Like Tree19Likes
Old 10-05-2011, 04:13 PM   #10156
Check the closeout items , there should be alot more parts there ! The tc3/4 also does not require many upgrades to be competitive : IRS spool , lcd drives, acer bearings , litedrives, and you're good to go !!!!!
bertrandsv87 is offline   Reply With Quote
Old 10-06-2011, 05:16 AM   #10157
Originally Posted by SHOEADDICT View Post
Yes I have without any problem, STOP SHOUTING !!
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 10-06-2011, 08:36 AM   #10158
Folks from asia are the best at customer service ! Never worry about loosing your money. It is not in their culture to deceive people !!!!!
Old 10-07-2011, 02:24 PM   #10159
Bubblehead's Avatar
I replaced my stock servos with Savox SC-1257TG big improvement, I found out why my car was so slow my motor was shot due to over gearing too much heat, no fan.
Handing is also getting better adjusted front/ rear shocks.
Bubblehead is offline   Reply With Quote
Old 10-07-2011, 03:13 PM   #10160
So it's all good
Old 10-07-2011, 06:20 PM   #10161
The savox 1257tg is fast 0.07sec, but it's 20grams heavier than the low profile savox 1251 servo 0.09sec ..... Anyone with a low profile servo in a tc4 ????
Old 10-07-2011, 06:54 PM   #10162
Anybody seen the Awesomatix center shaft roller system to stop shaft from wobbling ???? I Wonder if it can be retrofitted to a tc3/tc4 !!!
Old 10-08-2011, 09:20 AM   #10163
Smile
I have the IRS litedrives in the rear of my tc4's for years now , no rebuilds ever . How long does your ball diffs go before you rebuild ??? Do you run them in the front ?
Old 10-09-2011, 05:09 AM   #10164
Bubblehead's Avatar
Good day at the track yesterday, worked some more bugs out I think I'm ready for next weekend. My problem was not heat something is wrong with the can "stator".
Old 10-10-2011, 11:46 AM   #10165
What sort of bugs did you find ? There are lots of them, but nothing that can't be solved...
Old 10-10-2011, 12:11 PM   #10166
One of these bugs in Mod is the roll center issue. I had to run very low roll center setup (0-2) from the manual to stop my cars from traction rolling, in addition to running 2 to 2.5degrees of camber to compensate for the wheel bearing slop that reduce the camber by 1 degree or more when the car enters a corner. I could add transmission shims to reduce the slop, but it binds my drivetrain a bit. I prefer adding camber and making sure my tires turn without any excessive vibrations when free revving...
Old 10-10-2011, 01:42 PM   #10167
Bubblehead's Avatar
Switched bodies P37 over Mazda Speed 6, P37 has a more neutral feel. ESC settings and adding motor end-bell timing , chassis set-up is good 17.5 boosted. 17.5 blinky needs a little work going to change front roll-center, lower inside camber links.
Old 10-10-2011, 02:31 PM   #10168
Guys, are the TC4 ft CVD dog bones longer than TC3 dogbones (blue aluminium)?
Old 10-10-2011, 03:09 PM   #10169
Bubblehead's Avatar
I checked the part# and they seem to be the same ASC 3888, I have the HD CVD's in the front of my TC4's.
Old 10-10-2011, 03:36 PM   #10170
Tc4 and Tc3 bones are the same length but not the same thickness: tc3(3.5mm), tc4(5mm) . The tc3 ones appear longer . Good to see you guys improving your setups....
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
