Like Tree38Likes
Old 07-31-2013, 03:37 PM   #11551
Losi no longer makes those driveshafts. Does anyone make double jointed CVD's for the TC4?
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 07-31-2013, 07:01 PM   #11552
You have to search on the net for them, and nobody makes double jointed cvds for the tc4 ! They are easy to find on the net too.....
bertrandsv87 is offline   Reply With Quote
Old 07-31-2013, 07:50 PM   #11553
DesertRat's Avatar
In my limited experience, neither my TC4 nor TC6 feels the strain because of normal joints simply due to my setup running less total steering throw. Both chatter under no load when the steering is at full lock, but it never gets there during the run. It might not be worth it. Unless you want the car to turn an 18" turning circle.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 07-31-2013, 08:06 PM   #11554
Big Midget's Avatar
Trader Rating: 98 (100%+)
I gotta question.
Anyone found smaller diameter wheel nuts for the TC4? Some wheels are hard to use with that big wheel nut.
Dee & Mee Hobbies
Fastlane Raceway-wwwfastlanehobbies.com
Topeka On-Road Racing-Jake's R/C Pro-Am Topeka,Ks
www.ZigPhoto.com,RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 08-01-2013, 02:25 AM   #11555
Hi all.
Have 2 questons.
1. First time run my car with Turnigy TrackStar Waterproof 1/10 Brushless Power System 5200KV/80A and after 10 min motor gointo 83 degree celcium.
Pls reccomend fan for the motor.
2. How much mph I can get from motor Turnigy TrackStar Waterproof 1/10 Brushless Power System 5200KV/80A and 3 Cell lipo?
messir is offline   Reply With Quote
Old 08-01-2013, 06:40 AM   #11556
theproffesor's Avatar
Trader Rating: 56 (100%+)
Well considering your motor will be spinning at over 52000 rpm, I would have to say your mph = more than you or th car for that matter can handle. With that in mind I would say a fan is not needed on a car that is in pieces from hitting, well, anything. But if you really want a fan since your running 3s, get a good 12volt PCU fan and find a way to mount it to you car over the motor wired directly the the +/- on the esc.
If you really want to know estimated speed, calulate your rollout, multiply that by rpm, then do an inche to mile conversion and there you have it. example rollout = 2in per 1 motor rotation 52000 rpm = 104000 inches per minute = 6240000 inches per hour. There are 63360 inches in a mile so that would equal 98.5 mph.
Good luck, I hope you have a back-up car or a lot of spare parts
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 08-01-2013, 06:57 AM   #11557
52000 rpm is nothing for the tc4... It can handle whatever motor you put in it buddy.... With the correct gearing(7.1fdr++) , you can reach 50+mph , but you should never run your Car past the six minute mark... Have fun...
Old 08-01-2013, 07:00 AM   #11558
I also had similar issues with my wheel nuts, but I sanded the outside of the wheel wrench enough so it could fit these wheels...
Old 08-01-2013, 08:49 AM   #11559
Originally Posted by Big Midget View Post
I gotta question.
Have seen 8/32 nuts with 7mm hex on ebay but cant find them now.
I just run a 8/32 tap through metric 4mm wheel nuts.
Rojna is offline   Reply With Quote
Old 08-01-2013, 09:25 AM   #11560
DarthRacer's Avatar
I gotta question.
I started to reverse the nut so the nylon part goes on first. It gives the wrench more surface area to bite on.
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Old 08-01-2013, 10:48 AM   #11561
Why not more than 6 min?
I really look to small fan for RC I think. Not from computer as I not expirienced with handmade.
Also I think it bad cooling anyway in the car as it have body...
Old 08-01-2013, 10:51 AM   #11562
You mean this car too offen will broke? Coz speed or bad quality of parts?
Old 08-01-2013, 12:00 PM   #11563
Six Minutes is the max amount of time allowed to race... If you're bashing, run it until it blows.....
Old 08-01-2013, 12:06 PM   #11564
Big Midget's Avatar
Thanks guys, I'll try to tap some 4mm wheels nuts.
I think thats a good idea!
Dee & Mee Hobbies
Old 08-01-2013, 12:16 PM   #11565
cdwilliams1's Avatar
Trader Rating: 38 (100%+)
What parts are needed to make the tub version into the FT? I suppose you have to buy them individually as I can't find the upgrade kit anywhere.
I race at www.mncarpetoval.com !
cdwilliams1 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
