Like Tree19Likes
Old 11-13-2013, 03:38 PM   #12106
I also ran 3.65FDR with a 12.3mm rotor, so now with the 12.5mm rotor, CF shaft, and lighter battery pack(Tp2700 35C 168grams), I will take my chances at 3.4375FDR.... Wish me luck !!!.... My car weighs 1422grams now. Close enough to the 1380g limit..... Happy racing...
Also, for the first time ever my 13.5t FTtc4 got under the weight limit at 1373grams, so of course I am gearing up to 3.94FDR ....lol..... We'll see what that does too !!!
bertrandsv87 is offline   Reply With Quote
Old 11-13-2013, 04:07 PM   #12107
DesertRat's Avatar
Originally Posted by bertrandsv87 View Post
3.75FDR did not yield any heat in my tc4 the last time I ran it , so I am gearing up baby..... Don't hate, and don't take my advice if you don't want to, but the yokomo boys are killing every undergearer out there, so I'll join the overgearer crew and burn some motors too.....lol... I will report back my findings for sure.....
It is dangerous to recommend someone gear any car gear it up to 3.4:1 or even higher without knowing exactly what they are running and how.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 11-13-2013, 04:38 PM   #12108
No heat + no top speed = gear up ! .....just sayin....
Old 11-13-2013, 05:13 PM   #12109
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Anyone know what this part will do on a tc4.
I guess it will let you move your motor closer to the center but I could be wrong.
http://www.tqrcracing.com/shop/produ....asp?p_id=1817
Thanks,
E.
A battery pack a day keeps the stress away
RED-LINE M03 is offline   Reply With Quote
Old 11-13-2013, 05:19 PM   #12110
If you can get it to fit, sure....
Old 11-13-2013, 05:21 PM   #12111
moparSRT's Avatar
Thanks,
E.
it should, I use washers/spacers, 4mm is about the max you can get before you run out of shaft to mount the pinnion.
moparSRT is offline   Reply With Quote
Old 11-13-2013, 08:48 PM   #12112
Thumbs up
Had the TC4 with the Diggity Chassis out to Lou's Speedway near London Ontario for initial runs. I managed to set a New Track 8 Minute CVTA Record - Canadian 21.5 Vintage TransAm 1450 Grams - which previously was held by VBC Team Driver and Roar National Champion Dave Johnson's prototype Ghost VBC during the Fall Fiasco a few weeks ago. I was using the Stock TC4 Arms but added Yokomo Shocks with 350 Oil, Yellow Front Springs and Blue Rear Springs. I was geared at 82 Spur with a 56 Pinion. I also ran an Eric Wippler Carbon Shaft. I used a Protoform Javelin Body. I ran 4mm Droop front and rear, no sway bars. Stock Composite CVDs front and rear. Also 6 Degree Caster Blocks.
More performance to come.
Number 49 Lou's Speedway Canada, Honda House www.hondahouse.com
ElliotCanada is offline   Reply With Quote
Old 11-13-2013, 08:48 PM   #12113
i would like to see
gear diff
dcj's
& maybe a chassis that will accept lipos & brushless
tc4.1
starrx is offline   Reply With Quote
Old 11-13-2013, 08:55 PM   #12114
Emaculant's Avatar
Sweeet! Any pics?
Emaculant is offline   Reply With Quote
Old 11-14-2013, 02:40 AM   #12115
That's awesome Elliot first run with the car and broke the record......!!!
Which version DC4 chassis are you using?
Standard, flex or hard?
Did you cut the chassis down yet?
Nice carpet track
Results:
http://www.jlaprm.com/PC/LOUSPEED/11...VTA%2021.5.HTM
Can you post some pictures of you car if you have time.
Old 11-14-2013, 04:50 AM   #12116
I ran the standard chassis plate which I trimmed. I'll post pictures this weekend. I'll be adding LOSI LCD shafts for next week.
I ran a standard tub chassis with Xray Shocks for a few races in CVTA when the Club Racer first came out and won the 3 A Mains I entered with it. The best lap was within 1/10th of my usual Xray T4 at that time. We were trying to show that you don't have to spend lots to run Canadian Vintage TransAm at Lou's Speedway.
Dave Johnson's VBC Ghost recorded a best lap of 10.8, I ran a best of 10.9 in a qualifier. That's the Best Lap to beat right now. Dave will probably improve that time the next time he is at Lou's so I have some work to do.
The reason I mention Dave is just to point out that Lou's Speedway attracts some very competitive racers. Adam Hutchinson who works at Lou's won the Vintage TransAm at the US Indoor Champs in Cleveland a couple of years ago. I just wanted to use this information as a baseline for the performance potential of the TC4.
Old 11-14-2013, 09:09 AM   #12117
DesertRat's Avatar
Are you a bot or something? Stop trying to get people to burn their cars down. You KNOW this gearing story is massively aggressive and you still spam it like a Nigerian prince scam artist.
Old 11-14-2013, 10:02 AM   #12118
Smile
Nice work Elliot !!!! You will get faster, and don't be scared to gear up, and lower your droop to 2mm or less.....lol....
Old 11-14-2013, 10:45 AM   #12119
My next upgrade....
Has anyone tried this?
TC5 slipper-spool pads and leave out the rings on the front diff. The slipper pads will keep your gears safe.
Let me know.
It's almost VTA time
Old 11-14-2013, 10:49 AM   #12120
moparSRT's Avatar
My next upgrade....
Let me know.
Works great, make sure you have steel outdrives, remove ALL balls from the diff. You will need to lightly sand the spool pads and dont forget to use lock tite on the bolt.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
