Old 11-30-2013, 10:10 PM   #12226
I think in the Fttc4 , there are lots of screws on the top deck you can back off a bit to get flex... The Ray brace cutouts work on the tub tc4 , and the remaining screws can also be loosened a bit...
bertrandsv87 is offline   Reply With Quote
Old 12-01-2013, 11:53 AM   #12227
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
Hi guys, I am from Brazil.
Looking for a TC4 in good conditions, paypal payment.
Got a baby coming next year and want to reduce drastically my costs with rc and I think a TC4 with a 13.5 or 17.5 is what I need now.
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 12-02-2013, 09:58 AM   #12228
I just finished backing off a whole lot of screws out of my tc4's, and boy did I get alot of chassis flex !!! My cars were way too stiff with the screws tightened all the way... A few turns back, and voila: FLEX !!! I did take out the same part of all the braces that Ray cut out, but only in my 17.5t tub car... I got even more flex !!! I hope to be able to test soon, but it looks very promising !!!
Old 12-02-2013, 11:23 AM   #12229
Brooksracing's Avatar
Hi Guys
Just wanted to keep you updated on my TC4 build. I purchased a DC4 LE kit last week with optional flex top deck. I intend to build it up with some improved parts to increase performance and ease of maintenance. The car will then be raced in the 13.5T class of the BRCA nationals. A class which the TC4 used to do very well in but has essentially disappeared from to be replaced by more modern cars ( a back step?? Well I think so )
While I wait for the Diggity kit to arrive I have been working on the TC4 FT kit that will provide the base for the new race car. This is a car I have had since new when they first came out and I used to race at the nationals before moving to a sponsored drive with Losi (the dark side I know) then a break from the sport, before returning about 8 months ago.
To the TC4 kit I have converted to TC6 front and rear hubs plus carriers, the rear to allow matching vertical attachments for the camber arms inside and outside.
I have also got together a better quality bearing kit, RSD DCJs (they now fit) and a IRS front light weight spool. I also built up a set of latest TC6.1 dampers with RSD soft bladders, 0 rings and 6 hole pistons. I also plan to use the RSD dual bell crank steering system, floating Lipo attachment kit and a carbon drive shaft from Whip.
With these bits I think it's going to be one truly quick car and I can't wait to try it out on track. I will post build pics, testing reports and set ups as I go.
Many thanks
Tom
No car as yet!!
Brooksracing is offline   Reply With Quote
Old 12-02-2013, 11:36 AM   #12230
That's a pretty advanced Fttc4 you got there... Lots of tc6 parts, and the Rsd dcj's are an alternative to the losi LCD drives.... Nice !!! Good luck at the Nats......
Old 12-02-2013, 12:50 PM   #12231
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Originally Posted by Brooksracing View Post
Hi Guys
Many thanks
Tom
Very nice Tom...
You may want to look at building a slipper spool with tc5 slipper pads.
This will save your gears in a hard crash.
Also maybe remove the FT bing Aluminum and install the regular plastic arm mounts to save some weight if need, although the DC4 LE tc4 weighs a lot less than a factory tc4.
Sounds like a nice ride can't wait to see some pics.
A battery pack a day keeps the stress away
RED-LINE M03 is offline   Reply With Quote
Old 12-02-2013, 04:25 PM   #12232
Rick Hohwart's Avatar
Default New setup posted to AE website
Ray Klebanow - 2013 Halloween Classic USGT
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 12-02-2013, 04:34 PM   #12233
Thanks guys the input is very much appreciated and any further ideas or tips are very much welcome.
My idea was to build a car to compete at the top level in the UK using a TC4 probably the favourite car I ever raced but continue to evolve its design in the direction associated could have gone if they hadn't swapped to belt drive.
I will definitly post pics of the build and testing as frequently as I can not to mention race results!
Thanks again everyone, great community on here BTW
Tom
No car as yet!!
Old 12-03-2013, 06:05 AM   #12234
Here is my Diggity 3mm Chassis after a date with the dremel. Now 80mm wide. Car being built for CVTA - Canadian Vintage TranAm 21.5 / 1450 Grams.
Number 49 Lou's Speedway Canada, Honda House www.hondahouse.com
ElliotCanada is offline   Reply With Quote
Old 12-03-2013, 08:18 AM   #12235
Trader Rating: 39 (100%+)
How is the flex? That is one big hole from the motor area.
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 12-03-2013, 08:36 AM   #12236
Smile
It's a big hole indeed, but the way Elliot cut this chassis down to 80mm was the way the chassis needed to be cut from diggity design in the first place, minus the big hole of course... I think it's the thinnest chassis out there, and diggity design should consider cutting their next chassis the same, but without the hole....lol..... I guess my 70mm design was a bit extreme, but 80mm is good enough...lol... Good Job Elliot, and with such a stiff 3mm chassis, the big hole won't mess it up too much...
Old 12-03-2013, 08:57 AM   #12237
kufman's Avatar
Originally Posted by Rick Hohwart View Post
Interesting, the battery and the ESC are on the same side. Must run a shorty pack towards the back of the car?
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 12-03-2013, 09:06 AM   #12238
Smile
You can always try Red line's layout on post #12223....
Originally Posted by RED-LINE M03 View Post
The TC4 picture I posted a couple pages back is the Orange body car sitting in the TQ #1 spot.
The car in position #2 is a $700 Awsomactic and all the other cars are Xray T4 2014, 2013, TC6.1WC ect...
I would say this car is pretty dialed in....!!!
It's nice to see folks stick to the older cars and not buying the next flavor of the month touring car.
http://youtu.be/JYqmzR-2o9g
Old 12-03-2013, 10:16 AM   #12239
Ray k's Avatar
Trader Rating: 46 (98%+)
Here is a pic of my layout .
Ray k is offline   Reply With Quote
Old 12-03-2013, 11:03 AM   #12240
kufman's Avatar
Interesting. Chopped the motor mount down to save weight? With all the weight you added to the motor side, why did you decide to move the ESC to the other side?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
