Team Associated TC4
Good main run Rojna... That first place guy was very quick...
Vta is really about not crashing....
Hi
i bought a TC4 2 months ago (i think rs) but i need another, if anyone has please shot me a PM!
Thanks!
Thanks!
Torque Steer
I just finished putting together a used TC4 for VTA racing. Runs great and fun I have found that when I am able to full throttle I am having some torque steer to the right. Is this the nature of the TC4 or do I have an issue? I check things over and nothing seems to be loose or worn out. Any ideas???
1) The car is unbalanced left to right
2) There is drag in the drivetain on one side of the car
3) your Chassis is Twisted (we call it tweaked)
4) Your spring pressures are lopsided or your ride height is different from left to right.
5) Steering trim not set correctly
6) Too much toe (in or out) on the front
There are a couple reasons this can happen.
Another thing I see often is people over tighten the upper shock mounts crushing them to the point the shock binds up when compressed. I found this recently when I put another racer's car on my tweak station and could not balance the car. When you compressed the suspension only one side would fully return to ride height while the other side stayed compressed by 1/8". The shock cap was binding up on the upper shock mount and not allowing the spring to fully extend the suspension arm back out.
This will cause a car to keep turning even after returning your steering back to center. Easy check just grab the top of the shock and try to rotate the shock (pivot) on the shock mount bushing. If you can't wiggle it back and forth a little then slightly loosen the shock mount nut and try again.
Not sure on the TC4 but on the TC3 the shocks often are not square (perpendicular) to the arms. Meaning the upper shock mount is not directly above the lower shock mount causing the shock to lean towards the shock Towers. This can cause the shocks and mounts to bind under compression. The fix for this is to space the upper mount out away from the tower until the shocks are directly over the lower mounts. This might require longer shock mount screws to be used.
Finally it may also depend on how your shocks are built, rebound, no rebound, negative rebound, bladders, vented shock caps etc. I have even seen different numbered shock pistons from the left to right shocks which will cause handling problems. The shocks must be built the same left to right for the car to run true.
One thing I have learned about on road racing is you can't just be a good driver to go fast, you must first be a good mechanic! The second thing is you get out of on road racing what you put into it, meaning you spend way more time tuning and maintaining your car than driving it if you want to consistently be fast.
Tajar, if you have a front diff, change it to a spool and make sure your droop is equal left to right....
I'm gonna get the Novak 12.5mm rotor for my 17.5t tc4 rtr . Hopefully it will be a huge improvement over the 12.3mm rotor.....
So anyone Here shear off the Center Driveshaft (Carbon) ? I did last night . Didn't think you could break one but it looks like I had some rubbing on the shaft and that allowed the shaft to snap.
Anyone know where I can get another Carbon Center Shaft?
I now own two TC4s. How did that happen??
17.5 and USVTA hehe. Now I just have to get out and race!
My apologies for not going and looking for it myself, but I saw a post that had a good setup sheet listed for a VTA TC4. Can anyone help?
Scott
Scott
