Team Associated TC4 >
Team Associated TC4
Like Tree298Likes
Team Associated TC4
Old 01-09-2013, 07:00 PM
  #11011
Originally Posted by Mr.juarez
Hello fellow tc4 owners.
I have some questions regarding the tc3 and tc4. A friend of mine gave me his old tc3 so I rebuilt it, cleaned up everything, new bearings and new electronics were dropped in. most likely this will be my vta car. So as I been looking to get some parts and spares I was looking for suggestions.
I bought a set of tc4 arms locally thinking they fit but the hinges fit loose. If I get the tc4 arms, hinges and the tc4 ft allow hinge/arm holder fit?
What are the major difference between them two and will my tc6 axles and dog bones bolt up if I want to swap to them? Was thinking about ordering a set instead of the allow ones and use regular 4mm hexes and wheel nuts.
I posted the above under tc3 as well. Thanks
You can use TC4 arms on a TC3 but you have to use TC4 hinge pins and you have to drill out the TC3 arm mounts for the thicker TC4 hinge pins, you will also need to shorten the TC4 hinge pins. You cant use TC4 arm mounts because they dont fit the TC3 chassis.
TC6 axles will not fit the TC3 or 4. But the NTC3 axles will fit and are a great upgrade
Rojna is offline
Old 01-10-2013, 05:14 AM
  #11012
FL_SilverEvo8's Avatar
Trader Rating: 14 (100%+)
Does anyone know where I could find a 48p spur gear 64t? I want to run close to a 4.00fdr
And a 64t spur gear with a 40t pinion gear would get me right at 4.00fdr.
FL_SilverEvo8 is offline
Old 01-10-2013, 08:36 AM
  #11013
Boomer's Avatar
http://www.stormerhobbies.com/cgi-bi...ns&pn=RRPB2260
Boomer is offline
Old 01-10-2013, 10:38 AM
  #11014
Nobody makes a 64t 48p spur gear... 60t spur gear is the right choice...
bertrandsv87 is offline
  #11015
Hey guys, does anyone still run the graphite ft tc4? I'm gonna be making new graphite shock towers and was wondering if anybody had used them before? If so, what improvements could be made to them for strength, handling, and tuneability if any?
Geotechy18 is offline
Old 01-10-2013, 10:43 AM
  #11016
The graphite shock towers are pretty good . I have not broken One yet.
Old 01-10-2013, 05:25 PM
  #11017
who makes one of them? I seem to only find 66t to be the lowest.
Old 01-10-2013, 05:29 PM
  #11018
nvm found it
Old 01-11-2013, 04:34 PM
  #11019
tajar66's Avatar
Default Servo Recommendation
I just picked up a gently used TC4 roller. I plan on setting it up for VTA club racing. I am looking for some servo recommendations. Any suggestions would be appreciated.
tajar66 is offline
Old 01-11-2013, 04:44 PM
  #11020
DARKSIDE's Avatar
this is what Im using in my TC4 and TC6.1.....
Attached Thumbnails Team Associated TC4-29166_sm.jpg   Team Associated TC4-29167_sm.jpg
DARKSIDE is offline
Old 01-12-2013, 11:36 AM
  #11021
IndyHobbies.com's Avatar
Brian S. and I went to Summit RC Raceway in Fort Wayne, Indiana last night for their Winterfest VTA Race. It was awesome! 4 heats of VTA cars! Anyway, I just wanted to post that Brian took 1st place with his trusty old TC4. Proving once again that the TC4 is an excellent VTA platform!
I run a TC3, and have parts for them. But, if I was starting from scratch, I'd choose a TC4 especially since its been re-released and parts are easy to get.
Attached Thumbnails Team Associated TC4-winterfest2013-003r.jpg   Team Associated TC4-winterfest2013-001r.jpg
IndyHobbies.com is offline
Old 01-12-2013, 04:35 PM
  #11022
The tc4 rules baby !!! Congrats Brian!!!
Old 01-12-2013, 06:08 PM
  #11023
ChrisNRG's Avatar
Nice job Brian!
I'm looking for a new motor for 17.5 tc what would be better to go with?
A RevTech or D3.5 Maxzilla?
ChrisNRG is offline
Old 01-12-2013, 06:46 PM
  #11024
Parnelli's Avatar
Trader Rating: 18 (100%+)
Default New TC4 Team Edition for VTA
Here is my new TC4 chassis (thanks Eric) ready for VTA at the Rumble next weekend. DP
Parnelli is offline
Old 01-12-2013, 06:54 PM
  #11025
DARKSIDE's Avatar
Nice Brian...
DARKSIDE is offline
