Like Tree26Likes
Old 08-08-2013, 01:40 PM   #11626
bertottius's Avatar
Trader Rating: 18 (100%+)
I didn't even know they made plastic outdrives for the TC4. If you're worried about weight, IRS makes really nice aluminum outdrives and "pin cushion" dog bones.
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 08-08-2013, 01:44 PM   #11627
Steel is heavy but extremely durable... You won't need an Awesomatix with the DC4 LE's potential... I thought you were going to order tge aluminum IRS litedrives instead...Good luck...
bertrandsv87 is offline   Reply With Quote
Old 08-08-2013, 01:44 PM   #11628
Smile
Steel is heavy but extremely durable... You won't need an Awesomatix with the DC4 LE's potential... I thought you were going to order the aluminum IRS litedrives instead...Good luck...
Old 08-08-2013, 03:28 PM   #11629
flibbbledy gibbildy wob
Awesomatix a700l+ffg when it arrives!!
Diggity*Designs Dc4 le #11
Schumacher Mi5
2 Schumacher Mi4 cxl*Schumacher Mi1*HPI Savage XS*Schumacher MENACE 21 Schumacher fusion 21
Captain go slow is offline   Reply With Quote
Old 08-08-2013, 04:06 PM   #11630
Excuse the post!
New drive shafts are on the order list. Along with a parma bumper and some rpm ball cups
and some new shocks preferably associated shocks. Among other things that are on the list. I will get some pictures up when I get a chance. As anal as it is im guessing diggity wont number other chassis they sell. so I might buy a chassis or 2. dependant on the choices which both look good.
Schumacher Mi5
Old 08-08-2013, 04:14 PM   #11631
If your car weighs less than 1400grams, it will be fast...
Old 08-09-2013, 05:42 AM   #11632
AM03GT's Avatar
You can run the plastic outdrives in 17.5 and 13.5.
With a little modding they work great. I run the HD Aluminum CVD Bones up front with a spool and the plastic outdrives in the rear with the plastic dogbones!
Dremel down the cvd bone pins so they are just under the surface of the outdrive diameter when installed. The next part is the "hard" part. depending on your resources you want an aluminum sleeve made to snugly fit over the outdrive. Anyone with a friend that has lathe access can get these made easily or if you look around you may find a stock size of tubing that fits.
mine are .405" O.D. .375" I.D.
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 08-09-2013, 09:48 AM   #11633
This mod is only worth it if you already have the plastic outdrives. If you don't already have them, then buying the aluminum $22 IRS(#2140) litedrives is the best way to deal with the problem once and for all without switching to the heavy steel outdrives, and without worrying about how much power the outdrives can handle...
Old 08-09-2013, 10:06 AM   #11634
bertottius's Avatar
I couldn't agree more. I would also recommend using the IRS dog bones with the pin cushions installed. If you use the standard dog bones with the metal pins they will wear out the aluminum outdrives. If you run 17.5 or VTA, you can use the composite dog bones with the cushions already installed.. Lighter and only $7.50 for a full set.
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
Old 08-09-2013, 10:17 AM   #11635
You're right about the pin cushions, but the amount of time it takes to wear the outdrives is pretty long... I am on still on my first IRS set of outdrives in my mod 3.5t after 5years and they wore down to a point but stopped wearing anymore. It's weird but I can still run them for another two years or so... That's $22 well spent....
Old 08-09-2013, 10:57 AM   #11636
bertottius's Avatar
Wow how about that!! I went through a set without pin cushions using a 25.5. I probably could've went a bit longer but, I'm a bit OCD.
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
Old 08-09-2013, 02:55 PM   #11637
Well nothing lasts forever, and I'm good with that....
Old 08-09-2013, 05:38 PM   #11638
volracer's Avatar
Send a message via ICQ to volracer
Originally Posted by Captain go slow View Post
Excuse the post!
I have the RPM ball cups everywhere on my TC4 except for on the hub carriers and spindles. The RPM ball cups are thicker and would rub on some rims.
volracer is offline   Reply With Quote
Old 08-10-2013, 03:34 AM   #11639
Have you had any issues running sorex pre glued tires?
Schumacher Mi5
Old 08-10-2013, 09:19 AM   #11640
DarthRacer's Avatar
Does anyone run swaybars on their tub chassis TC4? I'm currently running a soft one on the front and rear of mine in USVTA. I'd like to see if others are running them and what type of class and track they run on.
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
