Old 05-11-2012, 11:34 PM   #10531
Smile
You can run a 26t pinion with 72t spur with a 10.5t boosted motor, but if you don't run boost, then you will need a smaller spur gear (66t) and bigger pinion 30t to get your gearing around 5.0fdr to 6.0fdr .... Shimming should be very good(0.1mm play), on all Bearings, specially the ones holding the Tires, and you can get 5mm shim sets from 3Racing that contain the 0.1mm, 0.2mm, and 0.3mm shims in them...
bertrandsv87 is offline   Reply With Quote
Old 05-12-2012, 11:40 AM   #10532
mac112's Avatar
Smile
OK, thanks, will get some Robinson racing gears and switch out the 72/25. glad you gave me two options, one for boost, one for Non- boost. I will use the Non- boost
Mac.
mac112 is offline   Reply With Quote
Old 05-12-2012, 10:59 PM   #10533
Smile
No problem !
Old 05-13-2012, 11:30 AM   #10534
xrayroooahhhh's Avatar
Default A little help!!
Hey Guys
If you were going to convert a Club Racer TC4 to a FT TC4 do you need the motor mount listed from the FT TC4 (team associated 31105) why I ask is, can't seem to find any of this part number online (all discontinued)
Thanks for any help
R
-ROOH RACING-
www.donerite.net
xrayroooahhhh is offline   Reply With Quote
Old 05-13-2012, 11:10 PM   #10535
Yes you will...
Old 05-15-2012, 10:27 PM   #10536
Trader Rating: 15 (100%+)
Default TC4 Shims
Can someone explain to me the purpose of the TC4 shims? When I bought my TC4 from this forum, it was already set up so I never changed it. How do I go about deciding which shims to put in?
saxo is offline   Reply With Quote
Old 05-15-2012, 10:59 PM   #10537
Shims are there to reduce excessive play(over .1mm). If you can clearly move components back and forth with obvious gap between moving parts, then you need shimming to reduce play so it can be barely perceptible to the naked eye. You will need different thickness of shims(.1mm to .3mm) to be able to achieve proper shimming ...
Old 05-18-2012, 07:36 AM   #10538
flat4's Avatar
Send a message via Yahoo to flat4
Default TC4 chassis up grade?
lately I have been thinking about upgrading the chassis on my tc4. I found a chassis from Diggity Design, but i am not sure if I will be able to use the stock front and rear arms on there XLR-V2 chassis. I would much rather replace an arm then some of the other bits if my car happens to get hit while racing
http://www.diggitydesigns.com/D3_OnR...LR8V2_Kit.html
mo6/ae sc10/2wd slash
flat4 is offline   Reply With Quote
Old 05-18-2012, 09:08 AM   #10539
Conrad's Avatar
Apparently you can fit stock TC4 wishbones with some work but the aluminum ones diggity makes are a different length so it would affect the handling. I emailed diggity/posted in their thread on rctech a few months back and haven't had a reply since otherwise I was ready to buy a kit from them.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 05-18-2012, 10:19 AM   #10540
The stock chassis is way too cheap and available to switch to the diggity design chassis for minimal performance gain, and alot more money. Also, the open diff design leaves the gears exposed to dust and debris .....
Old 05-18-2012, 03:07 PM   #10541
flat4's Avatar
the open diff i am not to worried about, the cheap'ness of the chassis is though. any thoughts on what would be a good upgrade of the tc4?
Old 05-18-2012, 03:23 PM   #10542
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
I would Email to make sure it's still available:
http://www.penguinrc.com/products/as.../p5500tc4.html
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
y2kgtp is offline   Reply With Quote
Old 05-19-2012, 02:18 AM   #10543
Smile
Personally, I don't think the stock chassis needs replacing at all to be competitive. It needs the lightest electronics though, and a lipo pack under 230grams with a spool up front(with losi LCD's losa3344), Acer Bearings, lightweight body, parma wide bumper....... Once you can get it balanced , tweak free, and under 1380grams, you will be competitive..... I run mine at 1471grams in 17.5blinky, and it's very competitive eventhough it's unbalanced, tweaked, and I need alot of practice.... The hardest part is to get it to go straight with my analog servo, and that loose steering bellcrank.....
Old 05-21-2012, 12:48 AM   #10544
racer x 1's Avatar
Trader Rating: 27 (100%+)
does anyone think the club racer can be taken seriously in 17.5 blinkly sedan? Im curious as I like to be different and absolutely no one at my local tracks run this car anything except VTA which isnt too popular. my concerns are of course the standard shocks and potentially the chassis dragging in corners. any input?
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 05-21-2012, 10:30 AM   #10545
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
Yes it can be taken seriously. That's what I race. The suspension geometry is still very close to the best current cars . Trust me the car is good and you will like it . Plus you can't beat the price I would just get some new shocks. Doesn't mean you have to its just preferance for me. I'm not a fan of plastic body shocks. So I choose to run tamiya shocks. But the newer tc6 shocks look the business!!
Serpent project 4x
jeff jenkins is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
