Like Tree26Likes
Old 09-01-2013, 07:19 AM   #11716
NutDriver's Avatar
Trader Rating: 15 (100%+)
I am seeking opinions. How necessary are sway bars for VTA and/or USGT racing with the TC4?
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is online now   Reply With Quote
Old 09-01-2013, 07:37 AM   #11717
bertottius's Avatar
Trader Rating: 18 (100%+)
Scott
I would say it depends on the track...I run the gold heavy on the front only and nothing in the rear on a really low grip track. I believe others may run on both front and back for carpet or high grip asphalt.
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 09-01-2013, 08:46 AM   #11718
DarthRacer's Avatar
I run the softest bars F/R on my TC4.
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Old 09-01-2013, 04:55 PM   #11719
I also run the softest bar. I tried the other bars and did not like them at all....
bertrandsv87 is offline   Reply With Quote
Old 09-03-2013, 05:23 PM   #11720
mugler's Avatar
Default metric axles for TC4??
Are there any current options to run CVD's on TC4 with metric axles ?
I heard that some hot bodies cvd's may be a fit but info was inconclusive...anyone here knows about this or any other options??
As it stands the standard axles are a big turn-off...can't even place car on a set up system to check for camber/caster/toe/balance etc unless wanna ruin the gauge towers by chamfering the axles holes...on HUDY, I think not, LOL.
SoCal Mini-Z Thread
AUGUST 6th, 2017, RACE REGISTRATION LINK.
FIRST SUNDAY OF THE MONTH MINI-Z TRACK DAY AT
BALDWIN PARK, CA.
NEXT >> July 2nd, 2017.
mugler is offline   Reply With Quote
Old 09-03-2013, 06:23 PM   #11721
metric axles = metric bearings, you would need to find a fit some metric hubs or machine the stock ones.
I use a integy set up on my tc4's, works just fine.
Rojna is offline   Reply With Quote
Old 09-03-2013, 06:39 PM   #11722
mugler's Avatar
I'm surprised R1wurks or any of the other after market CVD makers aren't allover this, standard where axle fits in bearing with metric 4mm threads, would be sweet!
i believe but not sure, that the Hotbodies knuckles & C hubs are meant to be used with their CVD's on TC4s...again info I got inconclusive unfortunately so was fishing to see if someone who knew could verify.
just double checked on the HUDY setup, for sure axle diameter is too large... does not fit.
SoCal Mini-Z Thread
BALDWIN PARK, CA.
Old 09-03-2013, 10:41 PM   #11723
Trader Rating: 76 (100%+)
Mugler, not sure if they are still in production, but Square RC from Japan made 4mm threaded axles for the TC3/4 dogbones.
bullet100 is offline   Reply With Quote
Old 09-03-2013, 11:25 PM   #11724
mugler's Avatar
Thanks for the heads up...I'll do a search to see if anything pops up.
I'm familiar with that brand since back in the day square also made some over the top beautiful mini-z wheels too
SoCal Mini-Z Thread
BALDWIN PARK, CA.
Old 09-08-2013, 05:26 AM   #11725
hesh's Avatar
Originally Posted by scooby61 View Post
Hello every one I'm new to the forum and just getting back to on road
New to the electric thing but the local track is electric only so I just purchased a tc4 club kit and was planning on running a gt spec class
Built it with an lrp 17.5 and a tekin rs esc
This is a rubber tire class and a 2 cell Lipo limit
However I'm having gearing issues the guy at my lhs suggested I use a Robinson racing 64 pitch gearset with 56 t pinion and I think its like a 72 t spur for a rollout around 4.06
This can't be right since the gearset won't even fit in the car
And even with some grinding would leave room to properly set gearmesh
Any help would be appreciated I was hoping to race this Sunday but can't get the car ready
I run 62/72 on mine and have room to go up more using 64p gears...
Team Associated B4.1 WC
Team Associated B44.05-Avid
Team Associated TC3/4
Trinity Spec Truck
Traxxas Spec Slash
hesh is offline   Reply With Quote
Old 09-08-2013, 10:25 AM   #11726
DarthRacer's Avatar
I'm not sure what types of surfaces everyone races on, but my local track is concrete and I race my TC4 in USVTA. I had been looking for more on-power steering. I was running a light swaybar on the front and rear of my car, but after a few setup experiments I discovered that my car rotated through the turns better and gave me the on-power steering I wanted after I took both swaybars off.
Old 09-15-2013, 07:26 PM   #11727
NutDriver's Avatar
Gentlemen,
I'm wondering about rear toe and anti-squat. What do the square, triangle, etc mean? Is the 2.0, etc in reference to rear toe or anti-squat?
Scott
USVTA member #111
Old 09-15-2013, 08:01 PM   #11728
Square, circle, and triangle signs are just there so you can tell the blocks from One another. The 2.0 is probably the rear toe, or it might be the shim #2 that slides under the blocks to raise the roll Center.... In any case, welcome to the tc4 forum........
Old 09-15-2013, 08:04 PM   #11729
I also run my tc4 with the #2 shim under the rear forward arm mount to get some anti squat, and no shims under the rearward arm mount...
Old 09-16-2013, 05:20 AM   #11730
DarthRacer's Avatar
+1
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
