Like Tree26Likes
Old 10-26-2004, 12:11 PM   #1021
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Originally posted by Charlie O
I just pulled the front end off my NTC-3 it fits right on, just use the long screws from the NTC-3 & rubber grommets.
I seem to be having trouble with the NTC3 front bumper. To me, it doesnt look like a direct fit. The holes arent lining up. Charlie O, when you said you took off the front end of the NTC3, which parts do you mean?
Paul_TC4 is offline   Reply With Quote
Old 10-26-2004, 12:13 PM   #1022
Default Ya the Square ones look nice...
but I just dropped bucks on my IRS stuff. They are new so I don't see any grooves yet.
I talked to Speedtech about the Ti RAcing suff and he said qaulity is bad right now. Problems with the ti shafts not working. I don't think they are stocking them anymore.
I was told today that the front TC3 arms work fine if you drill the holes bigger on the larger hinge pin side. A quick fix until they come.
Nightbreed is offline   Reply With Quote
Old 10-26-2004, 12:15 PM   #1023
Paul_TC4's Avatar
Drilling holes in the arms was my original idea until I decided that I would use my tc3 hinge pins which are smaller a shot. If they dont work, now I know what to do
Old 10-26-2004, 12:15 PM   #1024
Default Tell us what we need Charlie O...
I hope to fit the NTC3 bumper on my TC4.
Old 10-26-2004, 12:27 PM   #1025
Greg Amendola's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to Greg Amendola
Couldn't one use a specified length of string, tire it around the drive shaft near the input adapters, measure the distance to the midpoint of the string, and make sure the string is equi-distant on the drive shaft in relation to the input adaptor? That should give you a really good idea of both front/rear balance but also L/R balance as well. This sounds much more complicated than it is...
Greg Amendola is offline   Reply With Quote
Old 10-26-2004, 12:37 PM   #1026
Hi again just wondering wat the drive ratio is, is it the same as the tc3 2.5?
Chazz
Chazz is offline   Reply With Quote
Old 10-26-2004, 12:42 PM   #1027
Charlie O's Avatar
Default Re: Tell us what we need Charlie O...
RPM NTC-3 front bumper the lower plastic one, AE NTC-3 foam front bumper part # 2227, AE NTC-3 part# 2332 rubber pad/grommet, & AE part # 6923 4-40 X 3/4 countersunk screws. never worry about a front A-arm again!
Charlie O is offline   Reply With Quote
Old 10-26-2004, 12:52 PM   #1028
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Charlie O,
Can you post pics of your NTC3 Bumper Conversion on my TC4? That would be pretty cool to check out.
cpatel529 is offline   Reply With Quote
Old 10-26-2004, 01:50 PM   #1029
Chazz
Don't need to know now found out
Chazz
Old 10-26-2004, 01:55 PM   #1030
Default Ratio
FYI- you can figure any car's ratio by dividing the diff gear by the pinion that runs on it.
This is not the spur gear divided by the pinion that runs on it.
JWATT is offline   Reply With Quote
Old 10-26-2004, 02:51 PM   #1031
I just want to mention for others that are building their cars, and mabe haven't read all of the posts on this thread.....That I had the same defective ring gears (being too thick) where the balls sit, causing the diff to be nearly locked up when correctly built, swapping in another set from the hobby shop completely corrected this....also, behind the wheel axle roll pin (right where the wheel hex or star adapter goes) mine needed to have the standard 10 thousanths 3/16 axle shims behind them like the TC-3 did.....Part# 7368......otherwise, the slop was completely unacceptable.........other than that everything went together "pretty" well.....also if you want the drivetrain super smooth ,take the extra time to pop the inner seal from the bearings (soak in motor cleaner or similar product) then fully blow them out, and lightly oil.....and the dvivetrain should be as good as possible,so far the people that Iv'e heard complaining about the drivetrain smoothness haven't done this........Im also wondering , are anyones front or rear arms (where the hinge pins and those little piviot balls go into the arm blocks) pretty sloppy?....... mabe associated engineered some slop into this area kinda like they said they did on the B-4 buggy and T-4 trucks..... and then later offered a fix for them
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 10-26-2004, 02:54 PM   #1032
Above....I was refering to the steering linkage on the B4 and T4's being corrected
Old 10-26-2004, 03:20 PM   #1033
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Brandon Melton
JDM_DOHC_SiR. Is blue the only color available?
Yes Blue is the only color...
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 10-26-2004, 04:40 PM   #1034
RBLove's Avatar
Trader Rating: 71 (100%+)
Default Re: 28 mm Foams on the TC4
Originally posted by XrayEye
Does anybody know if you need to modify 28 mm foams to keep them from interfering with the front suspension?
Thanks,
Dave.
Parma 28mm foams fit without any modifications. The off set is a little different that the Jaco. Not too mention the Parma foams are simply awesome...............
RBLove is offline   Reply With Quote
Old 10-26-2004, 04:42 PM   #1035
myclod's Avatar
Send a message via AIM to myclod Send a message via Yahoo to myclod
yeah the new parma foams are supposed to be nice, i just used some Tamiya spacers on mine and they work fine...AND they are BLUE
myclod is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
