Like Tree38Likes
Old 05-21-2012, 09:37 AM   #10546
racer x 1's Avatar
Trader Rating: 27 (100%+)
Originally Posted by jeff jenkins View Post
Yes it can be taken seriously. That's what I race. The suspension geometry is still very close to the best current cars . Trust me the car is good and you will like it . Plus you can't beat the price I would just get some new shocks. Doesn't mean you have to its just preferance for me. I'm not a fan of plastic body shocks. So I choose to run tamiya shocks. But the newer tc6 shocks look the business!!
Lol i was just looking at those. How low can you get the fdr is also a concern.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 05-21-2012, 01:28 PM   #10547
The stock shocks work, but with the yokomo shock bladders and green slime. They will need fluid change more often (once a month) to compete.....
bertrandsv87 is offline   Reply With Quote
Old 05-22-2012, 06:56 AM   #10548
xrayroooahhhh's Avatar
Could you post a starting set up.....and maybe a couple of pics of how you balanced the chassis? I am planning on running 3 classes this fall in our series, 17.5 blinky, open mod, and VTA and I have almost 100% decided on the TC4 (was thinking Sakura S) I am going to get 3 chassis and the price is killer right now......I was thinking the extra weight would not be an issue in open Mod as I can run whatever power I need to compensate.....you think getting the chassis prepped, selecting electronics, upgrading the shocks and then decide on battery for balance is the way to look at this??
Any set up differences/advice on the 3 classes noted above would be appreciated!!!
Roy
-ROOH RACING-
www.donerite.net
xrayroooahhhh is offline   Reply With Quote
Old 05-22-2012, 01:56 PM   #10549
The most important setup in the tc4 is roll center.... You will need to run no shims under the front arm mount that's next to the bumper, and no shims under the rear arm mount that's on the shock side of the rear end... You can also raise the inner camber for more fine tuning... I did all sorts of setups before that with no success: I was traction rolling everywhere, and the car was a slow brick ! Now, I can run over dots while cornering without any issue at all... The rtr arm mounts are way too high, and you will need to get the factory team ones to compete.... Also the front LCD drives (losa3344), are a must......
Old 05-22-2012, 01:59 PM   #10550
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
So the composite CVD drive bones that come on the TC4 Club Racer are not good?
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
y2kgtp is offline   Reply With Quote
Old 05-22-2012, 07:56 PM   #10551
The composite or aluminum cvd drives are only good in the rear of the car, not the front ... You need LCD's in the front to match the performance of the new kits.... The club racer come with a front spool, and you need LCD type drives when running a spool up front.....
Old 05-22-2012, 08:23 PM   #10552
y2kgtp's Avatar
Sigh. More money to go into it.
I am actually still on the fence over this car. Not Sure if the local club will run on-road much this
Year. I keep buying stuff for it, but leaving everything sealed until I make up my mind.
What parts would be recommended to get this chassis fairly competitive for 17.5T out of the box?
I have read recommended:
Losi LCD Driveshaft Set: JRX-S [LOSA3344]
Front "slipper spool" modification. Losi A3325 slipper spool and Associated lightened steel outdrives
FT arm mounts
Anything else?
Last edited by y2kgtp; 05-23-2012 at 05:36 AM. Reason: adding info and questions....
Old 05-25-2012, 11:06 PM   #10553
Anybody know if the rear ball diff that comes with the club racer is adjustable? Thanks
00Pocho is offline   Reply With Quote
Old 05-25-2012, 11:16 PM   #10554
Yes the tc4 club racer rear ball diff is adjustable... Slipper spool is not necessary if you have a parma wide bumper !
Old 05-25-2012, 11:58 PM   #10555
Cool, thanks! Do you have to remove the diff from the case to tighten it?
Old 05-26-2012, 03:04 AM   #10556
Never mind. I downloaded the manual and figured it out. Thanks
Old 05-28-2012, 05:58 PM   #10557
Thumbs up spur & pinion
anyone have a starting point 4 17.5 blinkey spur & pin size? thanks. gordy
narkix is offline   Reply With Quote
Old 05-28-2012, 10:47 PM   #10558
I have good results with 60t spur and 41t pinion or 3.65FDR with 30 timing on the motor, and 25% throttle expo on the radio with 30% throttle acceleration .....
Old 05-28-2012, 10:53 PM   #10559
Cool
If you crank up your 17.5t motor timing past 30 , you will want to gear lower : 60t spur and 38t pinion or 3.94FDR.... I don't like the heat that comes with timing past 30 though...
Old 05-29-2012, 05:06 AM   #10560
y2kgtp's Avatar
What would be a good starting range to get for pinions
For 17.5t?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
