Like Tree5Likes
Old 01-04-2012, 11:02 AM   #10396
Originally Posted by DaveW View Post
...mod them to 0.83mm thickness. ....
I didnt do any of that, just took out the diff and thrust balls and installed the slipper pads, put some locktite on the bolt and tightend down until the spring bottomed out, the only part I got was the 31173 pads, everything else is stock.
You must start with a metal diff, this will not work with the plastic one. Im using the 31062 outdrives..
Rojna is offline   Reply With Quote
Old 01-04-2012, 11:03 AM   #10397
Originally Posted by TeamGoodwrench View Post
What is the advantage of a spool over a 1-way ?? and where would you use a spool vs. a 1-way or a diff ???
Thx!
with a spool you have full time 4wd ... on and off power and when braking.
Old 01-04-2012, 11:05 AM   #10398
TeamGoodwrench's Avatar
And what type of tracks/conditions is this better than a 1-way or diff ???
Thx
LEFTHANDER R/C www.lefthander-rc.com
"I've got 4 on the floor and a fifth under the seat"
TeamGoodwrench is offline   Reply With Quote
Old 01-04-2012, 11:22 AM   #10399
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Thx
High bite = 1way
Med bite = diff
Low bite = spool
Thats just a guide line. Depending on your driving style or ability you can use a 1way or diff on surfaces with less traction if you like having more steering.
YR4Dude is offline   Reply With Quote
Old 01-04-2012, 01:14 PM   #10400
DaveW's Avatar
Do you have side to side play after the diff is installed in the case and the screws are tightened up? I modded the thickness of the pads to allow shimming of the diff in the trans casing. The pads form to the shape of the outdrive anyways, but only 'crush' so much... thats why i removed pad thickness.
You definitely have to use the regular steel outdrives... the lightweight steel have material removed where the pad contacts the diff half, and the plastic outdrives will just break.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 01-04-2012, 01:43 PM   #10401
DaveW's Avatar
Found it. It was part of a write up i did on a Tc3 conversion. At the bottom of this post......
TC3 Forum
And a few more at the bottom of this post...
TC3 Forum
Old 01-07-2012, 08:56 PM   #10402
kwiksi's Avatar
Trader Rating: 101 (100%+)
Send a message via AIM to kwiksi
Anyone know what the max tooth count is on spur/pinion (64 pitch)?
David Perez
Big thanks in 2017 to
Serpent/Desoto Racing - Jconcepts - Maclan Racing - Schelle Racing Innovations - Exotek Racing - PT Racing Oils - 92Zero Designs
kwiksi is offline   Reply With Quote
Old 01-12-2012, 11:19 AM   #10403
My new built TC4.1 for VTA ... almost done
Old 01-12-2012, 01:00 PM   #10404
DaveW's Avatar
Looks great! I like the mod to the upper deck for flex.
Old 01-12-2012, 01:32 PM   #10405
Trader Rating: 39 (100%+)
You will have to let us (me) know how the car handles with the top plate like that.
I have been wanting to mod mine but not had the times or courage
I have the center and outter posts removed but I'd Like more flex
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 01-13-2012, 12:46 AM   #10406
i want to change the old/stock CVD'S with common CVD/Axles for more streering angle, the question is?
which brand i should take to replace or to fit my stock TC4 CVD with common CVD/Axles nowdays?
with the cup in the axles, not in the dogbone....
for drift of course.......
THX
j3fron is offline   Reply With Quote
Old 01-15-2012, 08:25 AM   #10407
THX
http://www.ebay.com/itm/ALLOY-UNIVER...item19c4e877a1
http://www.ebay.com/itm/Titanium-Dri...item2c5795f0a3
Old 01-15-2012, 07:50 PM   #10408
Wink
Anybody run their camber link flat in a tc4 ? It took me one #2 shock piston in addition to three 1.25mm shims to get them flat or slightly sloping down towards the tire . Most of the newer kits run them flat while the standard tc4 setup slopes towards the chassis side, thereby raising the roll center. I have to test this new low roll center setup to see if I can push the car more around the turns. I had a bad traction rolling experience with the regular three shim setup. Hopefully someone could chime in....
bertrandsv87 is offline   Reply With Quote
Old 01-15-2012, 08:32 PM   #10409
Interesting thought.
You will also change the camber gain by running them flat. That could cause a loss of traction mid to exit
Something else to think about is the speed of weight transfer when having traction rolling.
Getting the car to roll slower can help with that or have the roll center higher making it want to roll more instead of just pitching over
Jason Deadman
Old 01-15-2012, 08:46 PM   #10410
THX
forgot that AE makes them and I have them in mine TC3's & TC4's LOL
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
