Like Tree19Likes
Old 10-30-2004, 12:35 AM   #1186
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
did u sand or polish the pins?>
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 10-30-2004, 01:00 AM   #1187
Default No sanding, no anything, and the pins are the stock AE ...
ones. I have noted the front and rear are different lengths. Both sides rock back and forth on the hinge pin. Not really a problem, right? Some others have had the same issue, but no response yet.
Nightbreed is offline   Reply With Quote
Old 10-30-2004, 01:25 AM   #1188
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Any word on any metal lightened outdrives from AE? Looking at the picture of Baker's car from the worlds, he appears to have silver outdrives.
josh
Speedo is offline   Reply With Quote
Old 10-30-2004, 05:30 AM   #1189
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Nightbreed, I have your problem. Mine isnt that bad. I checked the small screw that holdes on the hinge pin and it was a little loose. I fixed that play by tightening the screw. Then I noticed where the bearings go inside the hub there is play there also. What im gonna do it try a different axle spacer like the blue factory team ones and see what happens.
Paul
Paul_TC4 is offline   Reply With Quote
Old 10-30-2004, 11:56 AM   #1190
Originally posted by Grindog001
anyone else noticed a lot of torque steer? More than a tc3 by far
I once traced what looked and felt like torque steer, in my old TC3, to bad receiver. Every time the motor was under big load the steering servo steered a bit to the right. After I replaced the receiver I never noticed torque steer again in the car.
andsetinn is offline   Reply With Quote
Old 10-30-2004, 04:23 PM   #1191
AMGRacer's Avatar
Gave the TC4 a tough test last night. Ran a 4 hour endurance race with it. Teams of 4, 2 x 30 minutes stints each. The TC4 had me and a team mate driving it so it did 1/2 the race distance. We won on 915 laps. Thererfore the car did 450+ laps and in doing so set the fastest lap of the night (from what I understand). We did not set the car up, it was box stock with no setup changes except 42 front and 40 rear foam tires and gearing to suit a 540 Johnson motor. The car was on rails and I only had 1 practice pack before the race and could run as fast or faster than guys who had their cars dialled for the circuit and run the 540 class regularly (I only run mod and have only raced electric at 6 race meets so far, its normally gas for me )
So all in all as for a totally stock car I am very happy with it so far.
For the guys getting the slop in their cars ours has some as well and it handled great. Had tons of steering and drove absolutely straight on power.
AMGRacer is offline   Reply With Quote
Old 10-30-2004, 07:17 PM   #1192
PIIHB!'s Avatar
Raced the TC4 for the first time tonight. I qualified 2nd and won. I was scared to death to hit anything because I couldn't track down any front arms. I love this car.
~Team Wrecking Ball~
**Tamiya TA07 Pro**Gens ACE**Hobbywing**
PIIHB! is offline   Reply With Quote
Old 10-30-2004, 07:48 PM   #1193
dr_hfuhuhurr's Avatar
Trader Rating: 71 (100%+)
Anyone have a pdf setup sheet yet?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is online now   Reply With Quote
Old 10-30-2004, 07:52 PM   #1194
Moderator
Speedo's Avatar
I think Tony has one on his site.
Old 10-30-2004, 08:23 PM   #1195
JimmyMac's Avatar
Ran the car for the first time on asphalt today. I used TC3 4° caster blocks up front. But I also had to use the TC3 outter hinge pins since the TC4 hinge pins were too big for the TC3 caster blocks. I also flipped the Front (rear) suspension block with the Rear (front) block to get less rear toe since I/we don't have the optional rear blocks yet. It was basically the same setup I used on my TC3.5. I would say the TC4 is just as fast.. if not faster than my TC3.5 from 2 weeks ago. The TC4 is a very nice car. Just can't wait til all the optional parts are available so I can tune it right.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 10-30-2004, 09:12 PM   #1196
diskostew's Avatar
Send a message via Yahoo to diskostew
Well my TC4 handels great stock... but in a really tight track the car handles a little lazy. I just picked up the complete graphite set from my local track... hopefully that will help a ton! my track also had the 4 degrees caster blocks in stock (plastic) so i am going to give those a try also. I also picked up the FT blocks and everybody at my track said go to the 2.0 rear block because the car has way too much toe out of the box... the only thing my track didn't have was sway bars.... they said they should be in next week I will put the car together and practice with it next week and let you guys know... but so far this car major @$$!!!!
diskostew is offline   Reply With Quote
Old 10-30-2004, 09:24 PM   #1197
Default World Championship
Well the TC4 and the Team Associated had a terrible showing at the Worlds. Don't know the reasons. TRF415 driven by Marc Rheinard won it all with 2 A-Main wins out of 3. I own that car and it is really nice. I just got the TC4 and will build it this weekend and from what I read and see it will be a great car.
I would have liked and expected to see Barry Baker win with the TC4 as he should have had it all in 2002. Really not many US drivers made the finals. Only TC4 was 5th with Juho Levanen from Finland driving that.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 10-30-2004, 09:31 PM   #1198
Send a message via AIM to T-Money86mcss
I disagree 190, 5th for a brand new car is not a bad showing at all, beat out the losi guys who are always dealing with a new design anyway. There were also a lot of guys further back in the field that had good runs, the winner of the A-main is not the only thing to be looked at.
T-Money86mcss is offline   Reply With Quote
Old 10-30-2004, 11:01 PM   #1199
Jsaves's Avatar
Default Billy Easton?
I thought Billy Easton quit Associated to go to college.
Now he is driving for Yokomo, what gives?
He did well at the worlds, but to bad it was not a TC4.
Jsaves is offline   Reply With Quote
Old 10-31-2004, 06:41 AM   #1200
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
someone buy my TC4 from me...
check forsale thread....
I just love my XXXS too much to drive this.
OUT
Keith Billanti is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
