Like Tree45Likes
Old 12-28-2011, 12:54 PM   #10366
DaveW's Avatar
Originally Posted by mos-leung View Post
Anyone run BL motor 5T in TC3/TC4 with ball diff ?
What 's the ratio
With a 5T BL? Hmmm...
1 part melted rear diff+2 parts broken mainshaft=
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 12-28-2011, 03:00 PM   #10367
Spool front ( with lcd drives) + rear loose(gooped) ball diff is my permanent solution ! 6years on and going strong...
bertrandsv87 is offline   Reply With Quote
Old 12-28-2011, 04:50 PM   #10368
You mean running BL 5T ? How size of the race course ? 150M X 100M.....
Any photo of your car ?
thanks
mos-leung is offline   Reply With Quote
Old 12-28-2011, 07:22 PM   #10369
I run BL 3.5t at FBF (200ft X 95ft)... I need more practice to drive superfast, but in the right hands, the car is very capable , with no foreseable breakdowns !!!!!
Old 12-29-2011, 05:25 AM   #10370
AM03GT's Avatar
Originally Posted by TeamGoodwrench View Post
Can someone post all of the different combinations of the mounts and the toe-in that they make ???
I'd like to get to zero rear toe-in for VTA Oval, but I don't know what combination of rear arm mounts make up zero toe-in ???
Thx
If i remember correctly...
The front circle mount is slightly wider than the rear square for hole position...
circle - circle in the rear will give you zero toe at that width...
square - square will also give zero rear toe at the given hole width...
the X mounts are thicker to push the material closer to the rear lip of the chassis as a "bumper" of sorts but if you have some tools you can probably machine or sand down one of 2 X mounts and do X - X combinations which will give you zero degrees rear toe at the 2.0 width, 2.5 width, and the widest 3.0 width...
hope this helps...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 12-30-2011, 05:13 PM   #10371
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
So I picked up a used Team kit to get me by until outdoor offroad season. Will be club racing with 17.5 blinky mode with rubberz. How does kit setup work on indoor med to low bite? Any tips and tricks I should know when I go through the chassis?
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 12-30-2011, 06:35 PM   #10372
Lightweight EVERYTHING!!!! 230gram or less lipo pack to keep the car under 1380grams, and use chassis rake to stop traction rolling !
Old 12-30-2011, 06:39 PM   #10373
Sorry, I forgot about the 55t robinson spur gears, and front spool+lcd that you will need !!!
Old 12-30-2011, 07:11 PM   #10374
kwiksi's Avatar
Anyone switch to carbon parts on their team tub cars? Any benefits to handling while lightening the tc4 itself?
Thanks in 2017 to
Old 12-31-2011, 07:17 PM   #10375
HAPPY NEW YEAR TC4 RACERS !!!! Win a few trophies next year!!!
Old 12-31-2011, 10:22 PM   #10376
YR4Dude's Avatar
Trader Rating: 44 (100%+)
What parts from the TC4 can be used on the TC3?
Arms, hubs, knuckles, shafts?
What about bulkheads and shocktowers?
YR4Dude is offline   Reply With Quote
Old 01-01-2012, 08:03 AM   #10377
yes to all except: shocktowers needs the supports too, the shaft has thinner cross pins, so you need the cups too (I never tried to swap myself thought)
you can use the 4 chassis braces too, it puts the links onto different set-up holes
Happy new year to all.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 01-01-2012, 08:40 AM   #10378
TC3 and TC4 use different sized hinge pins so its not yes to all ... it can be done but not a direct swap.
The cva shafts are a direct swap.
Rojna is offline   Reply With Quote
Old 01-02-2012, 09:23 PM   #10379
FangsCPO's Avatar
55T Spur????? Wow!!! What pinion you running. I'm running a 60 Spur and 43T pinion.
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 01-02-2012, 09:48 PM   #10380
Exclamation
I'm needing some help with gear ratio , I have 69 spur and 37 pinion gear so what is my final ratio 4.66?
Thanks for any help
hotrod306 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jpx
