Like Tree19Likes
Old 10-10-2012, 08:33 AM   #10771
Nice to see a tc4 TQ ing !!! Good job nuttynative......
bertrandsv87 is offline   Reply With Quote
Old 10-10-2012, 10:45 AM   #10772
cementsurfer86's Avatar
It's amazing how capable the car is right out of the box, and with a little TLC, can be a contender in classes like VTA.....like mine.
Jesse Anderson / JROY386 / R_
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 10-12-2012, 02:05 PM   #10773
Just got my club racer tonight. Here's what's in the box...
BTW, does anyone know what tooth spur I have stock? It's not the 72 tooth spur I was expecting.
Corners is offline   Reply With Quote
Old 10-12-2012, 02:05 PM   #10774
Double post
Old 10-12-2012, 02:31 PM   #10775
Odd, on the AE site, it calls out a 72t spur.... and I can't remember what my stock gear was, I switched to 64p right away.
Old 10-14-2012, 08:50 AM   #10776
Default TC4 Club Racer - VTA
Looking for a setup for club racer for VTA. Looked on AE website, 2006 was the latest setup and not for the club racer. Run high bite carpet 25.5. Want to build the NTC/TC3 threaded shock kit and replace stock springs. Already put aluminum CVA on as I broke the plastic one the first day. Changed to 64 pitch 3.97 FDR and advanced timing on the ballistic motor. Other that that it is completely stock. Getting better at driving good lines and need to get the car handling a bit better to carry more speed through sharp corners.
Turbo911 is offline   Reply With Quote
Old 10-14-2012, 04:11 PM   #10777
pejota's Avatar
You should be a bit more specific. There are a fair number of people here who can help.
pejota is offline   Reply With Quote
Old 10-15-2012, 03:38 AM   #10778
I just received my new club racer through AMAIN and counted the spur; 69T.
BTW, does anyone know what tooth spur I have stock? It's not the 72 tooth spur I was expecting.[/QUOTE]
Pellefa is offline   Reply With Quote
Old 10-15-2012, 03:32 PM   #10779
DARKSIDE's Avatar
http://www.nashrcracer.com/forum/viewtopic.php?t=3436
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is offline   Reply With Quote
Old 10-15-2012, 05:36 PM   #10780
Default Specifics
I don't know what specifics are needed.
I run an indoor CRC carpet track. Fastest VTA times are 13.2 seconds.
I have the aluminum shock ntn/tc3 shocks to put on. But don't know what shock oil is need. I have stock blue springs on front and rear. Thinking of changing to gold on front silver on rear (from searching internet). Changed the front CVA to aluminum, broke the plastic ones right away.
I have run offroad and there are specific setup sheets on the internet, but for the TC4 there isn't a basic setup for carpet VTA. Seems that someone out there has a decent starting point.
THanks
Old 10-16-2012, 05:32 AM   #10781
pejota's Avatar
Specifically, what is your car doing wrong?
Is it loose on corner entry, pushing on corner exit, traction rolling, etc...
As for setups, kinda surprised no one has chimed in, but these two setups are good places to start. You should also check with the people at your track.
http://www.teamassociated.com/pdf/ca...o_dhi_2006.pdf
http://www.teamassociated.com/pdf/ca...ekend_2005.pdf
The notable setup options are the 40wt shock oil, 2 degree caster hubs, Silver front springs, Green rear springs, front solid axle.
Old 10-16-2012, 06:13 AM   #10782
DARKSIDE's Avatar
this is my 1st TC4...I love my 3 and was looking to see what a baseline(boxstock) TC4 Club Racer could do...
I added the fan duct system, which works great
http://www.teamassociated.com/parts/details/31037/
and the thumb screws and brace
http://www.teamassociated.com/parts/details/31039/
In the manual, its shows about the web fix and I switched to 64p...in a 78 spur and 54 pinion, FDR 3.61 w/ reman Novak SS
Im also using the XP 1313 servo, and HW Juststock esc...with Reedy Wolfpack5000 25c lipo w/ bullet connectors
Now for setup...nothing...I put the stuff in the car and it was great...set TQ and won the main on an inverted start...
Changes I plan on making
5 mm ride height f/r
35 wt f
30 wt r
VCS3 Shock Kit w/ RSD bladders
RSD springs yellow f, teal r
FT screw kit
Bearing cleaning
The good thing is setup for VTA, the car was great out of the box...it didnt push or washout in the sweeper...with some ride height and camber adjustments, the car is a winner...I think I got into the high 12's with it...and on my TC6, Im running mid 12's, on similar track conditions
I would make minor changes 1st...starting with 64p gears...its alot easier to get a better FDR...then goto oil and springs
Team Associated TC4-img_20121012_183324.jpg   Team Associated TC4-img_20121012_183345.jpg   Team Associated TC4-img_20121012_200556.jpg   Team Associated TC4-img_20121012_200221.jpg   Team Associated TC4-4615_sm.jpg
April 8-9
Old 10-16-2012, 06:16 AM   #10783
DARKSIDE's Avatar
also I trimmed out the battery side of the chassis so the square edge of the lipo would sit without rocking
April 8-9
Old 10-16-2012, 07:16 AM   #10784
Reed60's Avatar
+1 on Darkside comments, I have a box stock TC4, 25.5, changed to 64p, I run 76 pinion and 60 or 62 pinion, depends on the track. I lowered the ride height, alum cvd's and thats it. We have a large class of VTA and mine is top 5 every race. The top guy also runs a TC4. It handles great!!!
T4.1, TC4, TC6, T4.2
JR PUNISHER
Reed60 is offline   Reply With Quote
Old 10-16-2012, 07:37 AM   #10785
Conrad's Avatar
bertrandsv87,
Could you post a picture of your modified carriers (C hubs) to show me how much material you removed to get the LCD driveshafts to fit correctly.
I have tried the XXX-S, JRX-S and obviously TC4 hubs and carriers and a mixture of all the parts but only the JRX-S hubs and carriers fit properly and allow the LCD's to move freely but they widen the track width too much and the driveshaft pin on the diff side is right on the edge of the diff half ready to fall out.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
