Like Tree43Likes
Old 06-27-2012, 11:39 AM   #10591
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
Originally Posted by saxo View Post
I bought a TC4 from this forum and it also came with the cooling fan/duct - Part #31037. But I cannot seem to put it on. Anyone have pictures or instructions on how to install this?
http://teamassociated.com/pictures/p...7/31037_md.jpg
The part is upside down as shown. (you are looking at the side that goes to the chassis). It bolts on top of the 2 holes in front of the motor.
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
y2kgtp is offline   Reply With Quote
Old 06-27-2012, 10:22 PM   #10592
It's fairly easy to install, but it can cause alot of glitching too... Good luck....
bertrandsv87 is offline   Reply With Quote
Old 07-15-2012, 08:03 PM   #10593
Hi everyone, I won a TC4 RTR today at a race as a door prize. I am going to pull out all of the electronics and put in my own gear. Would anyone on this forum be interested in buying the stock electronics?
flydrive rc is offline   Reply With Quote
Old 07-15-2012, 10:19 PM   #10594
I doubt it....
Old 07-29-2012, 08:43 PM   #10595
Ok guys I just got a TC4 Club racer and I need some help. I just had my first race with it today but had some traction issues on the rear. The rear end just keeps comming out, I had to almost drift the car to do something. I still managed to make the A Main but I was not on par with the other guys. First the car is bone stock so I need to buy some things like swaybars, front diff, etc. Can you guys point me in the right direction on set up for a small track with some 180 corners? Also we race this class as Super GT with closed end bell 20 turn motors. I'm using the same motor as most but I was very slow on the upper end. The guys passed me on the straights like I was standing still. I changed gearing to 86/40 with 64 pitch gears but the guys just kept on going by me. After every run the motor was just at 138 degrees so it was not hot at all. Most were around 175. I think my speed control has something to do with the lack of top end. I was using a LRP Quantum 2 that I used on my 1/12 scale. I also have a LRP Sphere (the original one), wish one do you guys think it's going to perform best?
jneg is offline   Reply With Quote
Old 07-29-2012, 11:17 PM   #10596
Smile
For the rear coming out, make sure you lower your roll center as much as possible, loosen the rear diff, and lower your rear droop, lower your steering dual rate... As far as motor gearing, try to gear the same or higher than everyone else, but make sure you also try one of your competitor's motors. They might be way faster than your motor because of some secret treatment nobody will tell you about.....
Old 07-31-2012, 10:13 AM   #10597
nuttynative's Avatar
I'm just getting back into TC racing for fun after a 5 year break. Things are much more advanced and I need pointers on initial setup of the TC4 club racer for parking lot racing. I will be running Speed Passion Cirtix Series "Stock Club Race" ESC and Motor Combo (10.5T), Sorex 36R tires, 5000 lipo's, Hitec HS-5565 MH servo, HPI BMW M3GT body. My main issue is where to start with pinion gearing and replacement shocks.
nuttynative is offline   Reply With Quote
Old 08-01-2012, 08:47 AM   #10598
Cool
FOR ALL TC4 RACERS: PLEASE LOWER YOUR,CAR 'S ROLL CENTER BY FITTING FT TEAM ARM MOUNTS(#31064 and #31068) IN YOUR CAR WITHOUT ANY SHIMS.... OTHERWISE YOUR CAR WILL BE A BRICK, AND A TRACTION ROLLING KING !!!!
Old 08-01-2012, 08:57 AM   #10599
runing #2 shims all the way around with the FT mounts without traction rolling, must be a set-up thing
Rojna is offline   Reply With Quote
Old 08-01-2012, 09:16 AM   #10600
If you already have the mounts, you can experiment, but if you have the stock RTR mounts, you're doomed... I don't think the club racer comes with the FT mounts, and hopefully racers will heed the warning......
Old 08-02-2012, 01:28 PM   #10601
Where are the shims you are talking about? On the hinge pins?
Old 08-02-2012, 10:13 PM   #10602
The shims only come with the factory team kit, not the rtr... They go between the arm mount and the chassis...
Old 08-02-2012, 10:18 PM   #10603
wrong, the shims (31010) are included and used in all TC4's
Old 08-02-2012, 10:43 PM   #10604
Cool
Rojna is absolutely wrong here ! I own three rtr's and two ft kits and I never had shims included in the rtr's ! The rtr only comes with a thicker arm mount than the ft aluminum mounts, which makes it impossible to lower the roll center through the arm mounts... Also, you can't shim the already thick rtr arm mounts, and expect better handling that way: you will have raised the roll center so high that the suspension will not absorb any lateral force, thereby tration rolling endlessly... Tc4 racers, beware of these quick spiteful unfounded posts that carry zero explanations...
Old 08-03-2012, 07:40 AM   #10605
Rojna is absolutely wrong here ! ...
ae must also be wrong ...
http://www.teamassociated.com/pdf/ca...ing_tc4rtr.pdf
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
webdr
