Old 09-16-2012, 07:08 PM   #10696
Smile
Good luck with 4.0 fdr and 17.5t ! It will depend on your motor timing now..... I don't mess with my ballistic timing at all......
bertrandsv87 is offline   Reply With Quote
Old 09-17-2012, 04:18 PM   #10697
cementsurfer86's Avatar
I figured this has been answered previously, but what are some quick ways to drop weight in this car? Obviously, screws, turnbuckles, etc..... but anything else?
Jesse Anderson / JROY386 / R_
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 09-17-2012, 05:33 PM   #10698
Reed60's Avatar
I do not mess with the timing and run a 60 pinion/75 spur 64 pitch set up.
It comes off at 150 temp...
mid size carpet track. FDR 3.1 something
T4.1, TC4, TC6, T4.2
JR PUNISHER
Reed60 is offline   Reply With Quote
Old 09-17-2012, 05:40 PM   #10699
all of the FT Carbon plastic parts weigh less then the stock parts.
you can also use a shorty lipo
Rojna is offline   Reply With Quote
Old 09-17-2012, 08:48 PM   #10700
Thanks!!! Ran VTA on saturday with my TC4, and was impressed, just a bit on the heavy side.
Old 09-19-2012, 09:02 AM   #10701
Conrad's Avatar
Shorty lipo, aluminium diff halves and plastic driveshafts (IRS make the nice versions of the latter two items, great as long as you don't run a spool). Otherwise it is quite a chubby car, it always has been. Don't waste your money on any of the c/f plastic parts they are no lighter, I weighed up everything when I converted my plastic tub over to c/f. Even on something as big as the chassis their was only 1g in it.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 09-19-2012, 09:12 AM   #10702
There is a 1g difference on just the rear shock tower !
Stock chassis 156g
Carbon chassis 131g
25g difference, thats almost 4 lead weights.
Old 09-19-2012, 02:05 PM   #10703
When using a short Lipo you loose something like 90 grams on the left side, is anyone moving ESC over to the left (next to the servo) in order to not screw up the L/R balance of the car...? Or is 90 grams insignificant in this respect...?
Pellefa is offline   Reply With Quote
Old 09-19-2012, 02:10 PM   #10704
I have my esc behind the shorty next to the motor. The shorty & esc weight as much as my servo rx & motor.
Old 09-20-2012, 02:44 PM   #10705
At 3.65fdr motor temp was 132F after over eight Minutes of practice... I could go higher, but speed/acceleration were good......
Old 09-20-2012, 05:15 PM   #10706
That's about what mine was running, but was down on speed ( we have an enormous carpet track). Currently I'm down to a 3.39 fdr.
Old 09-20-2012, 10:21 PM   #10707
Smile
Pellefa, I run my Car unbalanced with a 208gram battery, and all I can say is that I turn right full throttle faster than if the Car was balanced... Left turns are another story, but with low roll centers, traction rolling is not an issue. Total vehicle weight seems more important though: under 1420grams should be competitive, although I can see mine competing at 1475grams easily.... As far as gearing goes, 3.39 fdr should be blazing fast with all radio settings up....
Old 09-23-2012, 09:58 AM   #10708
Default My TC4 goes right when applying power
Originally Posted by saxo View Post
Thanks all for your suggestions. I had to tighten the rear diff cause it was too loose. After that I adjust the ride height and ensure camber, toe, etc...were set correctly. Now my TC4 screams straight! So happy. Thanks again.
Hi All,
SAXO had this isue some time ago and solved it by tightening the rear diff. I did the same, but issue is still there, although improved. I tighened it fully, then opened up 1/2 on the screw as per the manual.
Should I go tighter on the diff or rather check other stuff on the car...?
Old 09-23-2012, 09:59 AM   #10709
Thanks, I kept ESC on teh right side to make it possible to run both shortys and the normal 2S.
Old 09-23-2012, 04:05 PM   #10710
Cool
I've also ran into problems when running more than One degree camber in the rear, and less than two degrees in the front: I spinout bad..... I also realized that the underbelly of the chassis needs to be free of gunk, and cleaned with motor spray after every run or else it will scrub corner speed and cause spinouts.... Finally , the tc4 handles better on throttle than Off: getting Off the gas causes spinouts....
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
