Like Tree36Likes
Old 10-31-2011, 03:04 PM   #10231
Jason, did you weigh your car??? What battery pack do you run ? Try to get as light as possible...
bertrandsv87 is offline   Reply With Quote
Old 10-31-2011, 03:48 PM   #10232
Trader Rating: 40 (100%+)
Lol. Yea I run my car at the min weight. 1550g. Lol. We run. Usvta rules
I have made the changes. Just have to get down to the track
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 10-31-2011, 04:32 PM   #10233
Smile
Sorry Jason , I also wanted to point out that I meant two degrees negative camber all around, not positive in my previous post : I worked too much this week....lol.... I see that you run one degree positive camber up front but sauce only 1/3 of the tire. AE tc4 cars have loose bearings that already cause a one degree gain in camber with minimal lateral push. So you are ending up with two degrees positive camber while turning, too much traction, and huge outside tire wear. On the other hand a negative two degrees camber would end up being one degree negative camber with a more even tire wear, and, with full tire sauce, will give you enough traction to turn... Also, for 1550grams I think Ae blue or silver springs work best.....
Old 10-31-2011, 04:33 PM   #10234
What chassis are you guys running ? ( Jason what chassis are you running on that setup ?)
hotrod306 is offline   Reply With Quote
Old 10-31-2011, 05:05 PM   #10235
Quite right on the bearing slop. And I am actually get most of my wear on the inside of the tire currently. And I just replaced my bearings on the front and CA'd the inside of where the bearings go to Eliminate the slop and I had to add a shim behind the outside bearing reduce it more
I am running the factory team carbon version with all of the braces. ( front center and rear) removed
I'll take some pics as soon as I get light and time at the same time
Jason Deadman
Old 10-31-2011, 07:30 PM   #10236
Jason, how much faster was the guy ahead of you? I am certain that you will find that little extra speed/setup to win... Let us know soon...
I am usually only a few second back after 8 min But that is due to mistakes. If the 2 of us dont make a mistake it's a tossup as to who wins. average lap times are about the same
Jason Deadman
Old 10-31-2011, 11:04 PM   #10237
You got that car running right Jason... Good luck at next race !
Old 11-01-2011, 05:37 AM   #10238
Thanks,
I will be hitting our indoor track for some testing and maintenance on Wednesday and I will let you all know how it goes.
Just went thru the car last night and made some of the changes and it feels pretty good.
the one Thing I did this year is to centralize the added weight that I need for this class so I have put 126g of lead along the center-line under the drive shaft and I am now .05% from being perfectly side to side balanced and with my battery positions (custom battery locators) I can set the forward/rearward bias from +10% to -10% and a couple places in-between.
So I will be putting a few packs thru this beast and I can't wait
Jason Deadman
Old 11-01-2011, 07:23 AM   #10239
One thing that I cannot remember reading about in all your threads that could be good to upgrade too, are Losi pistons in shocks, they are defenitely smoother than AEs
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-01-2011, 07:27 AM   #10240
what happens when you dont run with a spine board?( i think thats whats it called)
do you get any more grip?
what springs for rtr should i run?(silver can,carpet) thanks
Old 11-01-2011, 09:09 AM   #10241
The Idea of removing the spline and top plate support posts is to increase flex in the chassis.
Generally (as far as I have found) adding flex helps with low traction conditions
Jason Deadman
Old 11-01-2011, 09:40 AM   #10242
jason and who ever, have you ever raced with tc4 in stock binkey 17,5 class and if so how did you make out vS the tc5,6 newer xrays ect?
Old 11-01-2011, 10:11 AM   #10243
I have not raced this chassis in anything other than VTA
Jason Deadman
Old 11-01-2011, 11:12 AM   #10244
I recently got a FTTC4, and I noticed removing motor screws is a pain in the butt for me. The problem for me is that the arms are in the way, so I would have my hex tools at an angle almost stripping the screws. What are your ways and tips I should know how to remove motor screws when adjusting for mesh.
iDChuck is offline   Reply With Quote
Old 11-01-2011, 11:31 AM   #10245
Generally I only change gearing occasionally but when I do I remove the motor and motor mount with the spur gear and set the mesh on the bench as it is a pain in the behind to adjust in the car
I have done it but with the old style 90 degree hexes. But it's slow
Jason Deadman
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
