Like Tree36Likes
Old 09-29-2013, 11:30 AM   #11761
Just use the stock ball diff's ...trying to rig gear diff's that are not a drop in fit is a exercise in fultility.
VTA RACER is offline   Reply With Quote
Old 09-29-2013, 04:35 PM   #11762
A tc4 gear diff will be good for the Car's rep, and excellent for future sales....
bertrandsv87 is offline   Reply With Quote
Old 09-29-2013, 05:32 PM   #11763
Stevevanb's Avatar
I've been thinking of getting a tc4 so I've been trolling this thread lately. I run a b44.2 and theres alot of talk about putting Team Durango gear diffs in the 44.2. I'm not sure how the inside of the tc4 diff case compares to the 44.2 case dimensionally, but there is a guy who makes the conversion parts to fit the Dingo diffs in. I clipped this from the B44.2 thread.
$100 AUD + Durango diffs.
http://www.bugleboyracing.com/index.php?productid=20
There was a post in here a few months ago when the gear diff discussion was going that showed how to get it done a little cheaper than using the plug & play bugle boy if you want to do a Google search you'll probably find it.
Edit
I think this is what he linked to...
http://www.petitrc.com/setup/associa...iff/index.html
Toy cars.....
Stevevanb is offline   Reply With Quote
Old 09-30-2013, 12:51 PM   #11764
I need some advice. The track that I am going to use this at has changed the layout and is now a large 1/8 track (Nitro guys). Here is a link---- FYI the track is a little shorter than viewed below by about 15 feet (straight)
http://www.youtube.com/watch?v=RU4QQTJ9H-c
I will go to the track for practice only...not many races there... what a shame....
Due to a long straight away... approx. 200-220 ft. I will need to get the car up to 50mph +/-. I don't want to be rear ended by a nitro car.... Can anyone suggest a motor, gearing. battery combo. I have both 2s and 3S batteries... I would prefer to use a 2S setup if heat is not an issue. I have an extra motor fan that I can install on the motor... I have all kinds of stuff,,, Tekin, Castle, Traxxas.. and would like to use something that I have, but will purchase if necessary... Remember, as there are no races I don't need the latest and greatest... just pretty good... I have a Castle MMP, MMM, RX8, a Veleneon ESC, a Castle 3800KV motor, Tekin 4.5 SCX, a Novak 17.5, and a Traxxxas Veleneon motor.. I think it's a 3500 KV. I just got some great tires.... Top, HPI, Sorex etc... and want to get this thing going.... Thanks in advance....
SouthFloridaApp is offline   Reply With Quote
Old 09-30-2013, 03:35 PM   #11765
Jordan Anderson's Avatar
With a 48pitch 60 tooth spur, what's the biggest pinion you can fit?
Or... What's a good pinion spur combo that'll work with the TC4s motor mount to get a 4.0 FDR?
Same question for 4.2 FDR?
JORDAN // EVAN RC8.2e, B5, B5M, EB48SL, SCT410.3
R/C GEARS , TRUKZ/KARZ , VRC PRO
We're not sponsored, but would recommend:
Team Associated, Tekno, A Main, Action, PM
Futaba, Schelle, Avid, Proline, Lunsford
Jordan Anderson is offline   Reply With Quote
Old 09-30-2013, 03:48 PM   #11766
60/43 is max which will get you 3.49 fdr
with a 55 spur you can go 34-47 pinion which is good for 4.04-2.93 fdr
60/35 = 4.29
60/36 = 4.17
60/37 = 4.05
60/38 = 3.95
Rojna is offline   Reply With Quote
Old 10-01-2013, 08:38 AM   #11767
Ray k's Avatar
Trader Rating: 46 (98%+)
I have a freshly built TC4 forsale if anyone is interested!
Associated TC4
Ray k is offline   Reply With Quote
Old 10-03-2013, 07:54 AM   #11768
khartlauer's Avatar
So I'm new to on-road racing and I bought a club racer TC4 to just get me started at a low cost. I am going to run a 17.5 blinky class with it and I was just wondering if anyone could point me to a general gearing or FDR for 17.5 blinky? Also, what are the advantages or disadvantages of running 64p spurs as opposed to the 48p spurs?
Kyosho Ultima RB6.6 MM
AKA - 702 R/C Raceway - Hartlauer Signs
khartlauer is offline   Reply With Quote
Old 10-03-2013, 08:00 AM   #11769
FDR will be different for every track, I would recomend asking at your local track where you plan on racing, or you could start around 4.2fdr and check your motor temp every couple laps and go from there.
With 64p you have finer fdr changes but strip easier.
Old 10-03-2013, 08:14 AM   #11770
khartlauer's Avatar
so 4.2 FDR? Thanks, thats what I was kinda looking for cause I have no idea where to start with on road gearing. I know 17.5 blinky offroad gearing really well since I run expert mod at the local indoor track with it...but its so different, I couldnt just transfer that knowledge over. also, I know in offroad, us 17.5 blinky guys turn the motor timing up to the max, is that necessary for on road or do you just run stock timing on the can?
Old 10-03-2013, 08:54 AM   #11771
Fdr start should be 3.75fdr, not 4.2fdr, and timing should be at 40 degrees.... I also run a novak motor in my 17.5t tc4, and 4.2fdr start is mainly for belt cars not shaft cars, which can run taller gearing without running hot..... Just make sure your drivetrain is free, and you're good to go....
Old 10-03-2013, 09:55 AM   #11772
DesertRat's Avatar
I would not recommend gearing that high to begin with, especially with an untested motor and endbell timing. Even in cars with great ventilation 4:1 is an aggressive starting gearing.
Also, fans, at least one big one of 25/30mm or two smaller fans.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 10-03-2013, 03:51 PM   #11773
I started at 3.65fdr with my tc4 17.5t and a novak ballistic(12.3mm rotor), with no heat at all after six Minutes, so to me a vulcan(12.5mm rotor) should easily handle 3.75fdr.... If you ask for most racers fdr advice, they will give you what fdr works in their belt cars, not shaft cars, and even when they switch to a shaftdrive, they still keep gearing as if they're still running a beltdrive Car... Old habits die hard !!!
Old 10-03-2013, 04:20 PM   #11774
DesertRat's Avatar
Well, my LRP X12 motor / Novak GTB2 set ran 4.0:1 in my Losi touring car, now it runs 4.0 or so in my shaft car, and it would go nuclear without fans but still gets to 170F with them. It's timed according to manufacturer spec, and the car spins free. If your car runs well at 3.65, thats great, but it's far out of the normal range and recommending it to others with no knowledge of their equipment (you know, besides that it's a Vulcan) or track type...
Start conservative on all settings, then go by lap times and temp.
Old 10-03-2013, 04:25 PM   #11775
I only recommended it to the racer because he runs a novak motor like I do, eventhough I run a novak gtb2 vs his reventon.... Lrp motors do get hotter than novak motors, and should be geared like you suggested....
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
