Like Tree26Likes
Old 10-11-2013, 10:53 AM   #11836
I also forgot to add:
17) throttle expo probably not advanced
18) throttle trim not advanced(increases corner speed)
19) throttle acceleration not advanced
20) esc minimum drive not advanced
.........after tweakin these twenty steps, you should be able to knockoff at least 1.5seconds per lap...just sayin....
bertrandsv87 is offline   Reply With Quote
Old 10-11-2013, 11:33 AM   #11837
bertottius's Avatar
Trader Rating: 18 (100%+)
How do you lighten tires?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 10-11-2013, 12:32 PM   #11838
Smile
Well to lighten the Tires, I weigh the new Tires(34+grams) first, and then I spin them on a truer and file Off two to three grams Off the rubber surface... If you want to go further, you can use the Xceed wheel trimmer (#103068) to take some rim material Off but you'll only be able to remove One gram or so that way before you weaken the rim too much, then you balance your Tires.... All in all , I got my Tires down to (30g/31g) for a 12gram total for four Tires.... The carbon fiber shaft saves 7g to 8g close to the Center of the driveshaft rotation, but this saves 12grams away from the Tires' Center of rotation, which should yield better acceleration, brakes, higher battery voltage through the run, etc.... Of course, if this mod is used in combination with other rotational mass reducing mods(Alu spool/diff oudrives/input shafts), you will see lots of improvements in laptimes....
Old 10-11-2013, 12:35 PM   #11839
DarthRacer's Avatar
A lot of work for a TC4, but if you like to tinker............
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Old 10-11-2013, 12:42 PM   #11840
You are right Darth, but I did most of them from 2006 on..... It did not feel like alot.....
Old 10-11-2013, 02:09 PM   #11841
Fastest lap for the pros in stock touring is EA 9.90seconds....
The fastest amateur's lap was 10.13sec...... That's not an amateur !!!! Good luck Evan !!!
Ronald Volker 9.41seconds mod.....
Old 10-11-2013, 03:47 PM   #11842
Better round Desert in RD4..... 26 laps , 11:05sec fast lap, but I think you're underpowered..... Good luck in the mains....
Old 10-14-2013, 05:56 PM   #11843
Hope the dc4 le showed some more improvements in the main....
Old 10-14-2013, 11:42 PM   #11844
DesertRat's Avatar
I think the only real problem the DC4LE has is that the chassis is too wide, but that can be fixed with a bandsaw and sander. I kept dragging the edge of the chassis, but I think it was the bump on the sweeper that was rubbing, not during normal cornering.
I won the C-main, car was really not 'better' but was driveable with dry tires, at least for the first few minutes then I trac-rolled it again, twice. The grip was just too high insane high, hell, it was too high for 1/12 scale. If you tried to run the car normally even an inline-chassis 1/12 car would just roll over. Even with dry tires running after 10 laps they were so sticky if you unbolted it from the car it would just about adhere to the underside of the table!
Hopefully there will be a few changes for less grip next year. I think it makes for better racing to look for grip and handling instead of looking for less and traction roll.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 10-15-2013, 09:16 AM   #11845
What was your setup ???
Old 10-15-2013, 09:35 AM   #11846
I do agree with Desert that the body needs to be thinner... The hole under the motor is too big, and limits how thin you can make the body.... Nevertheless, you can still get the body width down alot, more on the battery side though... I can see 10mm Off the battery side, and 6mm Off the motor side, but I still think setup and shock oil thickness is the key here.... I only use 80wt oil in my tc4's....
Old 10-15-2013, 09:37 AM   #11847
Congrats on winning your main Desert ! Did you feel you had enough power ???
Old 10-15-2013, 09:45 AM   #11848
DarthRacer's Avatar
Holy cow 80wt? What springs do you run and on what type of surface?
Where I run we have a concrete track, surface similar to asphalt, and we are running oil wts from 25 to 35 (AE) and springs from green to blue (AE).
Old 10-15-2013, 09:53 AM   #11849
I run 80wt with full rebound on all surfaces, asphalt/carpet, and it calms my Car down alot... No twitchiness, no darting, no Quick traction roll with low roll centers and blue front springs/ silver rear springs.... I run 80wt in my mini m03 also with great results.... Lighter oil make the Car react too fast. I would rather have a slower reacting Car to gain some consistency, but that's me....
Old 10-15-2013, 09:57 AM   #11850
DarthRacer's Avatar
I think our track is just way too tight for that kind of setup. We need the car to react quickly but be controllable. I tune to get as much steering as I can, then tune to prevent the rear from stepping out. Just on the edge of control.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
