Like Tree26Likes
Old 11-22-2011, 10:56 PM   #10306
Thumbs up
Also , as a security feature , you can use double sided tape to stop the battery from flying out if the tape fails...
bertrandsv87 is offline   Reply With Quote
Old 11-23-2011, 03:53 PM   #10307
whitrzac's Avatar
Trader Rating: 94 (100%+)
Anyone know where I can get a pair of MIP cvds(or similar)? I'm usually decent at finding rare crap, but I'm turning up empty handed....
whitrzac is offline   Reply With Quote
Old 11-23-2011, 05:59 PM   #10308
I use THESE
Rojna is offline   Reply With Quote
Old 11-24-2011, 08:34 PM   #10309
Towerhobbies should have the Factory team cvd's . Anyway anyone mixing Ae 80wt with Ae 40wt in their shocks to slow the leaks ? 80wt should stay at the bottom while the piston moves in 40wt oil. I also use green slime on the O rings....
Old 11-24-2011, 11:26 PM   #10310
I bought AE 31123. which totally doesn't leak anymore. I also used green slime and i have been using it quite bit now with no messy a-arms. :thumbsup:
iDChuck is offline   Reply With Quote
Old 11-25-2011, 05:13 AM   #10311
Trader Rating: 40 (100%+)
No silicone oils will mix and create a new blend
if you put in half 80 and half 40 you would end up with 60 in about 5 cycles on the shock
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 11-25-2011, 08:46 PM   #10312
Smile
Found the problem. Busted O ring . Everything is fine now. The Ae 31123 is good but I have so many parts for the old Ae shocks that I have no choice but to use them. Also I put 80wt oil only up to the level where it would cover the piston, and then I add 40wt to top it off. I don't know what kind of mix I got, but I will test it next week and see...
Old 11-25-2011, 08:49 PM   #10313
Also I forgot to mention, anybody using throttle advance in their radios ? I put mine at 30%, and it shaved two seconds in my lap times running stock. Now I have to add throttle acceleration to the mix to hopefully shave another three seconds..lol...
Old 11-26-2011, 02:03 PM   #10314
bert, care to share your radio setup? I messed with mines earlier this week and improved a lot. I'm loving my fttc4 even more.
Old 11-27-2011, 10:24 AM   #10315
Ok IDCHUCK, this is how I setup my radio:
#1: Epa steering 110% left and 110% right
#2: Epa throttle 120% , brake 40%
#3: Expo steering +50% (for slow speed and tight track)
#4: Expo throttle +100% , brake 0%
#5: Speed steering 100% turn, 100% return
#6: Subtrim throttle -50% (brushed motor advance)
#7: throttle acceleration 60% to 90% (per layout)
#8: Steering dual rate 69%
These settings will make your car automatically run at 50% of top speed when you let go of your throttle while making turns, thereby automatically carrying speed through the turns. I always setup to carry as much automatic throttle through the S section of the track, and punch it everywhere else ... Make sure you stay on the brakes or else your car will take off....
Old 11-27-2011, 10:36 AM   #10316
Idchuck, throttle advance should be used to get the car going about 15mph to 20mph. If you run stock that will probably be about 50% of top speed, but if you run mod, it might be about 20% of top speed. You car setup will be crucial in carrying corner speed, but you won't have to input any throttle to get through the S section... Also , if you can manage without using brakes it will reduce motor heat dramatically....good luck buddy...
Old 12-02-2011, 10:59 AM   #10317
FangsCPO's Avatar
I have a Spektrum DX3R.....how would I add throttle advance. Oops!!! Never mind, I just so the post. Thanks!
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 12-02-2011, 08:39 PM   #10318
Throttle advance should be used carefully just until you can get a smooth lap going, and probably won't be needed as you get better with the rythm of the track. Right now I found that my rear ball diff was too tight , and my motor comm was done. Hopefully that will make a big difference next wednesday....
Old 12-03-2011, 07:54 AM   #10319
cwoods34's Avatar
Got 2nd to a 2012 T3 last night in 17.5 by a few seconds..... Had a few moments with lap traffic...... Was also only .04 off his fast laps. A little more work.....
Weighed at 1473
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 12-03-2011, 08:32 AM   #10320
Smile
Good cwoods34 . My tc4 rtr is also heavy at 1465grams, with a tp3200 40c (208g) pack, but if your pack is not as light as mine, you can lose some more weight. I tried a tp4200 40c (263g), and a tp5300 65c (309g) in my car , and the excess weight hurt my lap times bad. I also had less speed down the straight , as I could not carry any serious speed through the turns with the heavier packs. The lightest my 13.5 Fttc4 can be is 1420g with the tp3200 (208g) I have, and I can lose another 40grams by running a low profile servo and a tekin RS instead of a Gtb...
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
