Like Tree36Likes
Old 11-28-2012, 01:40 AM   #10861
DARKSIDE's Avatar
I used the TC6.1 shocks and RSD springs/bladders/pistons on mine, and are very smooth. I really think they really help with setup
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 11-28-2012, 08:24 AM   #10862
Tc6.1 shocks are also very good, and follow the same principle. Although I don't know why racers want to build them with low to no rebound.....
bertrandsv87 is offline   Reply With Quote
Old 11-28-2012, 08:43 AM   #10863
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
I like no rebound because it adds to the spring - I prefer to separate functions. Shocks are for dampening, springs are for bound/rebound.
Call me crazy!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 11-28-2012, 01:09 PM   #10864
The spring releases much faster than the rebounding damper. The damper takes away(slows down) the spring force, and no rebound takes away more force than rebound, but the idea that the damper adds to the spring is incorrect. Also, if you take away too much force you lose traction. The upgrade necessary here is in the piston valving, which the Rc touring Car world has yet to experience, but for now I like rebound....
Old 11-29-2012, 08:37 AM   #10865
Boomer's Avatar
If you take it to the extreme, it can become clear. I tried an experiment because I wasn't believed.
I took four of my shocks and built them with bladders (so there was no rebound) and one was plumb full (so there was a ton of rebound) - all the same piston, same oil.
With the four bladder shocks, set up so there was no tweak, everything was "perfect" using scales L-R on the front (arbitrary, just to use one end).
I changed one of the shocks from bladder to no-bladder (rebound) and the tweak was off - the rebound side would now rebound faster than the bladder side. Effectively, the spring rate was slightly higher on that side than on the bladder side. Only a few lbs, but enough that it was easy to feel while driving.
However, if you do it so that it's all even on all four corners, then who cares? I could never get it all even on all four corners. . . so using a bladder equalized my inability to get all four shocks exactly the same.
Old 11-29-2012, 11:50 AM   #10866
What I was referring to was an AE shock with bladder/foam and full rebound, Not full rebound and no bladder/foam. With no bladder/foam, the AE shock is of course adding to the spring force, and not dampening at all, if you build it by the AE instructions. My advice is not to build by AE instructions and add the Yokomo bladder/foam, but the shock shaft has to come all the way back out consistantly after every press and release, and there should not be high resistance to press the shaft in the shock body either...
Old 11-29-2012, 12:34 PM   #10867
SS LS1's Avatar
Trader Rating: 23 (100%+)
With that method (each shock shaft must rebound out consistently after every press or release) your setup its very likely to be upset with any minute oil volume loss from any of the shocks. In my experience most shocks have a little leakage that varies differently between each shock throughout a race day. Thus your tweak is suspect to possibly vary from race to race. But if I build shocks with bladders, no foam and no rebound any minute oil loss throughout a couple of race really weekends does not upset the tweak or handling of my car between shock rebuilds. This works best for me maintaining 3 different cars and the amount of time I have available to work on them each week.
SS LS1 is offline   Reply With Quote
Old 11-29-2012, 01:12 PM   #10868
Smile
Very good point SSLS1, but when you consider the improvement from no bladder to bladder/foam, I will risk a little tweak(which is not important to me) to gain some traction. Remember, I run my Car tweaked/unbalanced in the first place: heavier on the motor side by over 140grams.... I also like it that way because I can attack right turns much harder than if my Car was balanced. I do agree that bladder and no foam is best if you want to stay tweak free though, but whatever you do, at least have a bladder in there... It's too bad most newbies ignore that fact, and then label the tc4 as an inferior Car. I would like to see how the other top chassis would handle with no bladder shocks...lol...
Old 11-29-2012, 01:34 PM   #10869
I also want to mention that no rebound slows down responsiveness, and might require stiffer springs, and might not be ideal for short carpet tracks but better suited for big asphalt tracks. Just my opinion though.....
Old 12-01-2012, 07:32 PM   #10870
Any tc4 wins or videos lately ????
Old 12-01-2012, 08:03 PM   #10871
Trader Rating: 40 (100%+)
I am just rebuilding mine for this Winter. My Tubber is going to go to my son (5) for VTA and I am moving my FTTC4 up to Stock TC (17.5 blinky) so trying to get her down to 1380g is going to be tough but she's a great car.
I'll up some vids when we start running
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 12-01-2012, 08:48 PM   #10872
Talking
It will be tough if you use a heavy battery pack: any pack over 220grams will make you overweight. Thunderpower 3300 65C packs are 205g to 208g, and are good to try but the side to side balance will be affected. My Fttc4 is around 1390grams with these packs, but my electronics are heavy. I can loose another 70grams by switching to the tekin Rs/spektrum/Savox 1251 combo but that's too expensive...
Anyway, I have found that it is best to never run AE rubber sealed Bearings on the tc4 axles because of the increase braking effect of rubber while cornering. It is best to run teflon sealed Bearings on the axles or ceramic Bearings....
Old 12-05-2012, 06:04 PM   #10873
What droop settings are you guys using? I use 1.5mm to 2mm over ride height....
Old 12-06-2012, 12:01 AM   #10874
I find that running blue springs in front with silver rear and low roll center is the best balance between roll and responsiveness there is.... All with 1.5mm droop of course...
Old 12-06-2012, 06:36 AM   #10875
JustWill75's Avatar
Send a message via AIM to JustWill75
I just did this last night. I came in fourth in my tracks VTA class. The car was real twitchy in the first half of the race then it would settle down and would become a beast. Do most of use the sway bar kit?
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
