have a bunch of nip aluminum factory team suspension mounts. pm me if interested.
jeff jenkins is offline   Reply With Quote
Old 01-06-2014, 11:05 PM   #12355
I'm still in the process of reading through the thread but I'm gonna go ahead and post my questions.
I just pulled my TC4 out of the closet after like 5 years. I purchased it back in the day when I had more money than sense and just kind of bashed with it. I bought a Novak GTB 5.5 esc/motor combo that I now realize was a mistake. It is way too much motor for me.
My question is, as I am a relative newb still, can you guys possibly recommend a pinion/spur combination that would help me make the motor more manageable. I know that BL motors have a sweet spot as far as gearing and I'm sure I won't be at that sweet spot but I just need less acceleration I suppose. Basically should I gear up?
I guess my other question is, should I just get a different Novak motor that is compatible with the GTB ESC? I see a SS5800 on ebay. Do you guys think this would be a good replacement?
visuvius is offline   Reply With Quote
Old 01-07-2014, 05:28 AM   #12356
RPM ball ends
Ya, I already have the steel front shafts, I heard the plastic ones instantly shredded, so i replaced then basically right out of the box. And I'm going to try tc6 ball ends. I'll work on the rest later. Thanks for the tips.
Old 01-07-2014, 12:39 PM   #12357
DarthRacer's Avatar
A 5.5 motor is just crazy fast, especially for a shaft drive tub car. I would suggest nothing over a 17.5 or 3800kV.
Old 01-07-2014, 01:13 PM   #12358
Oh trust me I know now. I don't know what I was thinking when I bought it, I just didn't know that much and went for the quickest thing I could find. I guess I"ll put up a WTT to see if anyone has a slower Novak they would trade with me. In the meantime I might just pickup a Sidewinder SV3 setup. Do you think the 4600kv version would be okay?
Old 01-07-2014, 03:18 PM   #12359
DesertRat's Avatar
Why not keep the GTB and get a different motor?
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is online now   Reply With Quote
Old 01-07-2014, 03:51 PM   #12360
NutDriver's Avatar
Trader Rating: 14 (100%+)
Speed Passion has a decent blinky ESC and motor combo for less than the cost of a Novak motor.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
