Like Tree19Likes
Old 11-04-2011, 10:10 AM   #10276
Jason you ran blue springs in the front ? If you can't get rear traction, slightly lower the rear droop ( from 3mm to 2mm)... Tc4's don't like too much droop in the rear... What about your steering expo, make sure you're between -40% and -10% ...
bertrandsv87 is offline   Reply With Quote
Old 11-04-2011, 10:32 AM   #10277
Trader Rating: 40 (100%+)
Yea I went to the Blue springs and the lower roll center made the car roll and tonne less than before. But I dis sacrifice rear traction. Not too bad but once corner in particular I likes to drift out due to a bumpy section.
I was thinking of trying a roll bar in the front but have to tested that yet.
Also our track was recently changed and some sections have not been run on much yet. and our carpet is old
P.S. what is the idea to changing the expo on the steering? Slowing down the action or speeding it up?
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 11-04-2011, 07:32 PM   #10278
Yes , the idea behind the (-40% to -10%) expo is to slow down the steering servo's sensitivity around neutral, thereby stopping the whiplash effect that might cause the rear to seem loose. It also gives a smoother feel, that results in faster laptimes and consistency...
Old 11-04-2011, 07:35 PM   #10279
Cool Idea I'll try that. Monday is our first club race. we'll see how things go
Jason Deadman
Old 11-04-2011, 07:42 PM   #10280
I have read somewhere that Paul Lemieux uses -10%, the Awesomatix experts prefer -35% ... I run -30% now , and I am learning the new racing line...
Old 11-04-2011, 07:53 PM   #10281
Smile
Jason, I forgot to mention that you can also use high throttle expo(+40% to +100%) to punch out of turns faster, and you can also add throttle acceleration (50%) to that , so you can out accelerate everybody... That's the shaft drive advantage !
Old 11-04-2011, 10:08 PM   #10282
cwoods34's Avatar
Anyone running 21.5 or 17.5 stock on low/medium bite carpet? I've been playing with 15.5 front/12.5 rear springs and various droop settings but the back end always wants to slide around. Spool up front..... won the USGT main tonight but curious to see what other setups anyone is running.
Also, what camber link positions do you guys like?
We use Solaris medium tires FYI.........
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-05-2011, 07:24 AM   #10283
did one of you run your car with a 10.5t boosted? and if so what fdr are you using in TC4?
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-06-2011, 11:26 AM   #10284
Another radio setup tip dual rate down to 70% . 100% is too much, and causing a loss of corner speed ...
Old 11-06-2011, 02:01 PM   #10285
Personally I run my radio so that it has full range and the outputs directly reflects what inputs I make.
I then drive the car.
frozenpod is offline   Reply With Quote
Old 11-06-2011, 02:13 PM   #10286
Weighted my car at 1200g without battery in (2s)
Here is its new coat too:
Uploaded with ImageShack.us
Old 11-06-2011, 08:38 PM   #10287
Smile
That's pretty low for a tc4 , but you still need a light battery pack to compete in stock : tp3200 40c (208grams) or lighter...
Old 11-06-2011, 10:49 PM   #10288
Default bodies
Where is a good place to buy bodies from?? Also does any 1/10 scale touring body fit? I'm trying to find something that looks different from stock. if anyone also has pics of there bodies that would be great.
rtaylor15 is offline   Reply With Quote
Old 11-07-2011, 02:11 AM   #10289
Don't forget mine's a TC3, I use IP 5600 60C usually on the TC6 for races or Kypom 5800 in 50C
Old 11-07-2011, 02:46 PM   #10290
These packs are heavy (over 300grams), and only necessary for mod racing , where the extra 100grams won't matter much...
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
