Like Tree26Likes
Old 08-03-2012, 07:57 AM   #10606
nuttynative's Avatar
Either way, I changed mine out yesterday and there were NO shims/spacers on it. Freah out of the box. Mine were taller as bertrandsv87 says. had to back off the droop screws quite a bit.
nuttynative is offline   Reply With Quote
Old 08-03-2012, 08:21 AM   #10607
Smile
Rojna, that pdf is for the team kit, not the RTR's ! The rtr's come with nothing included.... Nuttynative, you're right about backing off the droop screw, and if you want to lower the roll center even further, you can raise the inner camber links as high as possible... It should improve handling alot......
bertrandsv87 is online now   Reply With Quote
Old 08-03-2012, 08:43 AM   #10608
Originally Posted by bertrandsv87 View Post
FOR ALL TC4 RACERS: PLEASE LOWER YOUR,CAR 'S ROLL CENTER BY FITTING FT TEAM ARM MOUNTS(#31064 and #31068) IN YOUR CAR WITHOUT ANY SHIMS.... OTHERWISE YOUR CAR WILL BE A BRICK, AND A TRACTION ROLLING KING !!!!
You directed your post to all TC4 racers, not just the RTR Racers ...
All my TC4's are FT or TEAM, never had a rtr.
Wonder what does the CLUB RACER comes with ?
Rojna is offline   Reply With Quote
Old 08-03-2012, 10:30 AM   #10609
Cool
I directed my comments on the currently available tc4's out there: rtr and club racer... AE discontinued their Ft kits and team kits a long time ago, and you know it !!! Moving forward, the plastic arm mounts are the only things to change here...
Old 08-03-2012, 06:26 PM   #10610
According to the AE website the #31608 (X-2.5) part has been discontinued.
The #31609 (X-2.0) part is still available. Will that perform basically the same?
Lipo?
Brushless??
I'm still running Sanyo NiCds with a mechanical speed control.
FrostyDude is offline   Reply With Quote
Old 08-04-2012, 07:41 AM   #10611
That's what I've also found at the hobby shops, they can't get it. I got mine on Ebay.
Old 08-04-2012, 08:38 AM   #10612
pejota's Avatar
Heed YOUR warnings?
PFFFFTTTTT!!!
I'll heed the setup sheets and go from there.
http://www.teamassociated.com/cars_a...anuals_setups/
If you already have the mounts, you can experiment, but if you have the stock RTR mounts, you're doomed... I don't think the club racer comes with the FT mounts, and hopefully racers will heed the warning......
pejota is offline   Reply With Quote
Old 08-04-2012, 04:01 PM   #10613
AM03GT's Avatar
I've had 2 setups that worked very well the first running 2/2/4/4 on arm mount shims and the current setup using 3/3/3/3 . . .
Running the car with FT mounts and no shims is reminiscent of the old carpet racing foam tire setups...
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 08-04-2012, 09:41 PM   #10614
2/2/3/3 is my vta setting
Old 08-04-2012, 10:24 PM   #10615
I run 0/2/2/0 on carpet (some anti-dive and antisquat) to stop traction rolling... I have not tried it on asphalt yet....
Old 08-08-2012, 07:47 AM   #10616
Smile
I am going to try running 0/0/2/0 to solve my front caster angle lost on the front, causing my tc4 to wander a bit down the straight.... I will have to order another arm mount asc31065 to accomplish that.... Running flat 0/0 on the front end with the lowest roll center will be a first for me, and could be a game changer...
Old 08-14-2012, 01:34 PM   #10617
Trader Rating: 15 (100%+)
Default TC4 + LOSA3344 LCD DriveShaft
I finally had the chance to build the LOSA3344 LCDs. If I understand it correctly, I can use the existing TC4 hub carriers but I have to dremel? I thought I read that somewhere. I also have a set of Losi 2 degree Hub carriers that I can replace but if minimal work is required to make the existing TC4 hub carriers to work, I prefer to do that instead of changing the whole thing out.
Any pointers? This is my first time attempting this.
saxo is offline   Reply With Quote
Old 08-14-2012, 01:50 PM   #10618
Originally Posted by saxo View Post
I finally had the chance to build the LOSA3344 LCDs....
Why not run the associated 2402 cva's ??
http://www.teamassociated.com/parts/details/2402/
Old 08-14-2012, 02:19 PM   #10619
Well... I bought the LOSA3344 on the recommendations in this forum because it was said to eliminate the chatter.
Old 08-14-2012, 02:23 PM   #10620
Smile
Saxo, you are right ! You need to dremel and open up the hole a bit, but the hole needs to be wider on the diff case side than the tire side , so you'll still have some meat left on the caster blocks.....
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
