Like Tree26Likes
Old 12-27-2012, 06:30 AM   #10966
Default Set Up tips
Just picked up a TC4 to run in a USVTA on asphalt. Any good setups or hop ups recommended. Decided to run this chasis to stay cheap.
rajiex is offline   Reply With Quote
Old 12-27-2012, 06:30 AM   #10967
Default Set Up tips
Just picked up a TC4 to run in a USVTA on asphalt. Any good setups or hop ups recommended. Decided to run this chassis to stay cheap.
Old 12-27-2012, 07:00 AM   #10968
Trader Rating: 40 (100%+)
petitrc.com will be your best bet. lots of good setups I like to run my roll centers as low as possible and long upper camber links for more roll
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 12-27-2012, 12:50 PM   #10969
Checkout post #10888 on page 726 for extra setup tips.
Remove the Shields out of your Bearings, and run Teflon sealed Bearings on your axles.. You'll thank me later....
bertrandsv87 is offline   Reply With Quote
Old 12-27-2012, 12:52 PM   #10970
After all these upgrades, I am anxious to test out my ride against the competition. My local track has not reopened back up yet !!!!! hahaha.....
Old 12-28-2012, 10:51 AM   #10971
Happy new year everybody !!!
Old 01-01-2013, 03:10 PM   #10972
One more month until testing !!!
Old 01-02-2013, 08:04 PM   #10973
Send a message via AIM to Geotechy18 Send a message via Yahoo to Geotechy18
Hey guys, it's been a while since I lasted posted, but have started taking another look at my tc4 to see what I could do to mod/improve it to compete with the tc5s, tc6s, cyclone tcs, etc. I have quite a few ideas, and was thinking about updating it with new part designs that work in the newest competition onroad cars.
As for anybody out there who has frequently gone up against the most competitive cars, what kind of improvements are you guys looking for in the ft tc4 or the tc4 club racer?
Geotechy18 is offline   Reply With Quote
Old 01-02-2013, 09:25 PM   #10974
KC10Chief's Avatar
I run a TC6.1 World's Car. My club, like most of the other clubs in America, doesn't have any professional drivers. I bought the TC6.1 because I could afford it and like most people, was led to believe that it would make me faster. HA! My club is full of people with 6.1s and Xray T4s that totally suck at driving. I am a pretty patient driver. I don't hit the rails and I am never on my lid. Turn marshals never have to touch my car. The past few weeks, I've won every A-main. I rarely turn the fastest lap though. There's guys that can turn a faster lap. They just make more mistakes than I do. I'm consistent. My toughest competitor is a guy with a TC4 Club Racer that he bought used for $100. He's a good driver and makes few mistakes.
KC10Chief is offline   Reply With Quote
Old 01-02-2013, 10:18 PM   #10975
Checkout post# 10888 , page 726 , and read on from there for improvements..... Tc4's are fast when setup properly....
Old 01-03-2013, 07:07 AM   #10976
M3Armand's Avatar
+1M...
I'm still kinda annoyed (but happy I have a new car) that I bought the HB TCX 2 years ago thinking that I would be faster after being out of the "racing scene" for a long time and was still running my old HPI RS4 Pro for 12 years or so. So now that I have both, I also RARELY hit the boards on an 8 minute race and am getting the SAME darn exact times using both cars that are supposedly 15 years apart in technology. This is on an 8 to 10 second lap (depending how good you are) size indoor carpet track in the 17.5 class. I've seen the pros do 8.2 sec fast lap and I've done 8.5 fast lap. Even more disturbing is that since money is no longer the limiting issue for me (vs. compared to 20 years ago, but now the wife is the limiting issue), I've purchased the absolute best 100C+ batteries to see if I can get better times than a cheap 40C battery. Guess what? Again, no difference in time. I do, however, notice a punch difference. In a much, much bigger and possibly tighter track, I can imagine a difference when running outside of 17.5 class.
So again, my limiting factor is the wife. She says I need to get rid of a few cars so that I can get a new TC4. I believe that the shaft drive would be more efficient than the belt and would have a "freer" drivetrain. I'd like to experiment to see if I prefer shaft vs. belt.
Having said that, at the non-pro level, I think a lot of these cars will be the same to us and the improvements are going to come down to, as always, practice practice practice, setup and drive line...
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 01-03-2013, 09:49 AM   #10977
I want a top of the line truck what should I get?
Billy20 is offline   Reply With Quote
Old 01-03-2013, 12:34 PM   #10978
If you take the shields out of the tc4 Bearings, it will be the freest driveline of them all, which means you can gear taller without losing acceleration, no heat and more top speed... You can also reduce the rotational mass of the drivetrain for even more advantage, but remember that you can't gear the same as belt cars that have a lighter drivetrain but with more friction.... In my experience, I always have good results with the tc4 when I gear 0.4 to 0.5fdr higher than belt cars: if they gear at 4.0fdr , I gear my tc4 at 3.6fdr ... I also setup my ride to carry momentum around the corners, no braking.....
Old 01-03-2013, 09:02 PM   #10979
Exclamation
Originally Posted by bertrandsv87 View Post
Sorry darth, but by ”stock foward mount””, I meant the rear inner arm mount, that comes with a height equal to #31066 mount with a #2 shim under it.....
If you also want rear toe in adjustability with low roll centers, you can also get the 3°rear toe in block(#31067), and the 2° rear toe in block(#31069).... Good luck...
SO.....I guess what I'm looking for is....if you follow my interpretation...
Front (Front) arm mount 31064.......or triangle
Front (Rear) arm mount...31065...or circle
Rear (Front) arm mount..31066....or square
Rear (Rear) arm mount 31067 ......or X-3.0
(Optional) (Rear) arm mount 31069.......o X-2.0
I have found a complete set of 64,65,66,X-30...They are also described as
Triangle, circle, Square, X-30. Have I described this correctly for the parts I need to buy to reduce roll center on my TC4.
"NOW" Bearings, I just stripped the black coating from one of the large axle bearing. I am assuming this coating is rubber,It is very thin and and had to be scraped off with an Xacto knife. I'm not sure what the teflon coating looks like, A metal seal I think would be obvious. Below the rubber seal appears to be a pressed in metal seal or retainer for the bearing race????? I guess what I'm looking for is a description of the seal removal process. Thanks.
BE
TJ
THEBIGBULL is offline   Reply With Quote
Old 01-03-2013, 09:29 PM   #10980
Smile
Xacto knife is good to remove the seals... The teflon Bearings(#6906) are just for the axles where you'll need shields because of dirt.... For the other parts, you are correct...
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
