Like Tree19Likes
Old 12-17-2012, 08:09 AM   #10921
rigelkent09's Avatar
Trader Rating: 43 (100%+)
gearing recommendation for vta that will fit in my tc4, i would like to have 3.8 fdr just dont know what combination will fit in..thanks..
rigelkent09 is online now   Reply With Quote
Old 12-17-2012, 08:32 AM   #10922
Conrad, did you run the shortest wheelbase too??? My Car has the 4°blocks and turns a bit too much sometimes with the shortest wheelbase. I have to run 3° camber up front too...
bertrandsv87 is offline   Reply With Quote
Old 12-17-2012, 08:59 AM   #10923
DarthRacer's Avatar
I have a new Club Racer that I am setting up for 17.5 next season.
If I use the 31068 x-2.5 Rear Arm Mount, do I need to buy any additional mounts to be able to use it or will the stock ones work?
DarthRacer is offline   Reply With Quote
Old 12-17-2012, 09:18 AM   #10924
Darth , you need to have roll Center adjustability and the stock ones won't cut it... You need all the arm mounts: #31064 , #31065 ,#31066....
Old 12-17-2012, 09:34 AM   #10925
For example: I run my rtr tc4 with #31064 , #31065 in front and no shims ; stock forward mount(which is like a 0.5mm shimmed #31066) , and rear two degree block with no shims under it.......
Old 12-17-2012, 09:48 AM   #10926
Sorry darth, but by ”stock foward mount””, I meant the rear inner arm mount, that comes with a height equal to #31066 mount with a #2 shim under it.....
If you also want rear toe in adjustability with low roll centers, you can also get the 3°rear toe in block(#31067), and the 2° rear toe in block(#31069).... Good luck...
Old 12-17-2012, 10:10 AM   #10927
DarthRacer's Avatar
Thanks, that's what I was afraid of.
Old 12-17-2012, 05:34 PM   #10928
They are $12 each...
Old 12-17-2012, 05:48 PM   #10929
I meant they are not expensive when you consider that they will enable you to be as fast as the more expensive kits$550+++)...
Old 12-17-2012, 06:50 PM   #10930
DarthRacer's Avatar
LOL no problem. I just have to buy the other 3 now.
Old 12-17-2012, 10:31 PM   #10931
You are right. I don't know why AE didn't make the stock ones as thin as the FT ones but in plastic. It would have saved us alot of money, and saved them alot of hassle with different size molds....
Old 12-17-2012, 11:16 PM   #10932
Thumbs up
AND.....I would find these where????????
THEBIGBULL is offline   Reply With Quote
Old 12-17-2012, 11:24 PM   #10933
Thumbs up
Get a 60 tooth Kimbrough 64 pitch spur. Used for 1/12 scale cars. The ones I have bolt right in place of the the much larger associated spur, no modifications to the chassis or motor mount are required. 60spur/39pinion X 2.5 gearreduction =3.85
TJ
Old 12-18-2012, 07:23 AM   #10934
TJ
thanks for the help THEBIGBULL, i will try that...
Old 12-18-2012, 08:36 AM   #10935
You'll find them at Towerhobbies or google them. They are easy to find on the net, and forget about your LHS...
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
