Like Tree19Likes
Old 08-26-2013, 07:31 PM   #11701
60/35 sounds good for a start, just check ur temp every couple laps and go from there.
Rojna is offline   Reply With Quote
Old 08-26-2013, 07:54 PM   #11702
Rodarbal's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to Rodarbal
Originally Posted by trick25 View Post
trying to get gearing for 21.5. im a complete on road newbie. i would like to stay 48p
would the robison racing 55t spur 35t pinion fit in the tc4.
and that would make 3.92 FDR. would that be good on a oudoor track?
im looking for a good starting place and something i could go up a tooth on pinion if need be.
Hi Chris, I was about to reply to your PM on the other forum and was going to tell you to check out the TC4 thread here on RCTech...
This^^^
Even the 3.92 FDR is fine for our layouts (we run on a temporary asphalt track that changes weekly). Recently we've been doing much larger layouts with long straights. Although our infield this past week was relatively tight. You can get away with 3.8 FDR or just a tick lower with cooling fans especially as we start moving into our cooler months. I wouldn't run much extra end-bell timing, if any. Like Rojna said, check your temps!
BTW, Chris, there is NO racing at HT North this weekend (9/1) or the following. Most of us will be running the EOS event in San Antonio on the 8th. That should give you plenty of time to get your car ready for the 15th!
RJ Labrador
On Road: Tamiya & XRay
Off Road: Losi, Mugen & XRay
Rodarbal is offline   Reply With Quote
Old 08-27-2013, 07:02 AM   #11703
trick25's Avatar
Trader Rating: 25 (100%+)
thanks so you guys think i need to go with a 60 spur over the 55 on the 21.5?
im mostly concerned with what will physically fit in the car and allow for adjusment with pinion.
4wd bug-D413, 2wd ST-DEST210R, Blinky bug-22 2.0
Etrug-Tekno ET48.3 4wd SC-SCT410
trick25 is offline   Reply With Quote
Old 08-27-2013, 07:33 AM   #11704
You can get 60/41 which will give you 3.65
YES you need to remove the webing under the pinion on the chassis if you still have it there, real easy with a dremel.
Old 08-27-2013, 07:43 AM   #11705
trick25's Avatar
thats what i was worried about Rojna. Not the dremining but the sliding back and forth room(spur to motor center).
60t it is then on spur.
any setup particualy favored for outdoor asphalt?
thanks again.
Old 08-27-2013, 08:44 AM   #11706
DarthRacer's Avatar
The base setup for the Club Racer kit is good with the exception of using silver rear shock springs.
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Old 08-27-2013, 09:08 AM   #11707
NutDriver's Avatar
Trader Rating: 14 (100%+)
Can someone direct me to the base setup for the Club Racer, or another good starting point for my VTA TC4? (I'm lazy......and at work).
Thanks,
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is online now   Reply With Quote
Old 08-27-2013, 09:19 AM   #11708
IndyRC_Racer's Avatar
Rather than direct link a PDF file...
Here is a link on Team Associated's website for all the manuals related to the TC4. (http://www.teamassociated.com/manuals/TC4/)
The only Club Racer related manual doesn't contain any setup info.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 08-27-2013, 09:28 AM   #11709
Thanks,
Scott
My vta setup, easy to drive http://gregrojna.com/trash/2013/tc4%20birds.pdf
Old 08-27-2013, 09:35 AM   #11710
DarthRacer's Avatar
That looks just about identical to the setup on mine.
Old 08-27-2013, 10:16 AM   #11711
bertottius's Avatar
Trader Rating: 17 (100%+)
Rojna, you have a PM
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 08-27-2013, 10:42 PM   #11712
Talking
Tc4 carbon shafts(no mod necessary) are available now guys... Check the ”carbon shafts for touring Car ” thread....
bertrandsv87 is offline   Reply With Quote
Old 08-29-2013, 12:35 PM   #11713
Hi guys.
Have 2 questions.
1. As I bought used chassi I got from last owner 2 set of wheels. One is I think for indoor and nut easy keep wheel. Other set I think for outdor and i litle wide coz can't put nut, so I removed plastic washer. Its OK?
2. How correct setup front wheel for fast speed.
messir is offline   Reply With Quote
Old 08-29-2013, 12:50 PM   #11714
RedTwilight's Avatar
Newbie here with a couple of questions. I've been a plane and drag car guy for several years now. I'm just getting interested in the on-road RC touring cars now that a track has opened up close by. I just recently purchased a TC4 chassis kit and plan to go with a brushless / li-po setup. I plan to use this mostly for fun on the carpet track at the hobby shop and out in the parking lots.
Is there a more concise thread or write up about modifications and upgrades for this chassis? This thread is just toooooo long to go through at the moment.
I'm mostly just looking for upgrades for durability and better control over all out speed for the moment. I need to get used to driving it first after. Although I won't turn down any performance tips. So any information is greatly welcomed!
Thank you,
Trinity
RedTwilight is offline   Reply With Quote
Old 08-29-2013, 01:59 PM   #11715
bertottius's Avatar
Anybody selling a used DC4?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
