Like Tree42Likes
Old 01-15-2012, 08:09 PM   #10411
Smile
These are all good points, but I wanted to visually see the difference between the newer kits and the tc4, and that was the first visibly noticeable difference. My tc4 refused to compress the springs when making a turn, and would rather traction roll instead. Lowering the roll center that way, and by that much, should make the springs compress, and absorb the lateral energy better. Hopefully it will work because I have tried pretty much everything else....I dont know if anybody else has already tried it since I had to trim the rear shock tower a bit to fit the ballcup...That's with 5mm ride height, by the way.....
bertrandsv87 is offline   Reply With Quote
Old 01-15-2012, 08:14 PM   #10412
Also I thought that the springs compressed more with a higher roll center, but it seems to be the other way around, or so I've read.....
Old 01-15-2012, 08:40 PM   #10413
Trader Rating: 40 (100%+)
So I was curious and I pulled out my FT TC4 and Sakura Zero S
And on the TC4 the rear Upper camber links are basically level with no shims
The Front is angled towards the car by about 3mm Not sure if it's the same with the Tub chassis version
Also the Sakura has the same thing front and rear Level in the rear and angled to the car in the front but only by about 2mm and that's no shims front/rear
Now my TC4 likes to turtle if I hit a dot while cornering but the Sakura doesn't.
I'm running stock everything on the Sakura but it has a very flexible chassis (plastic instead of carbon fiber)
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 01-15-2012, 08:55 PM   #10414
Did you have the batteries in them with 5mm ride height ? My Ft tc4 has two shims in the rear, and three in the front and the arms are sloping towards the center of the chassis: high roll center, which explains the tendency to rollover.... I have them sloping the other way now, and I'll have to test and see what that does, but when I try to push the car laterally now, with sticky tires, the springs compress more than before...
Old 01-15-2012, 09:03 PM   #10415
I run 6mm ride height in the front and 5.5 in the rear (for 25.5 no timing VTA Class)
Jason Deadman
Old 01-15-2012, 09:32 PM   #10416
I forgot about Vta...sorry... But it's another tuning option....
Old 01-16-2012, 07:52 PM   #10417
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Originally Posted by Rojna View Post
forgot that AE makes them and I have them in mine TC3's & TC4's LOL
Part #?
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 01-17-2012, 05:32 PM   #10419
Smile
Anybody run 0-2 low roll center(no shims under the lower outside arms) front and back???? It seems to be the best way to really lower the roll center .... I am trying everything to stop traction rolling....
Old 01-17-2012, 05:51 PM   #10420
I am running 00 in the back and 0 - .25 in the front (slight kickup)
Seems to be better. to further lower your Roll Center try raising up your Upper inside Camber links
Jason Deadman
Old 01-17-2012, 06:41 PM   #10421
kwiksi's Avatar
Says they're for nitro version of tc3. It I recall that nitro is 200mm wide. Won't those shafts be too long?
Thanks in 2017 to
Old 01-17-2012, 08:25 PM   #10422
Most run anti dive (0 - 0.050")in the front and anti squat in the rear(0 - 0.050"), but at least you have low roll center front and back... Good buddy, I have to test it out......
Old 01-18-2012, 05:37 AM   #10423
Sorry I messed a Zero lol should read 0.025
Jason Deadman
Old 01-24-2012, 08:14 PM   #10424
No, the TC3/TC4 and NTC3 use the same shafts, the ntc3 has longer diff hubs.
The TC3 Rally 200mm conversion uses longer axles #3889 or 3986.
Rojna is offline   Reply With Quote
Old 02-04-2012, 03:17 AM   #10425
hey, does anyone in here already succesfull with CS kit from yokomo? especially with CS kit from active?
j3fron is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
