Like Tree18Likes
Old 12-03-2013, 02:31 PM   #12241
IndyRC_Racer's Avatar
Thanks Ray K for the pic/posting the info about your TC4.
I would rather find simple ways to lighten the tub chassis instead of buying/hacking a carbon fiber chassis.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 12-04-2013, 06:25 AM   #12242
Ray k's Avatar
Trader Rating: 46 (98%+)
Originally Posted by kufman View Post
Interesting. Chopped the motor mount down to save weight? With all the weight you added to the motor side, why did you decide to move the ESC to the other side?
Everything I cut was for flex purposes . The shorty pack reduced 100g on the left side ,so adding back the speedo and transponder is needed for overall left/right balance . The add stick on wt.s are to bring the car back to 1450g . those wt.s are more center then right side . A more centered weighted car will reduce weight transfer. The TC4 by design is a hard steering car . Being a stiff chassis designed for foam tire racing .
The original post of my setup starts back on page 797 , a lot of setup questions answered there.
Ray k is offline   Reply With Quote
Old 12-04-2013, 12:20 PM   #12243
Trader Rating: 39 (100%+)
What post number would that be? I run a different # of posts per page than default so I only have 300 or so pages in this thread
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 12-04-2013, 12:27 PM   #12244
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Exotek
Hey guys,
I was wanting to see if you guys wanted to pull together and put together a mass-mailer to Mike from Exotek.
I heard thru the grapevine that Mike was working on one a couple years ago.
With the TC4 winning more and more races and the release of the TC4 Club Spec. maybe we can make this happen with a mass email to Exotek.
What are some items that need to be addressed with the older TC4 platform?
Please feel free to add to the below list.
* A symmetrical chassis with equalized flex.
*3.0 quasi main deck with an adjustable, 7075 spine plate. No top deck. Optional lower decks.
*Lowered shock towers might be nice, but the longer AE shocks would then present a clearance issue.
* A more precise version of the steering rack.
* Gear diff
Exotek has made chassis for the other shaft cars like the Pro4 and the EVO so why not a TC4.....
Please let me know your thoughts....
A battery pack a day keeps the stress away
RED-LINE M03 is offline   Reply With Quote
Old 12-04-2013, 12:35 PM   #12245
Originally Posted by ElliotCanada View Post
Here is my Diggity 3mm Chassis after a date with the dremel. Now 80mm wide. Car being built for CVTA - Canadian Vintage TranAm 21.5 / 1450 Grams.
WOW that's a crazy dremel job...
Old 12-04-2013, 12:40 PM   #12246
Originally Posted by Brooksracing View Post
Hi Guys
Just wanted to keep you updated on my TC4 build. I purchased a DC4 LE kit last week with optional flex top deck. I intend to build it up with some improved parts to increase performance and ease of maintenance. The car will then be raced in the 13.5T class of the BRCA nationals. A class which the TC4 used to do very well in but has essentially disappeared from to be replaced by more modern cars ( a back step?? Well I think so )
While I wait for the Diggity kit to arrive I have been working on the TC4 FT kit that will provide the base for the new race car. This is a car I have had since new when they first came out and I used to race at the nationals before moving to a sponsored drive with Losi (the dark side I know) then a break from the sport, before returning about 8 months ago.
To the TC4 kit I have converted to TC6 front and rear hubs plus carriers, the rear to allow matching vertical attachments for the camber arms inside and outside.
I have also got together a better quality bearing kit, RSD DCJs (they now fit) and a IRS front light weight spool. I also built up a set of latest TC6.1 dampers with RSD soft bladders, 0 rings and 6 hole pistons. I also plan to use the RSD dual bell crank steering system, floating Lipo attachment kit and a carbon drive shaft from Whip.
With these bits I think it's going to be one truly quick car and I can't wait to try it out on track. I will post build pics, testing reports and set ups as I go.
Many thanks
Tom
Tom are the below items a direct fit in a TC4?
RSD DCJs
Old 12-04-2013, 12:45 PM   #12247
Talking
The post number is #11954 Jdeadman... Nice picture too..
bertrandsv87 is offline   Reply With Quote
Old 12-04-2013, 01:14 PM   #12248
Well Red Line, I think diggity design has the tc4 market already, and I doubt they're not already drawing their dc4 v2 already.... As food for thought, I think the new tc4 design should also include:
#1: An anti-torque steer top deck like the A700 evo, and mobile front diff case.......
#2: proper tc4 dcj's...
#3: superthin(80mm) 2mm CF chassis...
#4: independent arm mounts for even more flex....
#5: A mobile Center driveshaft support for mod use, and more toughness in general...
#6: tc4 specific dogbone roller pins to stop outdrive wear.
Basically an Awesomatix Evo with short shocks.....lol....
Old 12-04-2013, 01:57 PM   #12249
DesertRat's Avatar
Probably not enough money in it.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 12-04-2013, 03:04 PM   #12250
Smile
Money never stops perfection !
Old 12-04-2013, 03:55 PM   #12251
DesertRat's Avatar
Just keep thinking that.
Old 12-04-2013, 04:06 PM   #12252
Knowledge is above the bank's Fiat currency ! Unless you own a Losi...ahahah.....
Old 12-04-2013, 04:09 PM   #12253
Got to also test the new protoform mazda 6 GX body too !!! Money won't stop that either...lol....
Old 12-04-2013, 04:25 PM   #12254
You can also loosen all the top deck screws on the Dc4 le until you get lots of flex , and race it that way.... The Car will be much better for sure, and it won't cost a dime..lol...
Old 12-04-2013, 05:31 PM   #12255
Your probably right...
But I think it's worth a try.
It would only take 5 minutes of everyone's time to send a email to Mike from Exotek. He was working on a tc4 chassis two years ago so he already has some data on the car. Plus AE released the tc4 club spec so there are a lot more new owners in the current market place racing this car. Yes a lot of the cars are racing in the VTA class but there are some pretty competitive people racing VTA that may want an upgraded chassis and parts.
Just saying it wouldn't hurt to email Mike what's the worst that he could say is no...
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
