Old 12-23-2011, 09:06 PM   #10351
Smile
Keep your electronics light and your batteries around 230grams and you should be weighing 1350grams to 1380grams...
bertrandsv87 is offline   Reply With Quote
Old 12-24-2011, 05:26 AM   #10352
pejota's Avatar
Originally Posted by chestnutjazz View Post
Can someone explain to me shimming? I was looking on the site and saw some of the set up sheets, but I don't understand the sq cir or tri shimming; so can someone please give me a part list ?
If you are referring to these...
http://www3.towerhobbies.com/cgi-bin...?&I=LXNZ76&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXNZ77&P=7
They change the geometry of the inner hing pins for the arms. Squares and triangles just refer to which part goes where on the car. If you download the manual, you'll see what i mean.
The other mounts allow you to change things like toe, anti-squat and kick-up. If you do a little more research on Tower Hobbies you'll se some aluminum mounts used on the FT Team TC4.
pejota is offline   Reply With Quote
Old 12-24-2011, 09:25 AM   #10353
im looking for info on spur gears for team tc4
what spurs & size work well for a tc4 vta chassis?
also running 21.5 novak
thanks for any info
hotrod306 is offline   Reply With Quote
Old 12-24-2011, 11:44 AM   #10354
For vta you'll want to use a 60t or 66t robinson spur gear ....
Old 12-24-2011, 11:53 AM   #10355
TeamGoodwrench's Avatar
Can someone post all of the different combinations of the mounts and the toe-in that they make ???
I'd like to get to zero rear toe-in for VTA Oval, but I don't know what combination of rear arm mounts make up zero toe-in ???
Thx
LEFTHANDER R/C www.lefthander-rc.com
"I've got 4 on the floor and a fifth under the seat"
TeamGoodwrench is offline   Reply With Quote
Old 12-26-2011, 11:25 AM   #10356
Thx
They should be on the manual, if you do not have it you can download it on the AE web site.
http://teamassociated.com/pdf/cars_a...rtr_manual.pdf
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 12-26-2011, 01:51 PM   #10357
Unfortunately, been there--done that. The manual isn't any help.
I have attached a screenshot of the only section in the entire manual that even mentions rear toe -- it does not provide a chart showing the different combinations of front and rear blocks and the resulting amount of rear toe
Old 12-26-2011, 07:07 PM   #10358
Smile
The tc4 rear toe only goes down to 2 degrees, and you have to make your own modifications to get it down from there. Good luck !
Old 12-26-2011, 07:46 PM   #10359
Trader Rating: 39 (100%+)
What I would do is get a set of calipers and measure the hole spacing of the rear block and see what the spacing is on the others. I think the hub has some toe built in so you may be able to swap sides on the hubs and get less toe in.
The Arms also might be contributing but I don;t have my car in front of me and when I get it out I'll take a look to see what I see
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 12-26-2011, 07:51 PM   #10360
That's true -- I think that some guys were swapping out the rear axle carriers for Losi ones. I'm wondering if the reason was that those had less toe-in ?
Thx
Old 12-26-2011, 08:57 PM   #10361
pejota's Avatar
The Associated rear hubs aren't side specific, so there won't be any toe whatsoever. The Losi ones might have some toe built in, so there would be a left and right. Then it would just be a matter of switching them around.
If you want to do some serious research on rear-toe for oval racing, go to custom works website.
http://www.customworksrc.com/aa_support/support01.php
Many of those setups are asymetrical. For example, left rear toe will be in the 2-4 degree range and the right rear toe will be in the 0-2 degree range.
Not sure why you want zero, but it makes for some interesting reading...
Old 12-27-2011, 10:30 AM   #10362
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default ?
I have a question for all of the faithful TC3 / TC4 racers.
I remeber back in the day there was a special was to shim the diffs I know there were little tricks to the trade can some one tell any special things that will help getting the diffs ultra butter smooth. I think you had to trim some plastic off of the diff housings and use some niftech tc3 stuff but I'm not sure.
http://niftech.com/
Thanks for your time and help
RED-LINE M03 is offline   Reply With Quote
Old 12-27-2011, 12:40 PM   #10363
pejota's Avatar
Trial and Error is my method.
Shim it, put it together, test it.
Repeat until it's smooth. Sometimes i'd shave some plastic from the case, other times it was the tightness of the screws for the top of the case.
I've even had issues with the bearing cap in front of the spur.
All it takes is patience.
Old 12-28-2011, 05:00 AM   #10364
Anyone run BL motor 5T in TC3/TC4 with ball diff ?
What 's the ratio
mos-leung is offline   Reply With Quote
Old 12-28-2011, 01:52 PM   #10365
DaveW's Avatar
Originally Posted by Bubblehead View Post
There was an improvement in acceleration, but still lacking speed. I changed my gearing now my FDR is 4.9 matching what DW used when he was racing his TC4 I can't match the belt cars too slow.
Ron, you still doin well with the shaft cars? I sold everything shaft... im eying the new TC6.1.
Originally Posted by bertrandsv87 View Post
Was 4.9 for blinky or boosted ? How much does your car weigh? Anything over 1450g won't cut it....
4.9FD was 17.5 boosted (LRP x12/TekinRS). Mine was at legal weight adding 7 grams.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
SEO by vBSEO 3.5.0
