Like Tree38Likes
Old 05-29-2012, 06:44 AM   #10561
pejota's Avatar
Originally Posted by y2kgtp View Post
Sigh. More money to go into it.
Or run it out of the box and make changes as you go. The only huge thing you might consider before you run it is a front spool.
From what i've seen, people throw lots of money at cars to go fast when they should be working on setup and driving.
If you know you have awesome skills as a driver, then spend the money first. If you're skills aren't up to par, upgrade as you get better.
pejota is offline   Reply With Quote
Old 05-29-2012, 06:50 AM   #10562
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
The TC4 Sport comes stock with a front spool.
I was mainly concerned over a 'chattering' problem I have read.
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
y2kgtp is offline   Reply With Quote
Old 05-29-2012, 08:05 AM   #10563
pejota's Avatar
Are you racing indoor carpet or outdoor asphalt? I've never noticed a problem with chattering on asphalt or concrete outdoors, but i've never run a TC3/4 indoor on carpet with a spool.
Old 05-29-2012, 08:27 AM   #10564
y2kgtp's Avatar
This is intended for outdoor asphalt parking lot.
My interest in the LCD's to replace the stock CVD's came from this post:
Originally Posted by bertrandsv87 View Post
The composite or aluminum cvd drives are only good in the rear of the car, not the front ... You need LCD's in the front to match the performance of the new kits.... The club racer come with a front spool, and you need LCD type drives when running a spool up front.....
Old 05-29-2012, 09:30 AM   #10565
pejota's Avatar
I'm not a pro... so i would be more concerned with proper setup, gearing and driving consistent laps. If i ever get to the point where i need those last few tenths, then i'll start worrying about the things that will get me there.
In my own personal experience, the "upgrade" that has really helped me the most was removing the chassis braces at the four corners. That really allowed the chassis to flex and personally helped me with handling. Sway bars are the other thing that helped me as well. Other than those two things, just knowing how to setup your car, setup your transmitter, find the proper gearing and not tear up the pipes will go a long way to getting the most out of your car, straight from the box.
Old 05-29-2012, 09:40 AM   #10566
y2kgtp's Avatar
Sounds good to me. I was just looking to ovoid a potential weakness of the car from the start.
Old 05-29-2012, 01:01 PM   #10567
pejota's Avatar
Hmmm.... looking at the kit i'd start with:
AE TC Spring kit
35 and 40 pound shock oil
Threaded Body shocks
Aluminum Wheel Hexes
Sway Bars
Tires/Wheels/Body for your preferred class.
Old 05-29-2012, 01:06 PM   #10568
Trader Rating: 15 (100%+)
Default TC4 w/ Solid Axel = chatter
Regarding the reply about chatter and running the TC4 on carpet. I run this and indeed there is chatter. At least with my car it is quite loud though honestly it doesn't seem to affect my ability to drive. I'm not a a great driver but am getting better. Having said that, I did purchase the LOSA 3344 and hubs to eliminate the chatter problem. I just haven't come around to actually changing them.
I also did not know that you can simply remove the chassis braces. I was under the impression that you had to keep them on. I'll try that to see if it helps.
saxo is offline   Reply With Quote
Old 05-29-2012, 01:12 PM   #10569
y2kgtp's Avatar
AE TC Spring kit
Sway Bars
The Spring kit and Sway bars are next on my list.
I want to run a 17.5T RCGT type class with my local club, but they have not set any schedule yet for the year, so I am stashing parts waiting for this to happen.
Old 05-29-2012, 06:09 PM   #10570
None of the local hobby shops in my area carry 60T spurs and pinions over 35T. I'm also having trouble finding them online. What site are you guys getting them from? Thanks for your help.
00Pocho is offline   Reply With Quote
Old 05-29-2012, 06:19 PM   #10571
y2kgtp's Avatar
I know they go down to 49T for the spur. But
Will it fit ?
http://www3.towerhobbies.com/cgi-bin...&I=LXYGN2&P=ML
Old 05-29-2012, 06:23 PM   #10572
Yup, I checked tower hobbies and they have 49, 52, 55 then jumps to 72.
Old 05-29-2012, 07:09 PM   #10573
I too run a front spool with lcd's on carpet, and all I got to say is WOW !!!! The punch is out of this world, and don't have to wait until your Car straightens up to get power either... Also, Towerhobbies use to have lots of 60t spurs, and you will need a pinion range of 36t to 43t to make it Work, but remember to dremel the part of the chassis that's directly under the pinion gear for clearance, if you have the tub chassis !!!! I've broken One motor shaft not paying attention to that , and it can time consuming as well... As far as chassis brace, you must take them Off to get flex, but by far the best setup advice is to change both your front and rear outer arm mounts to the Ft aluminum arm mounts(2.5 rear), and run no shims under them.....
bertrandsv87 is offline   Reply With Quote
Old 05-29-2012, 07:16 PM   #10574
As far as 48p pinion gears (36t to 40t) are concerned, I run Hirosaka gears, but I think there are other manufacturers out there with 36+ teeth gears to 40+... You got to find them though, and switching to 64p is a no no for me, too much Work to keep changing spur gears in that Car...... I have never ruined a 48p spur gear in the 7years running my tc4's.....
Old 05-29-2012, 07:25 PM   #10575
Smile
Looking at your picture Y2kgtp, I would recommend the spec Tires that's being run in the club that you race or Sweep 32R Tires, and a protoform mazda speed 6 lightweight body, Savox 1251 servo...... The tc4 will compete well with these parts, and of course the most important battery pack : thunderpower tp4300-2spr65d ......
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
