Like Tree18Likes
Old 09-27-2012, 01:44 PM   #10726
Smile
I also use small shims on my racks and lots of loctite. If it binds a bit, I turn the screws back a bit until the play is minimal. Not hitting walls is the key to keep your rack from coming loose...
bertrandsv87 is offline   Reply With Quote
Old 09-27-2012, 05:36 PM   #10727
AM03GT's Avatar
With fresh ballcups the 31022 Bellcrank posts were the main point of getting rid of slop. Due to manufacturing tolerances the posts tended to be a tad long allowing the bellcranks to give a little vertically. Carefully sanding the posts down a little at a time to the perfect height the rack will build slop free.
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 09-27-2012, 07:19 PM   #10728
mdwalsh's Avatar
Trader Rating: 26 (96%+)
Selling my barely used and thoroughly modded TC4-
TC4 perfect for VTA or stock racing!
Matt
mdwalsh is offline   Reply With Quote
Old 09-28-2012, 10:35 AM   #10729
mdwalsh's Avatar
if you pm me about my TC4 and mention this thread ill give you a great deal on the car
Matt
Old 09-28-2012, 02:13 PM   #10730
Originally Posted by bertrandsv87 View Post
Don't forget to crank your throttle expo up , and throttle acceleration up too .... Without them up, you'll get killed down the straight !!!
Why would any of this have any impact if you are at 100% throttle anyway? It's still 100% throttle regardless of these settings.
Lipo?
Brushless??
I'm still running Sanyo NiCds with a mechanical speed control.
FrostyDude is offline   Reply With Quote
Old 09-28-2012, 03:51 PM   #10731
Smile
If you've never used expos and throttle acceleration, you are not getting max acceleration. Yes it's the same 100% as you said, but if I get twice as fast as you can, guess who gets blown away down the straight ????? With shaft drive, it's effects are more noticeable !!!
Old 09-30-2012, 03:56 AM   #10732
Well that seems logical. I will give it a try.
I have one other question since it seems like you have quite a bit of experience with the TC4 chassis. I saw earlier in this thread you recommended switching to the AE #31608 (X-2.5) factory team mount for the rear suspension arms. That part has been discontinued. The #31609 (X-2.0) part is still available. Will that perform basically the same? Thanks!
Lipo?
Brushless??
Old 09-30-2012, 06:41 AM   #10733
Originally Posted by FrostyDude View Post
... That part has been discontinued...
http://www.ebay.com/sch/i.html?_odkw...31068&_sacat=0
Rojna is offline   Reply With Quote
Old 09-30-2012, 04:47 PM   #10734
Originally Posted by Rojna View Post
Thanks!
However, I am still curious if there is a big difference between the 2.5 degree and 2 degree rear mounts. I can only assume they discontinued the 2.5 degree version because not as many people purchased it.
Lipo?
Brushless??
Old 09-30-2012, 05:17 PM   #10735
Not that much difference to me. I ran both two degree(tc4 rtr 17.5t), and 2.5degree(fttc4 13.5t) and I see no difference in rear traction on the same carpet surface. The 2.0 is supposedly faster down the straight, but I still see no difference. The rear seems planted enough in both cases to cause quite a bit of push. I will start tightening my rear diff a bit to gain some steering back...
Old 09-30-2012, 05:25 PM   #10736
Thanks!
Lipo?
Brushless??
Old 09-30-2012, 05:28 PM   #10737
Smile
Cementsurfer86 and Reed60, you guys had your tc4's geared at 3.39fdr and 3.1fdr respectively. Did any of you crank your motor timing to the max ???? I am about to try max timing with my ballistic with gtb2 xdrive next practice time. I'll also run a tp5300 65c pack instead of my usual tp3200 40c packs... I use to keep up with comp down the straight, but now I plan to blow past them... Any of you guys using microlubricants(zmaxx, bestline, etc...) in your drivetrain?????
Old 09-30-2012, 05:31 PM   #10738
MikeXray's Avatar
Trader Rating: 72 (100%+)
The only thing you'll be blowing with a novak @3.4 with max timing is smoke.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-30-2012, 05:36 PM   #10739
Smile
Don't say that Mike ! I had Delacruz in my sights down the straight at 360v2 last Wednesday... If only I could pull him a bit..... I think max timing will do just fine at 3.65fdr... You coming down next Wednesday???? I know Coach is scared....lol....
Old 09-30-2012, 10:55 PM   #10740
cementsurfer86's Avatar
As of right now I'm sitting at a 3.21 fdr, with 42 degrees of timing, and damn near pulled off the win last night in our scale spec main against much more expensive equipment. Our track is pretty big, so I'm able to get away with it, but I've also gone in small increments as well, so I don't burn my stuff up. Start at 35 degrees and go in 5 degree increments from there. At a 3.65 fdr, full timing will be just fine, just temp the motor after a few mins to be sure.
(On a side note, I temp'd my motor right after the main, and I was at around 150 deg. Not too bad.)
Jesse Anderson / JROY386 / R_
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
