Team Associated TC4
Plastic looks pretty thin, but I'd rather break a $5 rack than a $89 servo. VTA Cuda body got its first major damage too, spent a while last night with some spare lexan patching it up. Not sure what the tension was, as mine was an out of the box club racer and the rack is one thing I hadn't really tampered with yet. Other than a leaky front shock, my car was pretty decent out of the box and most of the basic setup was fairly consistent.
If anyone could help I would greatly appreciate it. I've been working on my brothers ft tc4 vta car. I have the exact same setup as my tc4 Club. His is really loose in the rear. I have tried everything I can think of and nothing seems to help. Got the setup that's posted on here in both. Mine is hooked. Any suggestions?
Tried the tires. Everything rolls smooth. Only difference I can see is the chassis.
How about weight bias? Electronics laid out similar? Battery placement the same?
I have a tub and ft set up the same for vta and they do handle the same
Diff set up the same on both cars?
remove the Blue Stiffner Posts and the Center Spline. then Test Again
Diffs are the same. Spool in front. Ball diff in back. I'll try removing the braces. Thanks
hey jason, what did you run for gearing at mn state champs last year? im trying to get my vta setup for this year so i can really look like an idiot you guys coming down again this year?
Hey Hesh, Yea Hotel is book and we will be there. last year I think I Ran 3.8 FDR I could have gone lower (faster) but I ran out of pinions. I think it was a 80/52. This year I am not doing VTA but Stock Sedan. Still debating on which car to run for that class. I will start with the TC4 but might go back to the Sakura depending on the track layout
What's the difference between the square and triangle hinge pin blocks? I've seen it on here, but can't find it.
Hey guys were can I get carbon fibre version of tc4
Ebay if you're lucky. There's one for sale right now. I saw one close around a month ago for about $160. You could also try and scavenge all the parts needed to assemble one yourself.
http://www.ebay.com/itm/Associated-F...item4ac2afb170
I have multiple TC4s, but came across a barely used tub TC4 at my local track that was a deal too good to pass up. I decided to tear down the car and rebuild it for VTA. I also decided to not use my current setup and start from scratch. My goal was to keep this car fairly basic and only use spare parts I already had.
After a couple weeks racing I've got the car working fairly well. In qualifying last night I had my car competing with a local driver who was in the top 3 in qualifying at the recent FT. Wayne carpet race. I still have a little bit of work to go to get the car better for my local track, but I am happy with it so far.
I should add that I'm running a front diff and AE black plastic shocks.
I do have a question for other people running VTA. Do you like running more or less ackerman on the car?
