Like Tree59Likes
Old 11-07-2013, 06:20 PM   #12016
Emaculant's Avatar
Originally Posted by bertrandsv87 View Post
Ray's setup is on page 797 , post#11954....
As far as the dc4 le, it's a good carbon fiber kit for those who want a CF chassis... Those who have one are still testing setups, I think... Both are competitive..
Touring cars need a 12.5mm rotor to be competitive. 12.3mm does not cut it....
Thanks! I can't find to much info on any carbon fiber chassis for The TC4 would it be worth it?
Emaculant is offline   Reply With Quote
Old 11-07-2013, 06:22 PM   #12017
Agent's Avatar
Send a message via AIM to Agent Send a message via Yahoo to Agent
Cool thanks! No one has a spare set of team shocks they want to sell do they?
`Carl
HPI: SNRS4, NMT | AE: T2, Rival MT, Pro Rally | Thunder Tiger: MT4 GT3 | Arrma: Typhon
WTB: Hitec X4 AC charger
Agent is offline   Reply With Quote
Old 11-07-2013, 06:25 PM   #12018
Suspended
The tc4 CF chassis is pretty rare, and setups are from the Nimh days, so they will differ from lipo setups, which are impossible to get.... It's up to the racer to find a fast lipo setup... Happy racing...
bertrandsv87 is offline   Reply With Quote
Old 11-07-2013, 07:05 PM   #12019
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Look for Brett Sisley... "Dialed"... he dominated when he ran his TC4 tub in 17.5... won the NW regionals with it.. he also owns rcspecialties.com
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 11-08-2013, 12:09 AM   #12020
Trader Rating: 79 (100%+)
PM sent
bullet100 is offline   Reply With Quote
Old 11-08-2013, 07:38 AM   #12021
Ray k's Avatar
Trader Rating: 46 (98%+)
Carpet setup below , for Asphalt - Tamiya blue front spring or AE silver ,shock position next hole up and 2mm front droop.
Additional info not on sheet :
Inside legs of corner braces removed
Outside tub wall between corner braces cut down 3mm
Motor mount cam heat sink removed along with the long "L" section
Steering rack servo saver glued and tight , Servo saver added to servo
5/8" holes drilled one under each diff and two under steering rack
Arms centered front and back
Droop is 1.5mm over ride height ,front and rear
Shocks are SpecR R-1 with 3 hole pistons , front 1mm piston holes and 1.1mm in the rear
Motor is Revtech Killshot, torque model
Ray k is offline   Reply With Quote
Old 11-08-2013, 07:58 AM   #12022
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Thanks for sharing Ray...
Do you have any pictures of the bottom of the chassis?
I wanted to look at the holes that you drilled in the chassis.
Just wondering what effects the below items had on your TC4?
Thanks again
A battery pack a day keeps the stress away
RED-LINE M03 is offline   Reply With Quote
Old 11-08-2013, 08:05 AM   #12023
moparSRT's Avatar
Thanks again
I would guess to add flex, remove weight and to keep crap from building up under the diffs and steering
moparSRT is offline   Reply With Quote
Old 11-08-2013, 08:17 AM   #12024
Yes, I was thinking about the flex part also.
I wasn't thinking about keeping the crap from building up under the diffs and steering rack.
Good input...
Thx
Old 11-08-2013, 08:47 AM   #12025
DarthRacer's Avatar
I find it interesting that you have the softer shock spring on the front instead of the rear. I have the same springs but reversed. Was that done to gain more steering or for another reason? If I had that setup (I run on asphalt/concrete) I'd loose rear traction.
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Old 11-08-2013, 08:47 AM   #12026
Ray k's Avatar
Thanks again
The two holes under the steering rack can be seen in the current picture. the other two holes are centered ,one under each diff. I don't think these holes did much to help performance .
I cut the long part of the motor mount off to increase flex .
I cut the sidewalls down to increase flex .
More flex will increase over traction.
Looking back at the mods , I think leaving the corner braces uncut and cross drilling the center backbone rib with 1/4" holes would possibly work better. Maybe eight or nine holes along the length .
Old 11-08-2013, 09:02 AM   #12027
10-4
I like that shorty layout
Old 11-08-2013, 09:16 AM   #12028
moparSRT's Avatar
I built a TC3 for vta not too long ago with similar ideas, works great, plent of flex.
Old 11-08-2013, 09:22 AM   #12029
Ray k's Avatar
With will worn X-patterns on carpet and 200 cars running over three straight days . Steering get aggressive. My posted setup is to reduce front grip.
My base line spring setup is AE Silver rear and HPI silver fronts .
10-4
The shorty pack thing made my car very competitive with modern touring cars . But outdoor at the Kissimmee track , big battery !!!
Me likely !!!
Old 11-08-2013, 10:39 AM   #12030
Suspended
Smile
I ran my stock tub tc4(no drilling) with a similar to Ray's setup on a pretty slippery carpet track with no traction issues at all... I did remove my swaybars though,and my driving sucked after almost a year off the carpet. Here is the video, I am the white slow car:
Http://m.youtube.com/watch?v=hHsrh8m...ure%3Dyoutu.be
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
trilerian
