Like Tree26Likes
Old 11-10-2013, 09:42 AM   #12061
boudin4evr's Avatar
Trader Rating: 18 (100%+)
i have a couple savox spares they do not last in offroad long! litle slop in them
what linkages are you useing with savox
i dont care for the long plastic drag link
what horn also
i have lots or racers edge clamping ones for savox
http://www.amainhobbies.com/product_...ervo-Horn-Blue
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 11-10-2013, 09:49 AM   #12062
DarthRacer's Avatar
I have been using the stock servo horns and the plastic drag link.
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Old 11-10-2013, 02:32 PM   #12063
boudin4evr's Avatar
i picked up another tub car today
has a 6.5 in it no pinion
what size pinion should I put into it just for fun
Marc Richard
Old 11-10-2013, 02:38 PM   #12064
A 25t pinion with the stock 72t spur should be fine with a 6.5t motor....
bertrandsv87 is offline   Reply With Quote
Old 11-10-2013, 03:15 PM   #12065
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
I'm just curious can the stock plastic TC4 handle a 3.5 motor on asphalt?
Do you have to mod the drivetrain?
How does a shaft car drive with all that power any torque steer?
A battery pack a day keeps the stress away
RED-LINE M03 is offline   Reply With Quote
Old 11-10-2013, 03:34 PM   #12066
boudin4evr's Avatar
this 6.5 should be fun! boosted on tekin rs pro
Marc Richard
Old 11-10-2013, 03:42 PM   #12067
To run a 3.5t, you'll need at least an aluminum spur gear adapter, aluminum input cups, CF or Titanium driveshaft, spool/LCD up front, and aluminum or steel rear diff outdrives.... The other even more important piece is a parma wide bumper+ grinding your axle stubs ....
Old 11-10-2013, 03:47 PM   #12068
DarthRacer's Avatar
Just drop in a set of NTC3 universals F/R and have at it. The stock composite drive shafts won't put up with the power.
You may need to upgrade the diff out-drives to something harder and I would think a front diff would be better to keep the drive-train stress down.
Old 11-10-2013, 03:49 PM   #12069
boudin4evr's Avatar
a buddy of man has a 3.5 and its more than a handfull!
Marc Richard
Old 11-10-2013, 04:08 PM   #12070
moparSRT's Avatar
Originally Posted by bertrandsv87 View Post
To run a 3.5t, you'll need at least an aluminum spur gear adapter, aluminum input cups, CF or Titanium driveshaft....
You dont need any of this, all you need is steel outdrives and cva's
moparSRT is offline   Reply With Quote
Old 11-10-2013, 04:25 PM   #12071
I was watching the fast guys today at our local track run boosted 3.5
I was getting addicted by just watching them run on this huge nice track.
Old 11-10-2013, 04:46 PM   #12072
Nice track for mod racing...
Old 11-10-2013, 05:08 PM   #12073
Smile
I just want to put all the improvements I made in one page or two, so this is part#1:
Off the top of my head, ]there is a list of major improvements possible in the tc4 , from front to rear:
#1 : Parma bumper + ntc3 reinforcements(overkill)
#2 : front hinge pin blocks#31064 and #31065(no shims)
#3 : run Teflon Bearings on axles #6906
#4 : front LCD drives #losa3344
#5 : dremel servo saver bolt for clearance
#6 : dremel steering turnbuckle for clearance
#7 : run black swaybar up front and back
#8 : use RPM ballcups all over
#9 : use lightweight electronics and lipos
#10 : use trf shocks or AE shocks with yokomo bladders
#11 : take the foam out of the driveshaft input cups
#12 : make sure track width is 190mm
#13 : shave axle stubs sticking out
#14 : use IRS aluminum spool & diff outdrives
#15 : dremel battery compartment stubs flat
#16 : dremel chassis under pinion gear
#17 : cut battery foam spacer so it won't rub the driveshaft
#18 : use rear hinge pin blocks#31066 & #31068(no shims)
#19 : make wheelbase close to the shortest possible
#20 : make droop only 1mm to 2mm over rideheight F&R
#21 : use blue front springs and silver tear
#22 : wax/armor all your ride/wheels/body
#23 : Always run 1 to 1.5 rear camber
#24 : make sure you charge up to 8.5volts
#25 : use only AE clamped wheel hexes
That's all I can recall for now....
Old 11-10-2013, 05:10 PM   #12074
part#2 :
VERY GOOD NEWS !!!
THE AE TC4 IS INCLUDED IN THE NEWEST RC CREW CHIEF SOFTWARE UPDATE !!!
YOU CAN ADD THAT TO MY LIST AS #26.....
Old 11-10-2013, 05:15 PM   #12075
Part#3:
No need to answer that one, I just took the Shields off my drivetrain Bearings only(I put Teflon Bearings on the axles), and WOW , what a difference !!!! That should be mandatory in all tc4's and is #27 down my list of upgrades... No tc6.1 or Xray T4 will ever be that free...EVER...lol....
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
