Like Tree36Likes
Old 12-30-2013, 09:28 AM   #12316
Rick Hohwart's Avatar
Originally Posted by kufman View Post
Have you ever driven one with a mod motor? I am guessing not.
Have you used a brushless mod with one? I know in the days of brushed there was significant torque steer (although It did not seem to hurt results). It is possible that a brushless mod, due to the smaller diameter rotor (compared to larger diameter armature), would produce less torque steer.
The Awesomatix car seems to work well with the brushless modifieds although hey have recently introduced improvements that reduce the effect. But until now it has not seemed to be an issue that makes the car junk.
It would be fun to see how a TC4 with gear diffs and all the latest improvements would stack up with a modified motor.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 12-30-2013, 10:22 AM   #12317
Smile
Making the tc4 chassis more flexible is the key to winning races, but it will require some dremeling and unscrewing a few chassis screws... Torque steer effect will be diminished to the point of extinction then..... Flex = Win !!!!!
bertrandsv87 is offline   Reply With Quote
Old 12-30-2013, 12:15 PM   #12318
kufman's Avatar
Yup, ran mine exclusively with brushless motors. It is more of a chassis twist than actual torque steer. The torque of the motor can compress one side or the other of the suspension and this results in asymmetrical handling. You just have to keep it in mind when you drive one. On power, it will steer better one way and on the brakes it will steer better the other.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 12-30-2013, 12:34 PM   #12319
DesertRat's Avatar
One thing that may be more important is any play in the steering linkage, including flexing of plastic parts. All front wheel and four-wheel drive cars will try to torque steer, just physics say it's got to try. TC4 stock steering components seem to get quite loose after a while... I know mine did. You can get aluminum parts on ebay if it bothers you.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 01-02-2014, 07:35 PM   #12320
Has anyone found a double joint cvd other than the losi one. My track is really tight and I need the extra couple degrees.
lee111m is offline   Reply With Quote
Old 01-03-2014, 11:25 AM   #12321
Smile
The only other dcj is the tc6 Rsd dcj, but you''ll need tc6 hubs, Bearings, etc....
Old 01-03-2014, 11:57 AM   #12322
moparSRT's Avatar
Originally Posted by bertrandsv87 View Post
... you''ll need tc6 hubs, Bearings, etc....
So you actually did this and know it works on a TC4 ??
Or is this more crap from your book of "just sayin"
Dont want anyone buying parts that wont work ...
moparSRT is offline   Reply With Quote
Old 01-03-2014, 12:32 PM   #12323
DesertRat's Avatar
Another possibility that would allow you to use the DCJ for the TC6 would be using the 6x10 bearing from the TC6 in the TC4 steering block, but 3/8 is .375", while 10mm is .393", so it would require some machining to hog out the stocker and make it run.
Then again, you could find a 3/8" x 10mm bearing, I don't know where you could get one, or just use TC6 steering blocks and shim or clearance them to fit in the TC4 caster block / c-hub.
Also, 6mm, the shaft diameter of the TC6 hardware, is only a few thousandths off of being 15/64", which is NOT a common bearing size and a google search found a grand total of ZERO 15/64 x 3/8 bearings, but who knows, it might exist.
Good luck, I hope that helped more than it hurt.
Old 01-03-2014, 03:10 PM   #12324
Smile
Moparsrt, stop trolling Bert!!! Brooks(post#12229) figured it out.....OK...... Do your research from 2014 on !!!! Hopefully Brooks will post a few pictures for you.......lol....
Originally Posted by Brooksracing View Post
Hi Guys
Just wanted to keep you updated on my TC4 build. I purchased a DC4 LE kit last week with optional flex top deck. I intend to build it up with some improved parts to increase performance and ease of maintenance. The car will then be raced in the 13.5T class of the BRCA nationals. A class which the TC4 used to do very well in but has essentially disappeared from to be replaced by more modern cars ( a back step?? Well I think so )
While I wait for the Diggity kit to arrive I have been working on the TC4 FT kit that will provide the base for the new race car. This is a car I have had since new when they first came out and I used to race at the nationals before moving to a sponsored drive with Losi (the dark side I know) then a break from the sport, before returning about 8 months ago.
To the TC4 kit I have converted to TC6 front and rear hubs plus carriers, the rear to allow matching vertical attachments for the camber arms inside and outside.
I have also got together a better quality bearing kit, RSD DCJs (they now fit) and a IRS front light weight spool. I also built up a set of latest TC6.1 dampers with RSD soft bladders, 0 rings and 6 hole pistons. I also plan to use the RSD dual bell crank steering system, floating Lipo attachment kit and a carbon drive shaft from Whip.
With these bits I think it's going to be one truly quick car and I can't wait to try it out on track. I will post build pics, testing reports and set ups as I go.
Many thanks
Tom
Old 01-03-2014, 05:31 PM   #12325
moparSRT's Avatar
Moparsrt, stop trolling Bert!!! Brooks(post#12229) figured it out.....OK..........
Jeff Jenkins figured out how to install a gear diff ... whats your point Bert - Just Sayin - LOL
You have neither of these
Converting to TC6 parts or gear diffs requires machining, not something the average racer wants/can do. So please stop posting crap on how you only need some parts to do the mod.
Old 01-03-2014, 07:14 PM   #12326
Wow........ A few hubs, Bearings, and dcj's won't hurt anybody !!! Stop discouraging newbies, and get your post count above 3000 before addressing me again...lol...
Old 01-03-2014, 07:46 PM   #12327
I have raced 3 FT TC4s from 2005-2011.
I used brushed motors in the early days 8T double and 19T which did have noticeable torque streer and I have raced with 8.5T to 13.5T brushless motors with boost.
I have used a 3.5T motor for practice but never raced with it.
IMO torque steer with brushless motors is a non issue with the FT TC4.
frozenpod is offline   Reply With Quote
Old 01-03-2014, 08:41 PM   #12328
Well the good new's is that I have a 6.1 aswell. So none of it will be a loss. I'll defiantly re-post if it works ... Then it won't be "just saying" HAHA.
Old 01-04-2014, 11:11 AM   #12329
moparSRT's Avatar
Looked into this back when LOSI discontinued the rear hubs ...
TC5/6 rear hubs will work if you drill out the hinge pin holes in the arms to 2.5mm, then you will need to enlarge the slots in the outdrives to fit the blades used with the TC5/6 CVA's, blades are 3.56mm outdrives are 2.51mm.
Front TC5/6 Steering Blocks fit the TC4 Castor blocks so no drilling or mods ... BUT the TC5/6 steering blocks have completely different geometry so you will end up with less steering throw then with TC4 steering blocks, TC5/6 steering setups wont clear the TC4 driveshaft so something custom will be needed to regain the lost steering throw. Same mod for the outdrives as in the rear.
I gave up on it but good luck and post some pics when done
Old 01-04-2014, 11:15 AM   #12330
Maybe i'll just pick up an older used belt drive. I'll have no time to do any of that with school just a few days away.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
