Like Tree38Likes
Old 10-19-2013, 09:17 PM   #11896
Nice Indy !!! That's what I would like to see more often: the tc4 in the winner's circle in VTA, stock, and Mod......
bertrandsv87 is offline   Reply With Quote
Old 10-21-2013, 06:00 PM   #11897
Winter Racing time guys !!! I can't wait to race next week ! Lowest roll centers(4mm shims under inner camber links) seems to be the ticket..... Happy Racing folks...
Old 10-22-2013, 11:04 AM   #11898
Smile
Anybody else use 4mm or more under the inner camber link, and no shims under the arm mounts ???
Old 10-22-2013, 11:07 AM   #11899
DarthRacer's Avatar
Mine is the other way around. Outer links are higher than the inner. Xray's setup sheets say they recommend it that way. My club racer came out of the box like that too.
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Old 10-22-2013, 11:17 AM   #11900
Trader Rating: 40 (100%+)
I run 3mm no shims (I got a co worker to mill 1 mm off of the arm mounts)
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 10-22-2013, 10:26 PM   #11901
Jdeadman, you are running an ultra low roll Center with a mm Off the arm mounts !!! That's what it is all about ! The traction must be insane..lol...
Darth, forget the Xray book !!! If your arm mounts are not on the chassis, and your camber links flat or slightly higher on the chassis side when your Car is at rest, then your roll Center is too high and can cause lots of traction roll, poor traction(sliding around),etc...
Old 10-22-2013, 10:32 PM   #11902
I milled my Ntc3 arm mounts and it worked great, but milling the tc4 mounts is truly a superb way to get the Car's full potential...... Associated should take notes !!!! LoL !!!!
Old 10-23-2013, 05:51 AM   #11903
lol not too bad in the traction but such a tight track I didn't want the car flopping about.
Stays flat and consistent. and depending on the traction level I only change the upper camber link shims
Jason Deadman
Old 10-23-2013, 06:04 AM   #11904
jeff jenkins's Avatar
Trader Rating: 76 (100%+)
weird as lowering the roll center via arm mounts will make the car roll more
Maclan Racing Products-RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
Old 10-23-2013, 08:17 AM   #11905
That's right, it will roll more, but with the correct spring and low droop(<1mm) the whole Car will squat down close to the carpet(2mm), lowering the CG and avoiding traction roll.... Alot of racers confuse ”roll” with ”traction roll” !!! They need to do their homework !!!
Old 10-23-2013, 06:06 PM   #11906
DarthRacer's Avatar
I use the FT aluminum blocks in the rear and I have one small shim under the front block for rear anti-squat. My rear camber links are lower on the chassis side, so my roll center is as far down as it will go. Once you set droop and ride height properly you have as much traction the little TC4 chassis can give you.
Old 10-23-2013, 07:34 PM   #11907
How many shims under the chassis side camber link is what seems to make a difference.... Four shims vs two(manual setup) seem to Work better, and makes the link parallel to the ground .... There is always jdeadman's arm mount milling solution to get more traction out of the tc4 chassis !!! Let's hope I get a few trophies with that mod.....Happy Racing...
Old 10-24-2013, 05:30 AM   #11908
bertottius's Avatar
Trader Rating: 19 (100%+)
I got positive results from the camber link shims too. What is this milling mod you speak of?
CHRIS BERTOTTI
Alpha Pace Racing
bertottius is offline   Reply With Quote
Old 10-24-2013, 06:01 AM   #11909
Taking the Lower arm mounts (Aluminum) and taking .5 to 1mm off the bottom. Only Issues is it really limits your droop. Not totally bad as I only run about 2-3 above ride height but all I can get is about 4 total with the milled shims.
You can sand the plastic ones and I did it to begin with but with these cars a few thousands off makes a difference in handling.
Now a Caution. this change does make the car want to suddenly loose traction. it seldom does but when it does it's hard to recover from. just fyi
Jason Deadman
Old 10-24-2013, 08:25 AM   #11910
bertottius's Avatar
Ohh ok. Thanks
CHRIS BERTOTTI
Alpha Pace Racing
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
