Like Tree59Likes
Old 03-29-2013, 01:13 PM   #11326
Rodarbal's Avatar
Trader Rating: 38 (100%+)
Send a message via Yahoo to Rodarbal
Awesome! Never thought of lubing the CVDs. We race outdoors on asphalt, which always is dirtier than we anticipate. Not sure if I'd want to put grease there, but I have some thin teflon lube I can try.
For the diff, I also use the translucent AE lube. It's probably at least 18 years old but the ish still works.
For the shocks, I've only recently started using the green slime. My problem is that I forgot it the last two times I've rebuilt shocks. Not that I've REALLY needed it. I've been using the blue o-rings that I had from Ofna. The Traxxas ones might be the same. They feel smoother to me, but provide the same (and maybe better) sealing as the brown AE o-rings. My shock oil inventory is pretty much all AE.
As for the bevel gears, I've been experimenting with graphite dry lube. Previous to that I used a thin application of white lithium grease. Prior to that I used molybdenum grease. I think the graphite is working, though. It feels good, and is more quiet than is has ever been before (running 64P gears now, too). This will make it easier to identify when bearings are going out. You can find the graphite dry lube in the Pinewood Derby Car aisle of your LHS.
RJ Labrador
Off Road Big: Mugen, Mugen & Mugen
Off Road Little: XRay & XRay
Rodarbal is offline   Reply With Quote
Old 03-30-2013, 02:15 PM   #11327
Evilcon666's Avatar
What can I do to get the most out of the stock 17 turn motor? Should i upgrade to a lipo battery, new pinions, gears, etc? Without getting into a brushless motor. What's the most I could do?
Evilcon666 is offline   Reply With Quote
Old 03-30-2013, 05:32 PM   #11328
AM03GT's Avatar
to reduce wear on the diff outdrives you can dremel the CVD pins so they are flush with the outdrive diameter. This reduces wear. also to make the plastic diff outdrives last you can fit an aluminum ring over the end in addition o the dremeled down pins...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 03-30-2013, 05:49 PM   #11329
heretic's Avatar
really ? how come !?
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 03-31-2013, 01:10 AM   #11330
slowclod's Avatar
ran my tc4 on the steet cause i was bored at home. took the brush system out and threw in radiant reaktor (yes thats the brand and thats how its spelled) 3500kv motor and esc combo that i got with by b4.1. took the stupid "drifter" wheels off, threw on some old beater wheels that i got with my tc3 years ago and adjusted the camber back to normal. its fun to run but the whole car needs to be taken apart and cleaned up which i will but like i said i was bored so i didnt care at that moment. i found a wad of hair, yes HAIR stuck between each wheels' hub and hex nut. GROSS!
whats is a good gear combo to really wake up this 3500kv motor. its fast but i want faster!
slowclod is offline   Reply With Quote
Old 04-02-2013, 01:38 PM   #11331
R Doyel's Avatar
I have a TC4 club racer. Can anyone tell me reasonably priced replacement for the shocks? I would put on the TC6 shocks, but they are pretty expensive. Any suggestions would be appreciated.
R Doyel is offline   Reply With Quote
Old 04-02-2013, 01:41 PM   #11332
DarthRacer's Avatar
I bought the VCS2 upgrade for one of my cars. Huge improvement IMO. No more emulsion setup and they have the nice blue caps. An upgrade from there would be to just buy the aluminum shock bodies for the NTC3 / TC3 / TC4 (VCS2).
DarthRacer is offline   Reply With Quote
Old 04-02-2013, 01:42 PM   #11333
What is reasonable?
I put the Tamiya TRF shocks on mine.
$60 for a set of four.
.crispy is offline   Reply With Quote
Old 04-02-2013, 01:48 PM   #11334
bertottius's Avatar
Trader Rating: 19 (100%+)
IRS has awesome shocks for touring cars as well as a bunch of aluminum hop up parts for the TC3 and TC4. Check out their dog bones too...alot better than stock ones.
http://teamirsrc.com/index.php?main_...ird2bsk304dbt5
CHRIS BERTOTTI
Alpha Pace Racing
bertottius is offline   Reply With Quote
Old 04-02-2013, 01:48 PM   #11335
R Doyel's Avatar
Thanks, I'll check those out.
Originally Posted by .crispy View Post
What is reasonable?
That's pretty good. I was considering the VCS3, but they're $50 a pair. I'll look at the Tamiya, as well.
Old 04-02-2013, 07:53 PM   #11336
beemerfan's Avatar
Trader Rating: 34 (100%+)
3 Racing work pretty good for the money. They are a copy of the TRF shocks but at 1/3 the price. The finish is not as nice as Tamiya and I had to fiddle with the spring retainers and ball ends to fit my TC3. But they've been working very well on my car for a couple of seasons with no leaks and they are easy to fill. Spec-R also makes some nice looking shocks in both plastic and aluminum bodies, but I've never tried them.
http://www.tqrcracing.com/shop/produ....asp?p_id=1259
http://www.tqrcracing.com/shop/produ....asp?p_id=5824
http://www.tqrcracing.com/shop/produ....asp?p_id=5825
beemerfan is offline   Reply With Quote
Old 04-02-2013, 10:03 PM   #11337
IndyRC_Racer's Avatar
The Associated plastic TC shocks can be a pain to build (for many people). However when built properly they work well enough. Here is our VTA A-Main from last week. I'm driving the green & white Camaro, which is a tub chassis TC4 with the AE plastic shocks (qualified 2nd - finished 1st)
http://www.youtube.com/watch?v=J5oOg2EbQ94
+ YouTube Video
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 04-03-2013, 06:56 AM   #11338
SS LS1's Avatar
Trader Rating: 23 (100%+)
Just get the Tamiya TRF shocks and be done with it. Think of it as an investment in your racing program like when buying a high end radio our charger as you will have them for years. The shocks will outlast your interest in the TC4 chassis and then you will have them to use on your next chassis someday. I put them on my TC3 and the car was awesome. They were much better than the FT TC3 and TC5 shocks I had run previously on the same car.
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 04-03-2013, 07:16 AM   #11339
Get a used set of XRAY T3/NT1 shocks on eBay.
Serpenteer is offline   Reply With Quote
Old 04-03-2013, 05:56 PM   #11340
heretic's Avatar
+1. Maintenance is critical to get the best out of them, though. That is, clean them and replace the O-rings often.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
